Thread Tools Search this Thread Rating: Thread Rating: 83 votes, 4.81 average. Display Modes
Old 07-29-2008, 08:36 PM   #101
shortyb
My Ride: Has blue lights
Originally Posted by snikwad View Post
you shouldnt have that much gunk at 45k miles, just doing 6-7k oil changes from hear on out run good gas, and air filters, and you will be fine.
Sound advice, go with it.
shortyb is offline   Reply With Quote
Old 07-29-2008, 08:40 PM   #102
4ngie
4ngie's Avatar
My Ride: Chrissspyy
Great thread, Ken
4ngiefest VII - 10/5/2013
4ngie likes this.
4ngie is offline   Reply With Quote
Old 07-29-2008, 08:48 PM   #103
Daddy MO
My Ride: e30/K5 Blazer/Xterra
How bout you make a thread about "how to walk on water"!!!
Thanks to: Lubrify.com / TOMAS Sport Tuning / BRRacing / Craftwerx Concepts / I/O Port Racing Supplies / AGUND1S Tire
Daddy MO is offline   Reply With Quote
Old 07-29-2008, 09:46 PM   #104
firstbm1
My Ride: 02' 330ci
firstbm1 is offline   Reply With Quote
Old 07-29-2008, 11:16 PM   #105
eee4666
eee4666's Avatar
My Ride: Sold
Awesome thread Ken .
I have 66,872 miles on my 02 step. I'd be "risking it" if I were to change out the tranny fluid huh?
eee4666 is offline   Reply With Quote
Old 07-29-2008, 11:58 PM   #106
BM-MAN
My Ride: Hot 3 coupe
Send a message via MSN to BM-MAN
Great!!! Thanks a lot for this.
BM-MAN is offline   Reply With Quote
Old 07-30-2008, 02:58 PM   #107
kpeng
Banned User
My Ride: E46 330 and E30 325
You should still be ok. Do it soon though!
kpeng is offline   Reply With Quote
Old 07-30-2008, 03:17 PM   #108
Bartacus
My Ride: 2002 320i Sedan
FANTASTIC thread!! Ken strikes gold again. Ken lad, you get my vote for "best E46Fanatic EVER"!
I'm still kicking myself for never touching my tranny fluid. 2002 320i sedan, 207,000KMs, no fluid changes, daily driven year round in Canadian winters from hell, and not one tranny issue......yet.
Bart
Bartacus is online now   Reply With Quote
Old 07-30-2008, 03:21 PM   #109
Eduardo1971
Eduardo1971's Avatar
My Ride: 2004 330i ZHP
Very informative. Thanks!
Fight on!
Eduardo1971 is offline   Reply With Quote
Old 07-30-2008, 03:36 PM   #110
djhenry
My Ride: 2001 325i
Send a message via AIM to djhenry
awesome advice, thanks ken!
djhenry is offline   Reply With Quote
Old 07-30-2008, 03:49 PM   #111
SeanC
My Ride: 330i
AFAIK, you need 2 qt. for the diff when filling it up while the diff is still in the car due to the loss in the pipes, etc... If the diff is out you only need to pour down 1 qt.
Nice thread though!
Black Sapphire MetallicNatural BrownSilver Cube e46 330i ZHP/6MT - Sold
HellrotDove Grey e36///M3 - RIP
Alpine WhiteTanSand High Gloss e46 330i SlickTop/5MT - Sold
Black Sapphire MetallicNevada BrownDark Bamboo e70 X5 xDrive4.8
Alpine WhiteCoral RedAluminum f30 328i Sportline/6MT
SeanC is offline   Reply With Quote
Old 07-30-2008, 07:40 PM   #112
kpeng
Banned User
Thanks cngzsn!
Old 07-30-2008, 09:16 PM   #113
DJ Reminisce
My Ride: Knows Dubstep SUCKS
Not sure if this was mentioned already....
But where can I find a list of all the preventative maintenance I should do to my bushings and anything else around the 60,000 mile mark?
I have a copy of the Inspection II, but dont think it addresses what Im after.....any help would be greatly appreciated
Dinan CAI_Stage II_3.46 Dif
OEM CF Strut Bar_Eibach Sportline_GC Konis
OEM Gloss Grills_H&R Spacers_Clubsport Sills_Painted Splitters
Amber LED Corners/6k HID Fogs/LED Interior_Shadow Emblems
500W_RE Audio_Hertz Components
DJ Reminisce is offline   Reply With Quote
Old 07-30-2008, 09:39 PM   #114
xArmyPilot
My Ride: '01 330ci & '09 M5
Great thread, Kpeng ....I can especially attest to the fuel filter maintenance - Cheap, EZ and effective.
"Just because it has 4 doors don't mean it can't haul a$$"
xArmyPilot is offline   Reply With Quote
Old 07-31-2008, 12:09 PM   #115
kpeng
Banned User
Bushings don't really have a set interval. You can just check on them and replace as needed. Obviously, if you're lowered, they will wear a lot faster.
To check your front control arm bushings:
Have a friend stand outside your car and watch the front wheels, get in the car, put it into gear and let it coast forward. Hit the brakes for a second and have your friend tell you if he/she sees the front wheels stutter and jiggle around each time you hit the brakes. If it does, you need FCABs. You can switch places if you don't trust your friend.
To check your rear trailing arm bushings:
You can just look at them and see if there is any separation. Or if you're noticing that the rear is kicking out a bit more and being unstable around corners. Chances are, you'll need RTABs. Not sure how long they last when you lower a car, but about 25,000 miles after I lowered my car, they gave out. I replaced them with Meyle HDs with the Turner Motorsport Limiter Kit.
As far as the diff bushings, tranny bushings, I would replace them if you feel any problems. There really is no set time for these either. It depends on how you drive.
Old 07-31-2008, 12:24 PM   #116
Snik
Snik's Avatar
My Ride: IR M3 Vert.
the way most shops check the FCAB, raise the front wheels and rock the wheel, if you have play in the wheel check tie-rods 1st, if tie-rods have no play left to right, go under the car and grab the CA and rock them, watch the CAB and look for play in the bushing. if none, then you need ball joints. if you have a shot CAB, its safe to assume you need CAB and ball joints.
Do you ride a sportbike?
Old 07-31-2008, 01:07 PM   #117
DJ Reminisce
Im not lowered, and dont plan on ever lowering my car, any ideas when I may need to change these items? Should I stick with OEM or go aftermarket? Any suggestions?
What about shock mounts, any other bushings?
Thanks!!!
Old 07-31-2008, 01:24 PM   #118
SW222
Banned User
My Ride: is silver and slow.
Hey Ken, I always thought that you were a jerk from reading all your flamming posts towards ppl on here. At one point, I even wanted to respond and bash you back to defend and avenge your victims, lol. But I'm glad that I didn't. I came to realized that you are a very smart and informative person with great knowledge, from all your helpful posts. A lot of folks on here respect and appreciate your efforts, and so do I now. Would you mind if I PM you in the future for help and advices? I know, I know, I'll make sure to do a Very Thorough Search on my car problems BEFORE I contact you for pointers, haha. Cuz we all know Kpeng hate nooblets with a passion! =)
SW222 is offline   Reply With Quote
Old 07-31-2008, 01:28 PM   #119
pinoycowboy
My Ride: VW GLI & Passat TDI
Send a message via ICQ to pinoycowboy Send a message via AIM to pinoycowboy
exactly what i've been looking for, thanks ken
-dale
e46 SOLD :(
pinoycowboy is offline   Reply With Quote
Old 07-31-2008, 01:44 PM   #120
kpeng
Banned User
Thanks Simon. Sure, you can PM me whenever you like. I get a few every day, lol. I never flame anyone who doesn't deserve it.
maintenance, propaganda, tool
