///M3 Forum
Old 07-25-2008, 08:35 AM   #1
s14roller
My Ride: E46 M3
Keyfob remote will unlock but not lock car???
Guys,
It's a strange problem which I did a search for but seems like it's not a central locking problem that people talk about.
Basically, when I use the remote to unlock the car/trunk, they work fine. But it won't lock the car. When I manually use the key to lock, all doors lock and alarm system arms.
When in the car, I can also hit the lock button and both doors will lock.
Anyone had this before??
Thanks!
s14roller is offline   Reply With Quote
Old 07-27-2008, 03:39 AM   #2
KillaC3
My Ride: 18 & Over
Problematic keyfob Have you tried it with your other key? The locking mechanism seems to work fine. I think its the keyfob.
Carbon Fiber Fog Light Cover, Stock 19"s, & Stock Exhaust FOR SALE!!!
KillaC3 is offline   Reply With Quote
Old 07-27-2008, 03:48 AM   #3
sillieidiot
My Ride: '06 AW 330ci
are you like too far from the car?
Old 07-27-2008, 01:04 PM   #4
s14roller
My Ride: E46 M3
Yeah, Ive spent a lot of time searching on the forums and it seems like I may need to just drive the car a bit, and have the battery in the remote charge from ignition. Good news is, it's not a big deal and chances are, it's just the remote battery.
Thanks guys.
Old 01-06-2009, 08:26 PM   #5
cartsd
My Ride: 2001 328i
I just replaced the battery in my friend's keyfob as per instructions from this thread http://forum.e46fanatics.com/showthr...ey+fob+battery and we're having the same problem. Keyfob unlocks car but won't lock it. Trunk release button works though. I went through the key reset procedure several times and it seems to work fine, i.e., the car locks and then unlocks to acknowledge that the key is "paired". Does she just need to drive the car around some to allow the new battery to come up to full charge? Did that work for you, s14roller?
cartsd is offline   Reply With Quote
Old 01-07-2009, 01:02 AM   #6
Mike@F1 AutohaŘs
Past Site Sponsor
My Ride: E46 330ci
Could be the GM5 module going bad
Mike@F1 AutohaŘs is offline   Reply With Quote
Old 01-07-2009, 09:10 AM   #7
drchuck72
My Ride: 2003 M3
I'm having a similar problem, but, mine stems from the fact that oftentimes, I can't lock or unlock the car when I am standing behind it. I have to stand off to the side to open it. And I've always found that the BMW keyfob remotes do not have particularly good range. I can unlock my wife's Honda from 3-4 times as far away and that's not saying much because I have to be really close the BMW to use the remote.
DR CHUCK (plate number ON)
2003 Titanium Silver M3 Cabriolet
AC Schnitzer rear lip spoiler, Carbon Fibre Rear Valence and front strut bar.
Supersprint Exhaust
drchuck72 is offline   Reply With Quote
Old 01-07-2009, 11:58 AM   #8
smaglik
My Ride: 2002 BMW M5
the range does suck on the remotes. possibly need to re-acquaint the remote with the car? I recall there is a procedure for this somewhere.
smaglik is offline   Reply With Quote
Old 08-04-2015, 06:31 AM   #9
shortysE46
My Ride: e46
Hate to resurrect an old thread but has anyone solved this issue?
Ive replaced the locking relays in my GM5 with no change.
My fob will lock and release trunk, but not unlock.
It will work if I hit the lock button twice and follow it up with the unlock.
shortysE46 is offline   Reply With Quote
Old 08-04-2015, 08:46 AM   #10
M_3_X
My Ride: E46M, 330Xi, E30, X3
Have you tried the key initialization process?
2002 ///M3 Coupe, Steel Gray, black leather, HK, 6MT.(01/2015-current)
2005 X3 3.0i ZPP, Htd seats, Htd strng whl, Black Sapphire on Terracotta.(08/2008-current)
1991 325i Convertible, 5MT, htd seats
2004 330Xi Orient Blue, 6MT, Sport, Premium - Son
1995 ///M3 Coupe, Luxury, MT, Htd seats, Cosmos Black.(11/2011-01/2015)
2003 325Cic Orient Blue, Premium (03/2007- 03/2010)
River City Bimmers - BMW CCA Chapter
M_3_X is offline   Reply With Quote
Old 08-05-2015, 08:24 PM   #11
shortysE46
My Ride: e46
Yes ive tried that, the key will initialize. Meaning the unlock button is working. Its so strange
