Go Back   E46Fanatics > BMW News from around the Web
Submit the latest BMW news from around the world for other E46Fanatics members to check out.
Old 03-28-2007, 08:00 AM   #1
tim330i
E46Fanatics Owner
tim330i's Avatar
My Ride: 03 Ti Silver M3
Royal Purple Launches new 5W40 Oil Specially Formulated for European Cars
Royal Purple has added a new 5W-40 high performance motor oil to their extensive top-of-the line synthetic lubricant line. Royal Purple 5W-40 has all of the performance advantages of other Royal Purple motor oils while meeting API SM and CF warranty requirements as well as European ACEA A2-96 and A3- 02 warranty requirements. 5W- 40 has become an increasing common viscosity specification particularly in European automobiles.
Increase Your Power-
Royal Purple motor oil reduces friction and improves combustion efficiency, which translates into more horsepower and torque. Royal Purple has been proven in independent tests to increase horsepower and torque between 3%-5% compared to leading synthetic and conventional oils.
Save Fuel And Money At The Pump-
According to independent research done by North Carolina State University, using Royal Purple motor oil instead of other “energy-conserving motor oils” offers fuel economy gains of up to 4.5%. The synthetic fluids’ low coefficient of friction means you’ll be making fewer stops for gas.
Wipe Out Wear-
Royal Purple motor oil is made from a blend of synthetic oils and the company’s proprietary, synthetic Synerlec additive technology. Synerlec greatly reduces engine heat and wear. And because it’s extremely tenacious, it adheres to engine surfaces after shutdown, which means you get extra engine protection every time you start up.
Extend Your Drain Intervals-
Royal Purple’s 5W40 lasts longer than other motor oils, so you can safely extend your oil change intervals—up to 12,000 miles or more, as long as you change the filter regularly.
Keep It Cool-
Royal Purple’s film strength is up to 400% stronger than other leading motor oils, which means the oil reduces both wear and heat to protect the engine, all while keeping friction to a minimum.
E46Fanatics Review-
Be on the look out for a E46Fanatics track date article including spring preparations for the first driving event of the season and a oil change with the new Royal Purple 5w40!
About Royal Purple -
Royal Purple makes synthetic products for all your automotive needs, including engine oils, transmission fluids, gear oil, coolant additives, fuel system cleaner, power steering fluid, chain lubricant, grease, penetrating lubricant, assembly lube and shop compressor lubricant. For more information on Royal Purple and its products, contact Royal Purple Ltd.
One Royal Purple Lane
Porter, TX 77365
Phone: 281-354-8600
Web: www.royalpurple.com
tim330i is offline   Reply With Quote
