Thread Tools Search this Thread Rating: Thread Rating: 55 votes, 4.98 average. Display Modes
Old 06-18-2012, 10:24 AM   #301
pipo1123
My Ride: 2004 bmw 330ci
Well now that i got my AE working my next issue is my drl i want them off since it is yellow and doesnt look good. i dont want to pay 100 or so. ive been searching and discovered a 1.4 scanner that can do the trick but i already have CReader vi will it do the trick? Or this is my only choice http://www.eobd2.com/service/detail.asp?id=39
pipo1123 is offline   Reply With Quote
Old 06-26-2012, 01:14 AM   #302
gavi
My Ride: BMW 330Ci sport 6MT
I think I just broke my bi-xenon bulb It's stuck, can't remove, please help!!!
I was installing angel eyes, and couldn't put xenon back, I think I broke the bulb, help needed!!!
gavi is offline   Reply With Quote
Old 07-04-2012, 06:51 PM   #303
gavi
I did it too, thanks!
Name:	my BMW 330 Ci.jpg
Old 07-18-2012, 02:30 AM   #304
DeceptiKon
My Ride: 2004 330ci E46 Coupe
So I installed the AE's. I feel like one of my ds2 bulbs is illuminating rather yellow. I don't have that xenon white. Anyone have an idea why? I might be tripping. Maybe the 6k AE's are making it look dimmer. But I feel like something is not right.
Sent from my PC36100 using Bimmer App
DeceptiKon is offline   Reply With Quote
Old 07-18-2012, 03:05 PM   #305
sillieidiot
My Ride: '06 AW 330ci
i'd check your connections again. could be something isn't secure
Old 07-18-2012, 04:26 PM   #306
DeceptiKon
I was thinking the ballast on the bottom wasn't plugged in all the way.but I'm assuming if it wasn't then the bulb would not even light up. Correct?
Old 08-13-2012, 03:38 AM   #307
gavi
Thanks for DIY. This was a great job, I have finished long time ago, I had no time to post pics. Here you go.
Thanks again
ID:	464776   Click image for larger version
ID:	464777   Click image for larger version
ID:	464778   Click image for larger version
A BMW can't take you as far as a diploma.
Joyce Meyer
Old 08-13-2012, 03:43 AM   #308
gavi
Sorry I just realize that non of my AE's caould be visible on the previous post, so this one is with an old front bumper
Joyce Meyer
Old 08-13-2012, 10:17 AM   #309
Glidde8
My Ride: 2004 325CI
Finally did them! Took a long time, hardest part was removing my passenger side headlight because it got stuck!
ID:	464803   Click image for larger version
Glidde8 is offline   Reply With Quote
Old 04-27-2013, 02:54 PM   #310
mlouie2000
My Ride: BMW 325 ci
thought I would mention that I used a heat gun/ paint stripper gun. I removed the lens in less than 10 mins so I wouldn`t bother with the `baking` method. You can direct the heat to just the glue and with a couple of flat bladed screwdrivers it will start to come apart and once you get so far you can pull it apart
mlouie2000 is offline   Reply With Quote
Old 05-27-2013, 09:19 PM   #311
fraserp
My Ride: 2006 e46 Cic
LED a/e
great DIY, now after going through the whole thread i have noticed a few mention of LED AE's, but no one has verified if it exist, if they have installed them, if available and where to buy, how they compare to CCFL ect.. could it be that no one has used them, OK, if it is in another thread please let me know, i am thinking of going LED's (if available) -- my ride 2006 330ci vert
fraserp is offline   Reply With Quote
Old 05-27-2013, 09:48 PM   #312
sillieidiot
yes they exist. i've installed a bunch of them. the orions from umnitza are the only LEDs currently on the market. i'd just go with LEDs for reliability. just so you only have to bake it once and be done with it. no need to go back when a ring fails. since it will probably last forever
Old 05-28-2013, 05:30 PM   #313
fraserp
thanks Sillie for that quick response, now i can stert shopping for LED A/E.
Old 05-29-2013, 06:37 AM   #314
Glidde8
My Ride: 2004 325CI
DIY Facelift Coupe Angel Eyes
The AEs I installed are Orion LEDs; you can see a picture a few posts up. They are extremely bright and haven't had any problems so far. When you are 10 feet of closer you can see the individual LEDs but anything further then that thy look like a solid ring. I highly recommend them.
Old 05-30-2013, 11:47 AM   #315
777eThOd*
My Ride: spins too much
and this thread is still alive!!
2007 BMW 335i FBO 6MT - Current
2013 Nissan Nismo 370Z - Current
2004 Non-M Facelift Coupe - SOLD
2006 BMW M3 - SOLD
777eThOd* is offline   Reply With Quote
Old 06-09-2013, 10:07 PM   #316
fraserp
some more details and pics would bee apreciated, as i am a little scared of putting my headlights into a oven. or a video on youtube
Old 07-22-2013, 07:52 PM   #317
bronxbomerss2
My Ride: 05 325CI
Send a message via AIM to bronxbomerss2
can you guys tell me where or which vendor you go your AE from i check modbargains and bimmian but nothing for FL coupe. i don't want the LED i personally don't like the individual led look.
bronxbomerss2 is offline   Reply With Quote
Old 07-23-2013, 02:00 PM   #318
DeceptiKon
I felt the same way and was very hesitant following through with it. (This thread compelled me to suck it up and do it to it as sketch as I felt it was).
Not kidding, after baking and begining to pry open the housing, all I was thinking was "wtf am I doing, I should not be doing this."
Honestly, it's not hard at all and no need to worry about ur headlights while baking (not hot enough) they will be fine. Be cautious of some parts of the headlight such as the part the mounting under the headlight (which u have to remove) clips into.
When the headlight is open, obviously avoid touching projector, and once AE install is complete make sure u have all the screws back in place, use a microfiber cloth make sure ur projector has no smuges. Worse thing u can do is put it all back together and notice u forgot a screw or have fingerprints all over ur projector, tempting u to bake/open it back up. You want to get it right the first time, the more u open it the more the adhesive will wear and before u know it, ur going for a car wash with ur new ASs looking great and u pull out to dry, next thing u notice is a crap load if condensation u have to wait 2 days to dry out. Trust me I know.
Good luck!
Old 07-23-2013, 02:05 PM   #319
DeceptiKon
Umnitza has a set as well. I have Orion v2s. I believe they have different styles. I suggest not going with ccfl (yellow and dull) and do led, they have the v3 or v4s. The number of leds is increased compared to the v2 and the back of the AE is not clear emitting more light. I feel like due to the increased number of leds and the closeness and amount of light being emitted u won't get as drastic of a "dotted" look. They also have preditor which ate thin lines, not sure if led or not.
Hope u find what ur looking for.
Umnitza com
Heard customer service is not the best, but they are a 20 minute drove from me so I usually go there to avoid shipping cost and fir the most part they take care of me.
Sv-concepts is another site to check out.
Old 07-26-2013, 12:41 AM   #320
Nickvjr
My Ride: 2004 330Ci Conv.
Send a message via AIM to Nickvjr Send a message via Yahoo to Nickvjr
While LED AEs do have a higher light output than most CCFLs that doesn't necessarily mean the CCFLs are yellow or dull. Both AEs have their own pluses and minuses. It really depends on the overall look and function that the owner is looking for. Here are my CCFLs side by side with some V2s.
-Nickvjr
2004 BMW 330Ci Convertible
Nickvjr is offline   Reply With Quote
