Go Back   E46Fanatics > Tuning & Tech > Suspension & Braking
Old 07-31-2008, 03:27 PM   #1
zeshon
My Ride: S/C 2000 328Ci
Exclamation Suspension Quick Reference Thread
Since we finally have a forum for suspension and brakes, it's time to crap it up with threads. First order of business is giving people a place to start. These are just a few things to get the ball rolling. Now that the E46 is a more affordable option for people, the community can only grow. We need quicker access to information so new people don't crap up the forum. This thread is for posting useful links to information about suspensions bother generally, and focused on the E46 chassis.
General Suspension Resources
E46 Suspension Information (Many thanks to JPR)
- Austin
Favorite sponsors
Bavarian Soundwerks | Euro Spec
Mods : Performance : Active Autowerkes Stage 1 C38 • New Subframe and TMS Rear Re-Enforcements • Upgraded VANOS seals • M3 Fuel Baffle • KW V2 • ZHP Control Arms • E60 Short ShifterSound : Bavarian Soundwereks Stage 2 • DICE iPod LinkLooks : Replica M3 Mirrors • Replica M3 Front Bumper • Matte Black Grillz • LED Signals
zeshon is offline   Reply With Quote
Old 08-01-2008, 06:17 PM   #2
kuksul08
My Ride: M3
Send a message via AIM to kuksul08
very nice!
Look at that subtle jet-black coloring. The tasteful thickness of it. Oh my God, it even has a 6mt.
S54 Valve Adjustment Spreadsheet & Info: http://dl.dropbox.com/u/28231781/S54...ent%20info.zip
kuksul08 is offline   Reply With Quote
Old 08-03-2008, 11:24 AM   #3
zeshon
I wish I could edit so I could add more as I go...
- Austin
Favorite sponsors
Old 08-03-2008, 02:48 PM   #4
Arrows
My Ride: 2000 323i.
Send a message via AIM to Arrows Send a message via MSN to Arrows
You can always PM a mod to edit it.
Arrows is offline   Reply With Quote
Old 08-07-2008, 05:46 PM   #5
jpr
My Ride: '99 323i
Swaybar sizes - http://forum.e46fanatics.com/showthread.php?t=372138
Bilstein Shocks Explained - http://forum.e46fanatics.com/showthread.php?t=517995
Ride Height - http://forum.e46fanatics.com/showthread.php?t=492030
DIY Info -
Control Arm Replacement - http://forum.e46fanatics.com/showthread.php?t=421918
Toe Alignment - http://forum.e46fanatics.com/showthread.php?t=459889
Camber Measurement - http://forum.e46fanatics.com/showthread.php?t=523203
TIS Info -
BMW Spring/Strut/Shock Replacement Instructions - http://forum.e46fanatics.com/showthread.php?t=516827
Steering wheel jerking on rapid brake application - http://forum.e46fanatics.com/showthread.php?t=515143
Control Arm Ball Joint Info - http://forum.e46fanatics.com/showthread.php?t=515137
Broken Rear Spring TSB - http://forum.e46fanatics.com/showthread.php?t=496579
jpr is offline   Reply With Quote
Old 08-07-2008, 06:01 PM   #6
simsima325
'a certain moderator'
simsima325's Avatar
My Ride: Honda Civic
great work guys! if you want to keep adding, I will add all the info to the initial post, and sticky both this thread and the brake info thread in this forum
keep up the great contributions!
Old 08-07-2008, 09:14 PM   #7
jpr
My Ride: '99 323i
Here's some more suspension goodness -
Swaybar noise solutions - http://forum.e46fanatics.com/showthread.php?t=380005
Sway bar upgrades using factory BMW parts - http://forum.e46fanatics.com/showthread.php?t=371422
BMW Performance Suspension Kit - http://forum.e46fanatics.com/showthread.php?t=537216
What coilovers perform the best while not slamming the car itself? - http://forum.e46fanatics.com/showthread.php?t=539125
Bulletproofing your Suspension: What next? - http://forum.e46fanatics.com/showthread.php?t=523207
** simsima325 - consolidation into the top post would be beneficial, thanks for offering to take care of that
Old 08-12-2008, 09:57 AM   #8
zeshon
Oh JPR, you're the man!
- Austin
Favorite sponsors
Old 09-02-2008, 08:28 PM   #9
jpr
My Ride: '99 323i
Another goody - the epic thread on the correct way to seat the springs on the struts. The pictures expired in the first through post, but read the whole thing and you'll find them again - http://forum.e46fanatics.com/showthread.php?t=350079
Old 09-08-2008, 11:14 PM   #10
zeshon
Here is a good thread for DIY KW installation.
http://forum.e46fanatics.com/showthr...9&highlight=kw
- Austin
Favorite sponsors
Old 12-28-2008, 10:54 PM   #11
zeshon
Do I need a front/rear strut tower bar?
Short answer : No
Long answer : If you have a few hundred to burn, then go ahead. The front bar has some minute effect, as does the rear. Putting in a front bar looks cool, and will have little/no negative impact on your vehicle. 323/328 vehicles need updated strut hats with longer studs. Rear bars take up trunk space, and don't do much. You will get mixed reviews, but as a whole they won't net you any real benifits.
- Austin
Favorite sponsors
Old 11-03-2009, 09:32 PM   #12
roastbeef
My Ride: 325ci
where is the thread on how to get rid of the factory understeer? it had to do with alignment, camber, and toe adjustment. it was a good read, but now i can't find it.
edit; found it.
http://forum.e46fanatics.com/showthr...ory+understeer
professional grade '02 nissan frontier rock crawler, and a 325 with a few add-ons.
roastbeef is offline   Reply With Quote
Old 06-22-2010, 11:57 AM   #13
Bob Ramberg
My Ride: 2002 330Ci
Toe-in or -out
I was looking at the alignment specs and the alignment sheet from my dealer and it appears that my car (2002 330Ci) has toe-out on both the front and rear axles. Is this correct? Every other car I have had had toe-in, espcially in the rear. I have used toe-out for track events but not on the street.
Bob
Bob Ramberg is offline   Reply With Quote
Old 06-24-2010, 05:44 PM   #14
jpr
My Ride: '99 323i
Bob
Bob -
I believe you are misunderstanding the specs. Toe in is cited as a positive number, toe out is cited as a negative number. The toe specification for all E46's calls for toe-in front and rear.
Old 06-26-2010, 10:27 AM   #15
Bob Ramberg
My Ride: 2002 330Ci
Thanks JPR for the quick response. I thought that would be the case but it pays to make sure. Unfortunately I now have to look for another cause of the squirrely handling that I have. I had the car aligned after I replaced the bushings and control arms. The car is a 2002 330ci with 55k miles, It has UUC rear trailing arm bushings and Powerflex front control arm bushings. I replaced the front control arms last summer. Tires are Goodyear F1 Asymetrical. The car trammels terribly. Uneven roads cause it to pull to the left or right, quite hard sometimes. In hard corners it is pretty stable. Not sure what the problem is.
Any suggestions where to look would be appreciated.
Old 07-04-2010, 06:05 PM   #16
jpr
My Ride: '99 323i
Just because you got the alignment done does not necessarily mean that you got a good alignment done. If you haven't done so already, check out the links to alignment info in this thread, then if you've got a copy of your alignment report, post it in a new thread and we'll take a look at it.
Old 12-11-2010, 08:35 PM   #17
kubi
Account Under Review
My Ride: BMW 330Ci
I have 2002 330ci convertible and trying to replace the rear shocks. In the rrepair manual and couple of other sites say that we can reach the upper mount of the shock from the "top storage compartment". Where is it? Is at reachable from the trunk or where? Is it a big space and easy to work at?
Any help appaciated.
Kubi
kubi is offline   Reply With Quote
Old 03-22-2012, 07:12 PM   #18
AlexD330
My Ride: 2003 BMW 330i
Best Coilovers for Sedans?
... Good thread
- AlexD330 -
April Dub Mix Out NOW!
AlexD330 is offline   Reply With Quote
Old 07-11-2012, 05:42 PM   #19
Imola.ZHP
My Ride: Imola ZHP
I would argue with the post about not needing a strut tower bar, my passenger side pinch weld has a hairline crack and a friend just had both of this fail...
Popped in here to hopefully find some information, I'll keep on searching...
-- '03 330i ZHP
-- Marcus
Imola.ZHP is offline   Reply With Quote
Old 10-04-2012, 02:25 AM   #20
irishpaul
My Ride: e46 diesel touring
Hi.. I'm no expert but I have had cars geo'd for track which can cause darting and / or tramlining
Check your settings against recommendations, specially camber and toe.
....and if you have lowered it a lit check caster
Check everything ;-)
Sent from my HTC Incredible S using Bimmer App
irishpaul is offline   Reply With Quote
suspension
