Thread Tools Search this Thread Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Old 08-02-2008, 04:03 PM   #1
impee
My Ride: BMW 2002 318i SE
DIY Radiator Flush
I've been busy all afternoon doing this, then spent nearly all evening put it on a webpage...my hands are very tired!!!
I hope some will find my DIY Radiator Flush helpful.
http://www.impee.co.uk/radiator_flush.htm
impee.
impee is offline   Reply With Quote
Old 08-02-2008, 04:04 PM   #2
willsbma
My Ride: 99 323i
I stuck a hose in every hole I could find until everything ran clear.
Edit: Your DIY is close but you are supposed to fill it with the heat on full blast.
Matte Black Kidney Grilles | Smoked Tails & Corners | Mtech II Bumper | Hotchkis Springs | ACS Roof Spoiler | M3 Spoiler | 20% Tint
WTB: Black sun visors & grab handles - PM ME!
I have P.A. Soft and a 20-pin adapter. Only used it a few times but pm me if you need anything coded!
willsbma is offline   Reply With Quote
Old 08-02-2008, 04:21 PM   #3
FLAT_FOOT
My Ride: L3MANS
Send a message via AIM to FLAT_FOOT
done that last week.....what a MESS!!!!
http://www.mybannermaker.com/link.php?nurl=http%3A%2F%2Fwww.mybannermaker.com%2F][IMG]http://img238.imageshack.us/img238/6656/mybanner4908a36d1f0abir8.jpg
6 Feet Under!....
to be continued......
FLAT_FOOT is offline   Reply With Quote
Old 08-02-2008, 04:36 PM   #4
impee
willsbma, thanks for the tip, I will change my notes.
one thing i wanted to ask is that, once i finished, i parked my car and went in. 1 hour later a kid from outside rang the bell and told me that my car is making noises. i ran out and heard the radiator fan on full...i took the car for a spin, incase it needed settling down or water needed to flow through all the pipes for it to stop, but it still didn't.
the only way it stopped is when i unplugged the fan cable and then put it back. since then every 30mins i go out and check the car and its fine...very paranoid now!
does anyone have any idea what that was???????
thanks.
Old 08-03-2008, 08:16 PM   #5
dakkon
My Ride: e46 330ci/e30 318is
you should also drain from the other blue plug, the one just to the right on the one you did losen... another thing you didnt point out in your DYI is the block drain, to drain the coolant from the block.
http://www.bmw325i.net/maint_coolant_change.shtml
dakkon is offline   Reply With Quote
Old 08-04-2008, 05:38 AM   #6
impee
Radiator flush
damn...It looks like I missed a couple of other things too...its becuase I couldnt log into e46fanatics on the day to search for a DIY for this!!!
If I haven't drained the block, does it make a big difference? or can I leave it till 2 years later when I flush it again?
impee.
Old 08-04-2008, 06:34 AM   #7
bmwbun
Banned
My Ride: Pre-facelift Coupe
The pictures with your DIY are excellent.
As mentioned above, you left out the engine block draining. Without draining it, you still have old coolant mixed with the new.
Also, I think I would change the name from "Radiator Flush" to Engine Coolant drain and refill.
bmwbun is offline   Reply With Quote
Old 08-06-2008, 07:27 PM   #8
willsbma
My Ride: 99 323i
thanks.
My fan was staying on when the car was off. I had to un-plug when stopped and then plug it in when I drove. PITA. One time I went to the store and it did shut off by itself, I expected it to be on when I came back out but it was still off. I thought I got lucky for a minute but then when I got home and shut the car the fan stayed on again. So it was a fluke and I still had to buy the fan. Just watch it carefully. Either you kill the battery or kill the engine.
Old 03-28-2010, 01:37 AM   #9
YOnpds
My Ride: E46
First of all, thank you impee for the DIY.
Second, anyone know why the fan is staying on? Is there a way to prevent this from happening?
YOnpds is offline   Reply With Quote
Old 03-28-2010, 03:11 AM   #10
Megalocnus
My Ride: 05 330i ZHP/MT
You meant deionized water, not ionized.
You want low ion concentration in this water - ideally only the water's own H3O+ and OH- ions. Some contaminating metals, carbonate, organic ions etc. will negatively affect the engine's aluminum alloy and/or precipitate with coolant's buffer or preservative.
This is why the engine grade water is either purified by distillation or depleted by passing through ion exchangers.
Megalocnus is offline   Reply With Quote
Old 12-14-2010, 01:40 PM   #11
BlazE46
My Ride: 03330ci
that sounded so cool. haha i wish i could talk like that.
BlazE46 is offline   Reply With Quote
Old 12-31-2010, 12:18 PM   #12
BMW-North
// Quandt AG (Retired) //
My Ride: AMv8,e46x3,e90,e83
Drain block
Dakkon made a great point above. If you follow this DIY you only swap a little over half the coolant. I appreciate the OP taking the time to put this together but I had to refer back to the Bentley as I was expecting to see 8.4 liters drain and I ended up getting about 4.5 liters.
If you read the linked DIY the OP replaces the drained coolant with 2.5 L of coolant and the same amount of distilled water. He puts in a total of 5 liters coolant.
The m54 and m52 (E46 2.5 & 3.0) engines have a coolant capacity of 8.4 liters.
You need to drain the engine block to get the remaining 3.5 liters out. It is a 13mm hex bolt on the exhaust side of the lower block below cylinder #2. (see photo). You will get another 3.5 L of coolant once you remove this drain plug. Put this plug back first, torquing to 25Nm (18ft/lbs) then follow the rest of the OP's DIY. Remember now that you will need an additional 3.5 L of coolant mixture.
BMW-North is offline   Reply With Quote
Old 01-06-2011, 07:35 PM   #13
mantoy3954
My Ride: 02 325 ci
radiator flush
Can anyone tell me if its a good idea or not to power flush my 2002 325ci coolant system?
mantoy3954 is offline   Reply With Quote
Old 01-06-2011, 07:49 PM   #14
TrickTizzle
My Ride: 325i
No need to.
Drain block. Drain radiator and your good.
Old 01-06-2011, 08:15 PM   #15
aphhpa
My Ride: 2001 330Ci
Send a message via AIM to aphhpa
Would this by any chance solve an issue of my cars heat AND A/C only working while the car is in motion? When idling the heat and ac does not work
aphhpa is offline   Reply With Quote
Old 01-06-2011, 09:53 PM   #16
steveninchicago
My Ride: 2003 325i
That sounds like a bad thermostat.
steveninchicago is offline   Reply With Quote
Old 01-06-2011, 10:46 PM   #17
aphhpa
My Ride: 2001 330Ci
Negative cause ive had my therm replaced and it still doesn't work unless moving
Old 01-06-2011, 11:19 PM   #18
iansanderson
My Ride: 2001 330CiC
nice job on the DIY and I won't knock you for making it. I know they take a lot of work.
But I will mention that it's not necessarily the approved method to vent the cooling system which is why you may have experienced the cooling fan issue you mentioned.
Cheat Sheet:
GT1/ISIS/MoDiC = Factory authorized diagnostic system used by BMW dealerships across the world.
NCS Expert = BMW Factory R&D programming tool available on the internet (not intended for the public and not available to the dealership network)
OEM = Genuine BMW part only available from a franchised BMW dealership.
DME = Engine Management Computer
iansanderson is offline   Reply With Quote
Old 03-27-2012, 04:34 PM   #19
rajivsinghsuwal
My Ride: BMW 325CI
When you drain the radiator, the coolant inside the engine block (3.5 Lt approx) does not come out of the radiator drain plug.
I think you should not flush it if you re not draining engine block.
If you flush it with water without draining the engine block, what happens is that the water you pour in will displace the coolant inside the engine block and when you add new coolant into the system with the 50/50 mix, that will become 25/75 mix (75% water and 25% coolant) when it mixes with the water sitting in the engine block.
That may have caused the fan to blow even when the engine is off because the higher proportion of water in the coolant system makes it to vaporize faster which creates high presure inside.
BMW Antifreeze/Coolant (50/50):
1 Gallon (3.78 Lt) of concentrated coolant, when you mix it with distilled water becomes 2 Gallons (7.56 Lt). BMW Service Manual says the exact volume to cover engine block and radiator is 8.4 Lt (for most models), so I guess it's good to have an extra bottle of coolant.
Engine-Block Drain Plug Location:
Radiator Drain Plug Location:
rajivsinghsuwal is offline   Reply With Quote
Old 03-27-2012, 05:06 PM   #20
mxchris727
My Ride: E39, E93 335
Send a message via ICQ to mxchris727 Send a message via AIM to mxchris727 Send a message via MSN to mxchris727
So would you need more than one bottle (gallon) of BMW concentrated coolant?
-Chris
I have a computer set up with DIS, TIS, SSS Progman, INPA, NCS Expert, WinKFP, and Tool32 with an EDIABAS interface; PM me if you want to stop by and code your car.
ISTA/P & /D is up and running!
mxchris727 is offline   Reply With Quote
coolant, flush, radiator
