Thread Tools Search this Thread Rating: Thread Rating: 83 votes, 4.81 average. Display Modes
Old 08-06-2011, 04:41 PM   #601
-Ross-
My Ride: Jeep JK/Yamaha FZ1
bump
Originally Posted by NFRs2000nyc View Post
Shut up and drink your snow from your plastic cup you hungry homeless homosexual.
-Ross- is offline   Reply With Quote
Old 08-06-2011, 08:25 PM   #602
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Originally Posted by RossGuy View Post
bump
kpeng no like noobs anymore
mods love noobs
Also...there's the 'search' function, with a stickied thread on how to use it. And, if this thread is stickied, then I think my Furrie thread should be too.
If I'm taking advice from people on the Internet, I don't want it from someone that has a beagle on appendage, you know what I mean?
Upcoming comedy shows: Comic Strip Live, May 12, 6 p.m. & Greenwich Village Comedy Club May 20, 6 p.m. See Facebook for other shows and PM me if you can make one.
dmax on Facebook
Mangofy your E46!
Old 10-24-2011, 10:37 AM   #603
kpeng
Banned User
My Ride: E46 330 and E30 325
bumping to inject a little intelligence into the forum, and take a break from crappy plasti-dip cars and neon wheels.
kpeng is offline   Reply With Quote
Old 10-24-2011, 11:24 AM   #604
HyeWarrior
My Ride: '03 325i --> '13 GTI
<3
Wow
So Amaze
Much Torque Steer
Such FWDoge
HyeWarrior is offline   Reply With Quote
Old 10-24-2011, 11:50 AM   #605
Ivanhoe
My Ride: BMW 330 xi 2005
Ivanhoe is offline   Reply With Quote
Old 10-24-2011, 12:06 PM   #606
Drew@Swift Motorworks
Past Site Sponsor
My Ride: Scooty Puff Jr
you should grammar check yo sig. It's usually best to not have poor grammar distract from your point if you are trying to make some profound statement.
Drew@Swift Motorworks is offline   Reply With Quote
Old 10-24-2011, 12:07 PM   #607
325inthe510
My Ride: 152ci of madness
Awesome guide! Really helpful for us new guys
325inthe510 is offline   Reply With Quote
Old 12-04-2011, 08:44 PM   #608
Stinger9
My Ride: '04 330Ci
Exceptionally Teutonic!
Narrative for each appreciated.
I haven't seen a real definitive plan laid out for the maintenance of our cars. Because of this, there has been way too many redundant threads on the issue of fluid changes, belts, pulleys, etc. So what I'm going to do here today is provide a bit of an idea of what my maintenance plan is, and just give everyone an idea of what kind of steps they should follow.
I want you to begin by just ignoring anything and everything BMW dealers have ever told you about maintenance. The lifetime tranny fluid claims, the 15K oil changes, the 100K sparkplugs...all a bunch of lies and ignorance. BMW does this for two reasons; A) To save them money when you're under warranty and B) To make your cars fall apart after the 50,000 mile mark (aka when warranty is over), and then they make their money by repairing your gunked up tranny and engine.
FOR ALL OEM PARTS, I RECOMMEND BUYING FROM TISCHER BMW
http://www.getbmwparts.com
FOR INDEPENDENT SHOPS, I RECOMMEND FINDING ONE ON:
http://www.bimrs.org
I must say though, this is nothing definitive and is merely the plan I follow. I think it's a pretty good schedule, and is merely here as a guide. Your driving style and conditions may vary. I am no professional, just an educated fanatic. If you have any concerns or technical problems, consult a trained professional like Seth @ J&B Eurotech Auto Service (one of our sponsors). His username is jbeurotech.
Oil Change - Every 6,000-7,000 miles
Now you might ask, why? Why not 15,000 mile oil changes like BMW recommends? Fact is, most synthetic oils will last that long, however...your oil filter won't. It's made of paper and will fall apart and let harmful little yuckies into your engine...and that's no good. I stick with Mobil 1 oil 5w30. However, you can run anything from OEM BMW Oil, to Castrol, Royal Purple, Amsoil, and Redline. Just make sure it is SYNTHETIC. Use only OEM oil filters (part #: 11 42 7 512 300)
Spark Plugs - Every 50,000-60,000 miles
I know BMW says you can go 100,000 miles without changing the plugs...and you probably can...if you baby the hell out of your car. Chances are, if you're on this site, you don't. I've swapped out my plugs at 50,000 miles, and they were corroded to hell. Stick with OEM plugs, there's absolutely no reason to deviate from them because there's nothing else out there that will yield any sort of gain or advantage (please stay away from the gimmick Pulsestar plugs). OEM plugs are NGK Laser Platinums, available at any local auto parts store. They are the BKR6EQUP, and is stock #: 3199 in most auto part places. Make sure you get some anti-seize too.
Air Filter - Every 10,000 miles
If you have a conventional airbox, then replace the filter with an OEM one. If you have a foam/cotton filter, then clean it. This is one of the most basic things you can do to maintain the car, yet most people overlook it. Filters get crude on them real fast and not only restrict airflow, but lets crap get sucked into your engine. All pretty common sense.
Fuel Filter - Every 30,000 to 40,000 miles
These get clogged up and you end up losing power. In some cases, it might even cause difficulties at startup. It might be overkill to change every 30,000 but it's inexpensive, and keeps your car running well. Very neglected part. Buy OEM.
Valve Cover Gasket - Before 60,000 miles
The valve cover gasket on our cars is known to go bye bye and let precious oil seep out into the engine bay or even worse, your spark plugs. This will cause misfires and all sorts of problems. At the very first sign of leakage, I had it changed out. Reading around and talking to people, most have had it fail around 60,000 miles or so. If you're past that point and haven't done it yet, do yourself a favor and do it asap.
Belts/Pulleys - Every 50,000 miles (or as needed)
You would be surprised at how easily the belts on our cars come apart. It's not much to maintain, and can prevent a potential catastrophic event. As a rule of thumb, I inspect the belts every time I do an oil change. If they have any premature wear, they're getting swapped out. But every 50,000 miles, they go bye bye anyways. Pulleys generally aren't an issue, but listen at startup, if you hear a loud whistling/whining noise from the front of the car, chances are that you'll need a new tensioner pulley. No worries, they go bad all the time, usually run around 50,000 miles.
Coolant - Every 2 years, check levels monthly
I usually use OEM BMW coolant mixed 50/50 with water every two years. Keeps the cooling system fresh and free of corrosion. I do open up the radiator cap every month though and add water if necessary.
Water Pump - Before 100,000 miles
The water pump on our cars is prone to failure because BMW used a cheap plastic propeller. On the later cars, I believe they switched to metal, but I still wouldn't chance it. I've yet to do this personally, because I'm still only around 70,000 miles. However, when the time comes, I will be switching it out for a Stewart High-Flow Water Pump from Turner. Also a good time to check and change your coolant system hoses.
Power Steering Fluid - Every 50,000 miles
Very neglected, most people wouldn't even bother. In fact, I know people who have ran on the same fluid for over 100,000 miles. It may or may not make a difference, but it's very inexpensive to do, and why not give your baby some fresh fluid? Our cars take ATF fluid instead of Power Steering Fluid. I used the Royal Purple ATF, but Mobil 1 will do too. Don't get the cheap stuff, make sure it's Dextron III approved. I've read instances where people have gone over 200,000 miles on the original rack & pinion/power steering pump by changing their fluid on a regular basis. You can bleed it by opening up a line, but I just use the turkey baster technique.
Brake Fluid - Every year (or before an AutoX)
When I bled my brake system, the brake fluid was disgusting and completely black. I recommend using ATE Super Bluid. If you brake hard or just over time, your brake fluid gets cooked. That's why I do it every year or before any AutoX event. Stopping power is important.
Brakes - As needed
I check my brakes every so often and make sure they have life in them. Like I just mentioned, it is super important and must be taken care of. I check if there is a lip on the rotors, and see how much pad I have left by taking the wheel off and looking at the caliper. When it comes time to replace the brakes, make sure to change pads/rotors at the same time. Reason being, if you change one and not the other, you run the risk of destroying the new part. Lips on old rotors can tear up a pad, and pads worn down to the metal will destroy new rotors. It's common sense.
Differential Fluid - Every 30,000 miles
I use Redline 75w-90 every 30,000 miles. You will need a little under 2 quarts, so you'll need two bottles.
Transmission Fluid - Every 30,000 miles & before 60,000 miles
This is for Steptronic transmissions ONLY. I have an auto, so I can't speak for the manual trannies. BMW says this is lifetime fluid, but that's a crock of horsepoo. I changed my step fluid before 60,000 miles. Reason being, that seems to be the general consensus "threshold" for step tranny failure. There have been many reports of people going to change their auto tranny fluid after 60,000 miles, and having instant failure. The reason being, by that time, sludge has built up, and putting fresh fluid in it will dislodge it and cause the tranny to fail. Do it before 60,000 miles, and you should be ok. After that, every 30,000 miles should be good. Again, this might seem like over kill, but as sensitive as our auto trannies are, it cannot hurt. I recommend Redline fluids once again, and changing the transmission gasket while you're at it.
Anyways, I hope this was of help. Again, this is what I do to my car, and what you choose to do to yours may be different. This is purely here as a guide. And like always, just check your car regularly and make sure everything's in good running shape. I've followed this maintenance schedule thus far, and plan on continuing to do so. I haven't had any issues with the car at all, and everything has been running smoothly and as they should. So I must be doing something right...right?
Old 12-04-2011, 09:02 PM   #609
tracerit
My Ride: 04 330Ci ZHP 6MT
really great writeup. what about bushings? should all bushings be replaced by 100k?
tracerit is offline   Reply With Quote
Old 12-04-2011, 09:24 PM   #610
dmax
dmax's Avatar
No.
Also, some of the mileage recommendations seem a little off.
Oil can go longer safely--OE Mann filters won't fall apart on you.
Also, PS fluid at 50K seems like too long and brake fluid every year seems too short.
The bmw coolant bottle now says 3 years on it I think...so 2 years is a little short too.
The items themselves are great, but doublecheck the intervals for some of these things.
Belts, I'd do before 50K miles...I've seen alligatoring on mine after 2 years...and had a belt fail on my e36...so maybe I'm too cautious about them.
dmax on Facebook
Mangofy your E46!
Old 12-04-2011, 09:48 PM   #611
TX78666
My Ride: 330i ZHP, N55 135i
No.
Agree. Also, if that is a concern, why not just change the filter at 7,500 and the filter and oil at 15,000? The filter is like $6 and takes 2 minutes to change. No reason to dump all that synthetic oil for that.
Because... Grocery Getter.
TX78666 is offline   Reply With Quote
Old 12-04-2011, 09:52 PM   #612
Saintluk2
My Ride: 2000 323i sedan
i recently replaced my factory filter at 180,000 miles and it leaked crystal clear gas. I think fuel filters are just a precaution against legal action by BMW against risky owners. Either that or my filter element is completely disintegrated by that mileage. LOL
Saintluk2 is offline   Reply With Quote
Old 12-04-2011, 09:58 PM   #613
TX78666
I just replaced mine at 145,000. I didn't think to evaluate the gas coming out of it, so I can't comment. It was definitely failing, but that could have been the pressure regulator. Either way, it made it 80% of the way to 180,000. Earlier replacement could also be a precaution against the bad experience of being stuck on the side of the road, like we were.
Old 12-04-2011, 10:02 PM   #614
Stinger9
My Ride: '04 330Ci
I'd agree with you after hacksawing open my filter
at 80K miles to find filter paper looking almost new. Except that I talked with my mechanic at the dealer who told me he's seen filters clogged up with gunk. I think it's just the luck of the draw in terms of getting one horrible tank of gas.
I drive cross country mostly and fill with the cheapest premium I can find in each town. Lot's of indy's.
So you could say I could have done without a filter, but I'd not ever remove mine to run the next 80K.
Old 12-07-2011, 08:05 AM   #615
findmadhav
My Ride: 2000 323I
Brakes - As needed
Great writeup and guide! Thanks!
findmadhav is offline   Reply With Quote
Old 12-07-2011, 09:36 AM   #616
Bostonbeast
My Ride: 2009 Yamaha R6
Sounds like a good idea. Does anyone else do this? I may try it.
Bostonbeast is offline   Reply With Quote
Old 12-07-2011, 11:13 AM   #617
kpeng
Banned User
No.
Old 12-07-2011, 12:40 PM   #618
rcsummers
My Ride: M3
saved.
"RICH"
My Build Thread
EURO.TECHNIKS
- Status Gruppe Tuning - Broadway Static - Recaro - DTM Fiberwerkz - AutoCouture Motoring -
Instagram: @summers_e46_m3
Twitter: @rcsummers0506
Xbox One: MisterMeisterM3
rcsummers is offline   Reply With Quote
Old 12-07-2011, 12:50 PM   #619
Rubenk
My Ride: M35A2
No.
The amount of money saved in the long run isnt worth the risk of losing an engine, especially one as expensive as a BMW engine...
Rubenk is offline   Reply With Quote
Old 12-08-2011, 10:19 PM   #620
hodorsail
My Ride: 330xi
idea on labor
just read every post...
For those of us that cannot do all of our own work....what labor hrs do you feel an indy should charge for each piece on the orig post?
I personally do my own brakes and rotors which is a huge savings but am a bit afraid to do belts, pulley's, expansion tank, thermostat, water pump. As far as fluid I feel it's a pain in the ass to deal with the old fluids, and other troubles that go with it. My BMW indy does my oil for $80. It's $50 in oil and filter if you shop well....so to save $30 bucks, just isnt' worth it to me.
My indy charges $100 an hr for labor so if I know what hrs you all feel an indy can do "the list" in I can then budget my preventative maintenance wisely. They even let me bring my own parts.
thx
hodorsail is offline   Reply With Quote
maintenance, propaganda, tool
