Thread Tools Search this Thread Rating: Thread Rating: 83 votes, 4.81 average. Display Modes
Old 10-13-2012, 08:35 AM   #641
Stinger9
My Ride: '04 330Ci
Next think about your fuel pump. How old is it?
And then a fuel filter just in case you got it clogged.
Old 10-13-2012, 10:33 AM   #642
smacera
My Ride: Bmw 318
Thanks Stinger for the reply, I haven't thought about the fuel pump as they can be fairly costly. I don't think it's been changed by a previous owner so it would be almost 12 years old. I changed the fuel filter last week but hasn't made a difference. What else can be causing these very low revs, I'd love to have a solution, any other ideas please.
Thanks so much
smacera is offline   Reply With Quote
Old 10-13-2012, 11:02 AM   #643
Stinger9
My Ride: '04 330Ci
You are a prime candidate for a new pump.
Too bad you can't get US pricing as it's only $120 here and easy to DIY.
You could do a pressure and volume test to test the pump, or better to just replace. What does it cost there?
Old 10-13-2012, 11:42 AM   #644
smacera
My Ride: Bmw 318
Pricing of the fuel pumps here new on ebay is $200 or used $70. Do you think this low rev and stalling when cold is related to the spark plugs, the engine computer hasn't given any codes for the plugs or the fuel pump??
Thanks again.
Old 10-13-2012, 11:53 AM   #645
Stinger9
My Ride: '04 330Ci
You will get no codes from a dying fuel pump. Further corroborates my theory.
It is a mechanical failure, not electrical.
Don't even think about an off brand pump. Siemans VDO is what you want.
If it is the pump, you could be stranded somewhere soon.
Spark plugs would have to be complete toast to cause this problem.
Old 10-14-2012, 04:06 AM   #646
smacera
My Ride: Bmw 318
Thanks Stinger for your reply, I'll keep the fuel pump in mind but like to try some other options first as they can be expensive. What about the Idle control clean or CVV?
I just really want to get rid of this rough idle and stalling.
I've looked up CVV and read a few articles and I'm still trying to diagnose if it's the CVV. A few say the following to test:
Paper (or a plastic freezer baggy) over the warm-engine oil-filler opening as a visual vacuum test (1)
Should move inward one inch or less
Some say it should improve the idle if the CCV is bad (1)
Some say you can feel the vacuum by hand (1)
Inflating balloon (or glove) over the dipstick as a visual crankcase pressure test (1) (2)
I've tried placing the paper over the oil filler when in idle, but lots of air comes out of the opening, blowing the paper away, is this normal or should I take it as a bad sign? Before I can lift the dipstick fully out, it losses rpms and nearly stalls so I'm not sure if air is going in or out of the dipstick.
Any other ways to see if it is the CVV.
I've look at all the nearby hoses and they all look in pretty good shape, some even look new. I've had the car 1 year, done 7k this year, bought with 77k miles.
Old 10-14-2012, 09:21 AM   #647
Stinger9
My Ride: '04 330Ci
def clean out that ICV is you're on the cheap. your labor is free. mine was only slightly dirty after 88K miles. cleaning did not make a difference.
not that well versed in CVV test as I just replaced mine with all four hoses 'cause I like to run new parts.
can search youtube and plenty here to find what you need.
Old 10-15-2012, 11:36 AM   #648
smacera
My Ride: Bmw 318
Hi Stinger
Thanks so much for your replies, you've been really helpful.
One last thing I forgot to mention, is that I've had a coolant leak ever since I bought the car just over a year ago, that I've never done anything about as it's so small. If I fill the coolant up to the max it takes 2 months for it to leak out, could this coolant leak affect this rough idling problem and stalling?
Thanks again
Simon
Old 10-15-2012, 01:56 PM   #649
Stinger9
My Ride: '04 330Ci
I'm no expert, but I've not come across anything that might give you a rough idle from a slo coolant leak.
Search for rough idle on this board.
Don't know how you're going to find that coolant leak.
Good place to start reading for rough idle:
http://forum.e46fanatics.com/showthr...h+idle&page=20
Old 10-17-2012, 12:50 PM   #650
smacera
My Ride: Bmw 318
Hi Stinger, glad to hear it's not the Coolant leak. I've just had the car scanned twice by a mechanic and he says it's the Camshaft Position Sensor even though I had a new one put in a month ago, maybe it's faulty, but I'm not convinced???? Any other ideas?
Old 10-17-2012, 12:54 PM   #651
Stinger9
My Ride: '04 330Ci
Did you use an original equipment BMW CPS?
This is critical as any other has a high incidence of not working correctly.
Old 10-17-2012, 01:10 PM   #652
smacera
My Ride: Bmw 318
No I bought it off Ebay lol. Most of them seem to be around $15. I'm trying to get a replacement.
Old 10-17-2012, 01:22 PM   #653
Wh33lhop
My Ride: douchemobile
Sounds like that's your problem.
Wh33lhop is offline   Reply With Quote
Old 10-17-2012, 01:24 PM   #654
darksideracer69
My Ride: 01 325ci
Waste of 15$
Sent from my SGH-T959 using Bimmer App
IMAG02051
Old 10-17-2012, 01:27 PM   #655
Alex323Ci
My Ride: M3 & 323Ci (sold)
yep there has been a high number of aftermarket CPS that don't work correctly. so this certainly could be the issue.
also when you say scanned the codes twice. hope this means he cleared and scanned again? just making sure the CPS code isn't a remnant code from before.
Old 10-17-2012, 04:08 PM   #656
Stinger9
My Ride: '04 330Ci
Spent more than $100 each to replace mine.
Not just because I like to spend a lot of money.
Old 10-17-2012, 04:16 PM   #657
GhostFlame
My Ride: E46 Sedan
I wonder if kpeng lost any weight by now..
GhostFlame is offline   Reply With Quote
Old 02-14-2013, 12:09 PM   #658
kpeng
Banned User
My Ride: E46 330 and E30 325
Still lovable jello of sex.
kpeng is offline   Reply With Quote
Old 05-04-2013, 07:12 AM   #659
smacera
My Ride: Bmw 318
I'm still having the same problem, now at 91k but been rough idle since 80K, I've changed everything that the codes suggest but still getting rough idle, drives smooth above 5Mph. It's an auto but will stall if it comes to a stop. I've changed both O2 sensors, MAF sensor, fuel filter, Cam shaft sensor, Air Filter and now just had Transmission filter and fluid drained but still the same. Also, I can't see any air leaks from the hoses. Another guy mentioned he changed more than these items and he's still got rough idle but was told the crankcase breatherhose for the CVV was a little blocked with a buildup of oil, said he changed it and car works like new. Does anybody think that this could be my problem? My photos below on my car shows some build up of Mayo, does this relate to the CVV or Crankcase and should I be worried?
ID:	503774   Click image for larger version
Old 05-09-2013, 10:32 PM   #660
latitude39
My Ride: 2002 325xi (163k)
"both" O2 sensors? On the 6-cylinder engines there are 4 O2 sensors, the pre-cats being the most important for performance. Mayo in CCV: my guess is to replace CCV and hoses, which will be brittle, if not cracked, by now. How about spark plugs? Which camshaft sensor? The intake seems to be the most critical.
latitude39 is offline   Reply With Quote
maintenance, propaganda, tool
