Rating:
Display Modes |
#81 |
Banned User
My Ride: E46 330 and E30 325
Daddy MO, You will be fine with the Mann or Mahle oil filters, they are basically OEM.
#82 |
My Ride: ZHP Custom Stage 3.5
What if your engine has been treated with the 15k mile oil change for the first 45k miles of it life? Is there any thing u can do to clean up the gunk inside the motor? I am planning on changing to Mobil 1 0w-40 every 5k.
Thanks Anthony
..::|TrippinBimmer's Boost Build with Cool Parts|::.. 4**whp/3**tq SAE Corrected |
#83 |
Banned User
Have you tried Seafoam? Use some before each oil change.
#84 |
Nice Ken,
Just to add that if you're doing your own maintenance there's plenty more you should check, some frequently, some less often, a quick browse through the Inspection 1 and 2 schedules will probably highlight some items that may otherwise have been ignored by the DIYer. Don't be too daunted, mostly it just involves visual inspection, that is, just looking at things. http://www.pelicanparts.com/bmw/tech...check_list.htm A load more useful info here: http://www.bimmerfest.com/wiki/index.php/BMW_E46 Not forgetting our very own superb stickied (all newbs should read before asking questions): http://forum.e46fanatics.com/showthread.php?t=320965 Great references for finding part numbers here: http://www.realoem.com/bmw/ http://bmwfans.info/original/
#85 |
Just dump it in the crankcase right?
#86 |
hahhaa, Ken that looks a lot like Mike Millers write up.
![]() you left out the radiator and expansion tank, and thermostat. VERY IMPORTANT i got 155k mile sout of my oe radiator, i just changed it last saturday. im not sure if i had the oe expansion tank i have 155k miles + on my oem vlve cover gasket and not one leak. i do have a leaking ps hose that runs from the res to the pump. ps pumps do go bad, but with flushes like you say, you should last. clutches tend to go at around 15k, mine has a slight slip right now, has had it since around 140k. control arms, look for about 60-70k out of the stock ones, before the call joints go to sh1t. then then CAB. diff bushings on aggressively driven stick shifts are usually good for about 130k BMWs 1st wp update was to a metal, alu alloy looking pump, they have now switched back to a plastic type pump. i have a alu wp that i took out last saturday and it is in immaculate condition, no play no rust except on the pulley side, hard to believe i got almost 80k miles out of it. the one i replaced it with was a heavier one, much bigger impellers about twice the OEs width, bavauto sells it for about $45
#87 | |
wrong, they are not OE. but approved OE suppliers. mann filters come from 2 places mexico and germany, ive heard quality control on the mexican ones are not as good. i just bought a box of 10 mahle filters and called it a day. mahle filters are 100% germany i believe i payed like $60 shipped for the box. |
#88 |
you shouldnt have that much gunk at 45k miles, just doing 6-7k oil changes from hear on out run good gas, and air filters, and you will be fine.
#89 |
G-cool, G-smooth, G-style
the link to replacing the power steering fluid also shows how to clean maf sensor.
how often does the maf sensor have to be cleaned? |
#90 |
2005 Acura TL A-Spec
2004 325Ci SMG M-tech II (Sold and got 2005 Acura TL A-Spec) :-( 2002 530i Sport 1997 Mercedes Benz C280 Sport (Sold and got 2002 530i Sport!) :-) 2007 Yamaha VX Cruiser (WaveRunner) see my garage for pics How a Rogue IKON should look on a M-Tech II Coupe http://forum.e46fanatics.com/showthread.php?t=537372 |
#91 | |
I'm no where near 70,000mi but I'm just wondering..
#92 | |
Banned User
#93 |
how much seafoam should i use to treat before each oil change and where do you dump it in at...ive done it for the fuel system through the gas tank....??? TrippinBimmer mentioned putting it in the crankcase???
#94 |
comin through as always!!!
good Shi7 boy
#95 |
kpeng,
i always though we should use Mobil One 0W40 European Cars for our cars. It is the only mobil one oil approved by bmw on the back of the container. it is what I have been using. |
#96 |
Nothing wrong with that. That's exactly what BMW say you should be using.
#97 |
Banned User
I would put a 1/2 in the crank, and 1/2 through a vacuum line (usually the brake booster line)
#98 | |
#99 |
Location: Tis quite a statement. Where do you live - where do we all live? in our minds? our souls? our bodies?
My Ride: She aint much 330ci
nice kpeng - the mods should be so happy to have such a stellar and upstanding forum member on the board
#100 | |
My Ride: Has blue lights
http://forum.e46fanatics.com/showthr...980&highlight= Save your $$$ on the Seafoam, you probably won't need it. If you do decide to use it, be careful, it's a very aggressive cleaner. Change your oil soon after it's use. Aggressive cleaners can do more harm than good if used too much. |
| Tags |
| maintenance, propaganda, tool |
