Thread Tools Search this Thread Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Old 07-25-2008, 10:52 AM   #1
security6
My Ride: 2001 330i
P0430 P0420 - Catalyst inefficiency - do I have to replace cats?
I have been getting P0420 and P0430 (not always at the same time) about once a month for the last 4 months. This past week, I have gotten the P0430 code 3 times. My car runs great. Acceleration is good, no rattles from underneath, no indication that anything is wrong except for the CEL. I replaced the post-cat oxygen sensor on bank 2 about 5 months ago with a new Bosch sensor. The precat sensors look good, but I don't know how old they are.
I'm thinking of doing the spark plug nonfouler "mod" on the post-cat oxygen sensors just to stop the CEL from coming on. Any reason (besides excess pollution) why I shouldn't do this? Will it have any long term effect on my car?
A little extra info to head-off the inevitable questions:
My next smog check isn't until March 2010, so I'm good for a while. Also, they don't use a sniffer here, just check for OBD readiness.
Car is a 2001 330i w/ 113k miles. I've owned it about 6 months. Last February I had some vacuum leaks which have been fixed for a while. I replaced the spark plugs, VANOS seals, and valve cover gasket about 1.5 months ago, as preventative maintenance.
security6 is offline   Reply With Quote
Old 07-25-2008, 11:02 AM   #2
MachRc
E46Fanatic
MachRc's Avatar
My Ride: 2003 Technik S1 M3
the cats are built into your headers...
maybe its time to change the 2 post cat sensors..
"One thing we all adore. Something worth dying for..
Its been nothing but pain, stuck in this game. Searching for fortune and fame"
MachRc is offline   Reply With Quote
Old 07-25-2008, 11:19 AM   #3
security6
My Ride: 2001 330i
Hmm....not sure I understand why you think changing the post-cat O2 sensors will do anything. I changed the post-cat sensor on bank 2 last February. I've only driven 4000 miles or so since then. Do oxygen sensors usually go bad that quickly? If the oxygen sensor was bad, wouldn't it throw a different code than p0430? Am I missing something here?
Old 07-25-2008, 11:23 AM   #4
MachRc
E46Fanatic
MachRc's Avatar
there are 2 pre and 2 post.. you only changed one?
Old 07-25-2008, 11:43 AM   #5
security6
My Ride: 2001 330i
Yep. I only changed bank 2 post-cat because that was the only sensor I got a code for (heater circuit on the sensor was bad). The sensor was replaced with a Bosch sensor designed for BMWs (i.e. I didn't have to splice any wires).
The 2 pre-cat sensors look fairly new, but I don't know for sure how old they are since they were there when I bought the car 6 months ago. I'm almost certain the post-cat O2 sensor on bank 1 is original.
Just to be clear, here is the timeline:
Jan 2008 - purchased car
Feb 2008 - replaced bank 2 post-cat O2 sensor
April 2008 to July 2008 - p0420 (bank 1) and p0430 (bank 2) codes appear about once a month. Sometimes both would come up, and sometimes only one would come up.
Week of July 20, 2008 - p0430 code (bank 2) is appearing every 2 or 3 days.
Old 07-25-2008, 01:28 PM   #6
K:^P
My Ride: 00 323//65 Fastback
I would change the pre-cats. A bad pre-cats may throw a code for the post-cat, not because the post is bad, but the emission is not normal.
K:^P is offline   Reply With Quote
Old 07-25-2008, 01:43 PM   #7
MachRc
E46Fanatic
MachRc's Avatar
i have a peake tool.. bit starnge with looking up all the f32 c23 codes but it shows clearly..
and maybe...
just maybe.. do you know if these headers are stock? you should have two resonators that kinda look like cats but theyre not
Old 07-25-2008, 02:23 PM   #8
security6
My Ride: 2001 330i
and maybe...
Not sure what you mean by the red sentence. I get the codes from a standard OBDII reader, not a Peake tool.
I'm sure the headers are stock. They have the BMW logo stamped on them.
Some interesting thoughts. I've never heard of bad pre-cat O2 sensors setting off a cat ineffiency code, because there are codes for bad O2 sensors.
Perhaps I need to get a scan-tool to hook up the computer to see what the O2 sensors are reading. On the other hand, it would be cheaper to do the spark plug non-fouler "mod."
Old 07-25-2008, 04:06 PM   #9
infamous_e46
My Ride: Tu Mama
if the cats are bad its time to get headers and software or headers and race cats
infamous_e46 is offline   Reply With Quote
Old 07-25-2008, 04:52 PM   #10
EuroTuner28
My Ride: 330ci ZHP,M3 ZCP
Send a message via AIM to EuroTuner28 Send a message via MSN to EuroTuner28 Send a message via Yahoo to EuroTuner28
change ur cats
funny how u find the car of your dreams and then u read the dreaded "AT"...deal killer...
EuroTuner28 is offline   Reply With Quote
Old 07-25-2008, 05:03 PM   #11
MachRc
E46Fanatic
MachRc's Avatar
the regualr obd2 scanner will show oxygen sensor codes it as heater circuit and the bank number..
a peake scan tool will give you a code like 0A
which then explains EXACTLY what it is..
its usually the pre-cats that go out first.
and guys.. the cats ARE the headers.built in ..
Old 07-25-2008, 06:34 PM   #12
security6
My Ride: 2001 330i
Most OBDII scanners will also show manufacturer specific codes (e.g. P1XXX), but the description might be off. However, the Bently manual gives descriptions for all the codes (regular and manufacturer specific).
The Peake tool isn't giving you any more information than an OBDII scanner (one that can read manufacturer specific codes at least). You just have to be careful not to trust the OBDII scanner description - double check it in the Bently manual.
As an example:
OBDII code I got was p0430 - catalyst inefficiency bank 2
If you hooked up a PEAKE tool you would get 06-2D. Then you would look it up in their book and see that it says catalyst efficiency, cyl 5-6. (The Peake manual here is wrong. It says there is a code for cylinders 1-4, and a different code for 5-6. It should say cylinders 1-3, and cylinders 4-6)
Old 07-25-2008, 10:05 PM   #13
silverslider
My Ride: 2001 325ci
Take a look at your O2 sensor values for that bank, I have seen a couple of instances where lazy sensors that are just above threshold set cat efficiency codes, but you had the sensors replaced right? there is a catalyst efficiency test that I perform but it involves two people, scan tool, and a 15 min test drive. Cats are quite expensive to replace so take it to someone who can give you a definitive answer before replacement.
Professional BMW service
-Dallas dealer service alternative experts-
silverslider is offline   Reply With Quote
Old 07-26-2008, 07:41 AM   #14
security6
My Ride: 2001 330i
Thanks for the help. I ordered a scan tool that will give me live readings from the individual O2 sensors, so I guess I need to wait to get it before I do anything else. Luckily, I have a long time before I need to get emissions done on my car.
Old 11-20-2014, 11:57 AM   #15
Delineation
My Ride: JapanRot 05 325i
Was this issue solved?
They said I could become anything, so I became a BMW owner.
Delineation is offline   Reply With Quote
Old 11-20-2014, 12:00 PM   #16
jfoj
My Ride: 330CiC, M5, X5
Epic revival of a 6 year old thread!!!!
Doubt you will get a reply.
Want to learn about P0420/P0430 and catalytic converters, read this thread - http://forum.e46fanatics.com/showthr...205&highlight=
I PMed the OP and he is thinking of trading the car in rather than taking any action!
Old 11-20-2014, 12:17 PM   #17
daniel_f.
My Ride: 330iC
Im still searching someone with that particular fault and an obd cable
Im currently at baby vacancy!
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 11-20-2014, 01:49 PM   #18
jfoj
You do not need an OBD cable, you need a smart phone App and interface for less than $30.
Old 11-20-2014, 03:57 PM   #19
Delineation
Thanks for the heads up on this thread. I'm committed to solving this. I'll subscribe to it and read it.
Old 11-21-2014, 12:44 AM   #20
daniel_f.
My Ride: 330iC
You cant flash a tune with on ordinary smartphone!
Siemens MS42 wiki!
Siemens MS43 wiki!
