Thread Tools Search this Thread Rating: Thread Rating: 55 votes, 4.98 average. Display Modes
Old 02-26-2009, 02:34 PM   #161
LeontiyZHP
My Ride: '04 330Ci ZHP
Originally Posted by kaMilave View Post
do i nead 4 the same size(rings)? and whot size are they
Hey, you need 4 of the same size rings.. Not sure the measurement on them, but make sure you get them for "FACELIFT COUPE" Usually 04+ but I guess yours is 03, but it's going to be the same..
E.G. Go to Modbargain.com from the "Application" the select "E46 FACELIFE 2dr Coupe.." There are a lot of companies that sell them, they even have LEDs now, check "Umnitza" website..
Leo
2015 BMW 335i M-sport (BSM)
2014 BMW x3 28i M-sport (BSM)
2004 330Ci ZHP SOLD and very much missed.
DIY Facelift Angel Eyes | AVIC-D3 Install | flickr
LeontiyZHP is offline   Reply With Quote
Old 02-26-2009, 04:42 PM   #162
kaMilave
My Ride: Bmw e46 2003 cabrio
yes bot i want to bay in poland and i nead sizeonly
kaMilave is offline   Reply With Quote
Old 02-27-2009, 01:06 AM   #163
LeontiyZHP
Sorry I wouldn't know the size, try contacting a vendor maybe they will know.. GL
Leo
Old 03-15-2009, 09:48 AM   #164
Phantom_Tulaba
My Ride: pure Hotness
Nice write up OP, looks sweet too!
Werd!
Phantom_Tulaba is offline   Reply With Quote
Old 05-05-2009, 11:27 PM   #165
DSpencer18
My Ride: 2005 BMW 330ci (ZHP)
Send a message via AIM to DSpencer18
I am going to do this for my next mod. What did you use to smoke your corners?
  • Has: - BSW d210 Subs/Amp - iSimple Ipod Integration - Smoked Side Markers - Smoked Reflectors - LED White Interior Lights - Hoen Xenonmatch Fogs - Hardwired Valentine V1 Radar Detector - AVT Ram Air Scoop - BMW Performance Intake - BMW Performance Short Shifter Kit -
    - Lambda Chi Alpha Zeta Phi 1067 and E46Fanatics.com stickers. -
  • DSpencer18 is offline   Reply With Quote
    Old 05-06-2009, 12:35 AM   #166
    LeontiyZHP
    Originally Posted by dspencer18 View Post
    i am going to do this for my next mod. What did you use to smoke your corners?
    Good Luck! Make sure you look through all DIYs so you don't get stuck in the middle of it!
    Originally Posted by leontiyzhp View Post
    ty!
    I got it from the hobby shop. It's the testors spray lacquer: Transparent black window tint. There were some other brands and styles there, like smoke, but i have no idea what it looks like. Gl on doing yours!
    My latest pick of the smoked corner look..
    Leo
    Old 05-06-2009, 01:07 AM   #167
    urbanrebel
    My Ride: Is Being Parted Out
    Um, Leo... I need some smoked corners...
    urbanrebel is offline   Reply With Quote
    Old 05-07-2009, 02:48 PM   #168
    DSpencer18
    so use spray lacquer: Transparent black window tint? Is there anyway I could clean the inside of the casing while i am in there? Because mine looks a little dirty..should I just use soap and water? Thanks, Drew.
    Old 05-07-2009, 02:50 PM   #169
    sillieidiot
    My Ride: '06 AW 330ci
    just go to a hobby shop and ask them for tint spray. they will give you some choices. i use testors.
    Old 06-12-2009, 07:56 AM   #170
    BMWNorway
    My Ride: BMW E46 Coupe
    Does anybody have problems with fog on the inside og the headlights after baking??
    BMWNorway is offline   Reply With Quote
    Old 06-12-2009, 07:54 PM   #171
    LeontiyZHP
    Check your PM
    If I'm correct it would happen if you don't have enough sealant around the headlight housing and the clear lens..
    Leo
    Old 06-14-2009, 03:18 AM   #172
    DBeemerphileWnaB
    My Ride: 04 325i & 00 323Ci
    Is there any reason to run the CCFL Angel Eyes wiring back to the batery post and box in front of the driver when they can just tap into the adjacent 12v daytime running light/headlight?
    DBeemerphileWnaB is offline   Reply With Quote
    Old 06-14-2009, 01:48 PM   #173
    Edison@JleviSW
    1.888.JLEVISW
    Edison@JleviSW's Avatar
    My Ride: BMW Duh
    Depending on the wiring harness you are using, you will need to run the positive to the battery terminal for power. The other wire connected to the ECU is to trigger the power.
    Old 06-14-2009, 04:42 PM   #174
    sillieidiot
    Just depends on how you want it to operate. If you want it to work like the drls, then just use that. That means it will turn off when the headlights come on
    Old 06-29-2009, 04:36 PM   #175
    BMWNorway
    I just installed my Angel Eyes but after connecting the headlight again, the side blinker on the driverside comes on with the parking lights but when I turn on the primary lights it gets turned off. It's not blinking, it's just a little lit. When I turn on the blinker it works as normal. Can anyone see what my problem is?
    I only disconnected the wire and connected it again after mounting the angel eyes. :s
    Old 06-29-2009, 11:27 PM   #176
    DBeemerphileWnaB
    I half-installed my CCFL AE's with one of the pre-made harnesses in my 325i, and wired the relay's trigger to the positive wire for light in the footwell, and attached the ground wires to the relay and the ballasts to a body ground, but did NOT yet install the wire to the power in the empty mystery cavity ("drug box") or the main trigger in the wiring box in front of the driver.
    Needless to say, when I pushed the key to unlock the passenger door, the AE's were working! So either my car is haunted or the relay is putting enpugh power through via the footwell light trigger to power these. It seems kind of ridiculous to hook them to the main battery terminal when they have such a low power requirement (1.4 amps=16 watts).
    Q:Is there an easier-to-access power point near the lights than on the opposite side of the engine compartment? How about for 'Accessory' only 12v power? I still need to wire the AE's in the 323Ci, and just want to have the AE's come on in that car when the key is turned on.
    Old 06-29-2009, 11:33 PM   #177
    sillieidiot
    wth man. this is a thread for install for the facelift coupe. not a thread for questions related to angel eyes.
    db, yes that is normal, hence why i put a small glass fuse in that interior spot as well.
    you can find anything else to use it if you want, but when it comes down to trouble shooting later, it's going to be harder because by going straight to the battery it is its own separate circuit and should not affect anything else (ground troubles are exceptions)
    Old 06-30-2009, 11:29 PM   #178
    Fedor1
    My Ride: 2004 325ci vert
    Thanks for the diy. Very very helpful.
    P1040718
    DSC_1074DSC_0940
    Fedor1 is offline   Reply With Quote
    Old 07-03-2009, 05:09 PM   #179
    konfetaz
    My Ride: e92 335i
    Hello, so still we need put in oven? And i dont understand why? :/ Thank you
    konfetaz is offline   Reply With Quote
    Old 07-03-2009, 06:00 PM   #180
    sillieidiot
    what year car do you have? you need to put in over to melt the glue to open it for our cars.
