Old 07-19-2008, 04:54 PM   #1
marlon177
My Ride: 04 Audi A4 1.8tQ USP
Send a message via MSN to marlon177
do i need torque wrench to install spark plugs
just order some ngk spark plugs from pep boys, but i don't have a torque wrench, do i really need one to install spark plugs? if i don't use the torque wrench to install the spark plug, anything will happen to my car? does torque wrench cost alot? thanks
marlon177 is offline   Reply With Quote
Old 07-19-2008, 05:02 PM   #2
NicB.
My Ride: 2000 BMW 328i
if you can torque them by hand to the correct level good for you. for those of us who don't trust the feel in our arms, we trust the click of the torque wrench.
NicB. is offline   Reply With Quote
Old 07-19-2008, 05:20 PM   #3
TxZHP04
My Ride: ESS TS2+ ZHP
USE A TORQUE WRENCH. Aluminum is not very forgiving.
Old 07-19-2008, 05:22 PM   #4
Roothog69
My Ride: 05 330i ZHP
I bought a 20 dollar torque wrench @ Pep Boys, I would recommend spending more money and getting one at Sears about 75 bucks. The one I got is cheap and the numbers don't really line up well on the handle. But feeling the click makes me feel fuzzy inside.
Roothog69 is offline   Reply With Quote
Old 07-19-2008, 06:49 PM   #5
Chris C
My Ride: 2001 325Ci
I bought mine from Sears for ~$75.00 and it is good.
Chris C is offline   Reply With Quote
Old 07-19-2008, 06:56 PM   #6
blk04zhpcpe
My Ride: 2004 330ci zhp coupe
definitely get a torque wrench. $35-$50 at autozone will work. overtightened a plug and in the process, stripped out the threads on my volkswagen and had to pay to have it repaired(helicoil). i'm sure it would be more expensive on a bmw. if you are going diy, spend more and get a good one.
blk04zhpcpe is offline   Reply With Quote
Old 07-19-2008, 07:17 PM   #7
willsbma
My Ride: 99 323i
Definitely use a torque wrench
Matte Black Kidney Grilles | Smoked Tails & Corners | Mtech II Bumper | Hotchkis Springs | ACS Roof Spoiler | M3 Spoiler | 20% Tint
WTB: Black sun visors & grab handles - PM ME!
I have P.A. Soft and a 20-pin adapter. Only used it a few times but pm me if you need anything coded!
willsbma is offline   Reply With Quote
Old 07-19-2008, 07:22 PM   #8
Anub!s
My Ride: e46 330ci, e92 M
Send a message via AIM to Anub!s Send a message via MSN to Anub!s Send a message via Yahoo to Anub!s
yep
Anub!s is offline   Reply With Quote
Old 07-19-2008, 08:01 PM   #9
kuksul08
My Ride: M3
Make sure the engine is cold so the metal is not soft. Screw them on until they touch the crush washer, you will feel it spin easily until it stops when it hits the washer. Then turn it very carefully and you can feel it crush the washer and stiffen up exponentially, which is about half a turn after it stops.
If you don't trust the feel then I'd say get a torque wrench.
Look at that subtle jet-black coloring. The tasteful thickness of it. Oh my God, it even has a 6mt.
S54 Valve Adjustment Spreadsheet & Info: http://dl.dropbox.com/u/28231781/S54...ent%20info.zip
S54 VANOS DIY Video: http://www.youtube.com/watch?v=9SkT2j3jsU0
kuksul08 is offline   Reply With Quote
Old 07-20-2008, 12:59 AM   #10
sdbimmer
My Ride: 2004 325Ci
http://www.harborfreight.com/cpi/cta...itemnumber=807
Walmart has one also for like $25.00.
sdbimmer is offline   Reply With Quote
Old 07-20-2008, 01:23 AM   #11
sprintman
My Ride: Ex 325CI owner
Torque wrench. Important to get the right amount of crush on the washer for correct heat transfer. Buy a decent torque wrench and you will have it for life. Cheapies are uselwss
sprintman is offline   Reply With Quote
Old 07-20-2008, 07:57 AM   #12
franz
My Ride: 03 330i
This is probably the job you MOST need the torque wrench for, next to your lug bolts.
franz is offline   Reply With Quote
Old 07-20-2008, 10:48 AM   #13
kpeng
Banned User
My Ride: E46 330 and E30 325
You will need a torque wrench and anti-seize. 18 ft./lbs for each one.
kpeng is offline   Reply With Quote
Old 07-20-2008, 12:15 PM   #14
willsbma
My Ride: 99 323i
^ Aren't you supposed to kick the ft/lbs. down when using anything that will lubricate the threads? I thought I read it somewhere.
Old 07-20-2008, 01:27 PM   #15
kpeng
Banned User
Ya, without anti-seize, 22 ft./lbs is recommended.
Old 07-20-2008, 01:33 PM   #16
marlon177
yea i got the anti seize, i will go check autozone or pepboy for a wrench....
Old 07-20-2008, 01:36 PM   #17
bmwmedic
My Ride: 323i 99 01 530i sp
Make certain you have copper containing anti-seize.
It conducts electricity and allows the plug to ground against the block, as it should
bmwmedic is offline   Reply With Quote
Old 07-20-2008, 09:54 PM   #18
fieroturbo
My Ride: 2002 BMW 330xi
I'm not sure about you guys, but I don't trust the "click" style torque wrenches. The minimum accurate level on most I've used only goes down to 30 or 40 lbs/ft of torque, and I've seen ones that were actually 20 lbs off from what the torque really was. That's asking for stripped threads, or broken bolts in the case of my Pontiac's oil pan.
I personally prefer the "needle gauge" style torque wrenches. It's accurate from 1-100 unlike the click style, and it automatically zero's out, unlike the radial gauge versions, and it's WAY cheaper than the digital versions.
It's the same price as the "click" versions.
I've got two from Craftsman: One that's about a year old, and another that's about 30 years old. Both work great!
Avionics Technician Second Class
Michael C Casaceli
United States Navy
2002 BMW 330xi - 5-speed (manual)
1994 Chevy S-10 Pickup - 4.3L Vortec
1988 Pontiac Fiero - 2.2L Ecotec Turbo
fieroturbo is offline   Reply With Quote
Old 07-20-2008, 10:02 PM   #19
infamous_e46
My Ride: Tu Mama
inch lbs or foot lbs torque wrench and dont ngk's have crush washers you can feel them give when its on tight enough
infamous_e46 is offline   Reply With Quote
Old 07-20-2008, 11:01 PM   #20
jamesthebikeguy
My Ride: Is a ugly POS
Send a message via AIM to jamesthebikeguy
how on earth can you install spark plugs wrong and eff it up? i mean come-on turn till firm give it a bit extra and nothing will be hurt or broken. Spark plugs aint rocket science.
u think ur mechanic uses a tq wrench for a spark plug?
some things on these bimmers need em but seriously?
jamesthebikeguy is offline   Reply With Quote
