Go Back   E46Fanatics > E46Fanatics News
E46Fanatics News
Official BMW News stories and E46Fanatics.com Articles
Old 05-15-2006, 07:00 AM   #1
Touch-up Paint Chips with the AutoVisuals AutoSharp Pen
tim330i's Avatar
tim330i
Owner/Admin
Show Printable Version Email this Page
Advertisement
posted by tim330i
With the spring showers washing off the dirt, grit and grim from the winter the damage to your BMW's paint can be painfully obvious. If not from the winter (perhaps in sunny California) there are away rocks threatening your paint and it is only a matter of time that you are going to be faced with this situation and no one likes the look of an unsightly chip in the paint! Now you are faced with either taking your car to a body shop to fix those chips or taking advantage of the AutoSharp paint pen from AutoVisuals. Last spring we touched up the E46Fanatics.com 330i with the AutoVisuals AutoSharp pen with outstanding results. Unfortunately for the paint on the 330i we again need to do touch up work and lucky for us we had a fresh AutoSharp pen handy.
The AutoSharp pen utilizes a felt tipped applicator to provide you with the easiest possible experience while touching up the paint on your car. If you have ever colored in a coloring book and stayed inside the lines, you can probably do this. In addition to making the product easy to use, AutoVisuals also provides an exhaustive selection of color codes that can match the color on your car perfectly!
We set off to work by first reading the directions (well, most of them) on the pen and find all the necessary tools. Step one is obvious for anyone that has ever painted before; make sure the surface is clean! We used some rubbing alcohol on the surfaces to ensure that the area was free from dirt and wax which seemed to work quite well.
Before using the pen, AutoVisuals recommends vigorous shaking of the pen to ensure the paint is mixed correctly and an exact match of paint colors is achieved. After shaking the pen for about a minute we grabbed a paper towel and depressed the tip a few times until the tip was soaked completely with paint. We were ready to start fixing up some damaged areas of the car!
A quick walk around the car and it was disappointing to see the damage that the winter had caused, with the 330i just over 5 years old we can't say the damage is any worse than it should be, and besides most of the visual damage will be hidden with the AutoSharp Pen.
Once you have colored in the dings in your car, you'll probably want to go back and put on another layer or two of paint in order to "raise" the paint level up to match your car. The directions on the pen advise waiting five minutes but through experience we would advise waiting thirty minutes prior to applying additional coast of paint. We experience some problems when only waiting the five minutes described on the pen but had no problems after waiting 30 minutes.
A few days later, we took some time to survey the areas where we had applied the fixes and had to actively look for them from any distance. When looking up close, you can still make out some of the depressions in the paint but this can most likely be fixed through applying additional coasts to the areas in question.
Once again, we were very happy with the results from the AutoSharp pen for the $17.99 price tag. If you are looking to touch up your paint without taking a trip to the body shop and are not an absolute perfectionist, you should definitely give the AutoSharp pen a try. The pen is not a perfect solution (especially for those who could never color inside the lines) but it performs as well, if not better, than you would expect. It certainly makes your car look 100% better from a step or two away from your car and unfortunately I am sure there will be more paint chips, but at least now I have a simple solution!
AutoVisuals (877) 701 - 7780
http://www.autovisuals.com/ info@autovisuals.com
This article has been viewed 5003 times.
Old 09-15-2008, 05:18 PM   #2
myksbmw
My Ride: BMW 2003 325i
Thanks for the post!!
myksbmw is offline   Reply With Quote
Old 09-22-2008, 03:48 PM   #3
Dan99
My Ride: 2001 330xi
Cool, I might think about that. I've always wanted to try that road rash by bavauto, but that looks complicated and I'm afraid that I might make it worse.
Dan99 is offline   Reply With Quote
