Old 02-24-2011, 09:48 AM   #1
rfier
My Ride: 99 BMW 323i E46
Michanical or Electrical Fan
I have a 99 323i manual 5 spd e46 and I have been doing allot of reading because i had to replace my a/c compressor fan and i noticed that allot of manual cars don't have the Mechanical belt driven fans they have electrical fans and my question is, I have a perfectly good working mechanical fan, would there be a benefit to switching to an electrical fan and why didn't my car come with one ... was it just because of the production date?
Graphic Designer: Will do photo edits for free (when i have time) shoot me a PM
BMW 99 323i e46: EE Halo Lights, Custom Pipe Style CAI, White Corner & Side Lights, Flat Black Grilles, Short Shift Kit, Aluminum Pedals
Coming Soon: H&R Sport Cup Kit, M3 Front Bumper, MTech Rear Bumper, GTR Style Hood, E-bay Headers, Rear LEDs, 18s, Magnaflow Muffler, BMW E46 330i M54 3.0L Engine
rfier is offline   Reply With Quote
Old 02-24-2011, 10:09 AM   #2
rhm325i
My Ride: 02 BMW 325i
i assume because of the production date. if your fan works i wouldnt worry about it. plus you would need a new fan shroud and a thermoswitch, also your harness might not even have the connectors for an electrical fan or the thermoswitch.
rhm325i is offline   Reply With Quote
Old 02-24-2011, 10:21 AM   #3
rfier
I was under the assumption that i would remove not only the fan assembly but the A/C Compressor fan as well and replace it with the electrical fan via the plug for the ac compressor fan ... but i see you logic in not fixing whats not broken ... i just wanted to know what the benefit is in having the electrical vs mechanical
Old 02-24-2011, 10:37 AM   #4
Drewfus2101
My Ride: N/A
Have you looked at your car? All manuals should only have a single electronic fan behind the radiator.
I have no idea what you are talking about with a A/C compressor fan. Only auto trans cars came with a mechanical fan. It bolts to the water pump and sits behind the radiator. Auto trans cars also have a electronic fan that sits on the front of the radiator to push air into it.
Drewfus2101 is offline   Reply With Quote
Old 02-24-2011, 10:42 AM   #5
alpine325i
My Ride: Alpine 2001 325i
I had both fans when I was an auto... converted to 5 speed and removed the mechanical fan as it was not necessary to cool the transmission anymore (auto runs much hotter then standard). I have had no issues with heat since removal even with ac on in the summer. Main reason for removing was to free up some drag on the engine that was caused by the mech fan. Hope that helps a little
WTB: KOSEI K1'S 17X8.5
alpine325i is offline   Reply With Quote
Old 02-24-2011, 10:46 AM   #6
rfier
On one side i have this:
On the other side i have this:
and there are two radiator looking things stacked one in front of the other
And i have a Manual Transmission
And this is exactly why im confused because everyone is telling me im wrong that only automatics have this... then why do i have it if im not automatic.
Old 02-24-2011, 11:08 AM   #7
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
I've seen a few manuals with the dual fan setup. Keep it or get the electric fan
Old 02-24-2011, 11:12 AM   #8
Hector45
My Ride: 2002 OB 330i
Main things you need to worry about with the mechanical fan is the water pump, if the bearing goes it can tear the fan apart, and two the motor mounts, if they allow too much play, when the engine torques the fan can hit the shroud and fly apart.
Hector45 is offline   Reply With Quote
Old 02-24-2011, 11:28 AM   #9
rfier
ok sorry im dumb ... just to clarify, I can either keep the A/C Condenser Fan and Mechanical Belt Driven Fan or remove both of them and have just one Electrical Puller Fan in there place and it would free up room, Engine Drag, Stress on the water pump, and reduce noise... right?
Old 02-24-2011, 01:37 PM   #10
Drewfus2101
My Ride: N/A
Interesting. I've never seen or heard of anyone with that setup. To answer your question, yes. Read this thread. I just did the conversion on my auto, and that part number worked perfectly. Have not had any problems in the first week.
http://forum.e46fanatics.com/showthr...fan+conversion
Old 02-24-2011, 02:28 PM   #11
Iceman00
Banned User
My Ride: E90 6MT
On my last Z3, I HAD a mechanical fan. At least until it failed and exploded, and took out my radiator. It was essentially a free fan delete mod. The major issue is the water pump bearing (as someone mentioned above) and to make sure they are in good shape. Otherwise unless you are looking to free up a few hp, leave it alone.
Old 02-26-2011, 02:23 AM   #12
ScareySteve
My Ride: 1999 BMW 323i
You're probably better off with the mechanical one anyways... I have a 99 323i with an electric fan and I actually just replaced it about two hours ago.
...WAY easier than I expected. I'm gonna take it out for a drive tomorrow to make sure it's working properly.
The problem with the electric fans is that they are notorious for getting stuck in the high speed position (which is why I just replaced mine). Since there is no relay, the whole fan unit has to be replaced when this happens.
You know what they say... more electronics means more can go wrong.
ScareySteve is offline   Reply With Quote
Old 02-26-2011, 03:40 AM   #13
Elwin
My Ride: 330i ZHP
On the manual you have electrical. On Automatic you have Electrical and mechanical. This is done to cool down the automatic transmission heat exchanger. If you replace mechanical with electrical - you will kill the automatic transmission. If you replace electrical with the same dual fan as on automatic while having a manual you just get better cooling assuming that your viscosity clutch on mechanical fan is working.
Elwin is offline   Reply With Quote
Old 02-26-2011, 05:11 AM   #14
Megalocnus
My Ride: 05 330i ZHP/MT
^ Negative.
As mentioned above - there are some (early model) E46 BMWs with manual trasnmission AND dual mechanical/electric fan setup. Including mine.
There are also several people here who have exchanged their dual fans for the single electric puller fan and their automatic transmissions aren't dead yet.
OP if your electric puller fan is broken, it may be worth replacing both your fans with the singe electric fan. This one will not be in front the radiator as your current one, it goes behind it. Part# 17117561757. This is Bosch fan, double if you need Bosch or Siemens.
Megalocnus is offline   Reply With Quote
Old 02-26-2011, 05:49 AM   #15
jeffmr
My Ride: 2003 325xi
That's good to know. I have usually had a really difficult time getting the mechanical fan back on when I do any work in there.
jeffmr is offline   Reply With Quote
Old 11-20-2011, 11:21 PM   #16
gumanov
My Ride: 2001 325Ci 5-speed
Sorry to bring back a somewhat old thread, just wanted to add that I also have a manual tranny with a dual fan setup..
Was doing research on how to replace the thermostat, and noticed some people claimed that ALL manual transmission E46's have a single electric fan behind the radiator. NOT true.
I own a 2001 325Ci 5 speed, production date 08/2001. It has two fans, one electric in front of the radiator and the other is attached to the water pump, behind the radiator.
Considering replacing the mechanical fan with an electric one, but also keeping the front AUX fan; would that be ok? Would like advice from someone who has done that..?
2001 325Ci 5spd
2004 330Ci ZHP 6spd :)
gumanov is offline   Reply With Quote
Old 11-20-2011, 11:56 PM   #17
jzwu
My Ride: 2005 BMW 330Cic
I think the problem is there is only one electric fan plug so only one fan can be connected even if you have two fans in thete.
jzwu is offline   Reply With Quote
Old 04-13-2014, 05:30 PM   #18
PeteyEsco
My Ride: '02 325xiT
I just took my newly purchased '02 325xiT to a mechanic. He recommended the first thing I do is replace my mechanical fan to an electric. He warned about it failing one day and becoming a grenade.
PeteyEsco is offline   Reply With Quote
Old 04-13-2014, 05:36 PM   #19
David McMahon
My Ride: '99 E38 740iL
Lots of stories about it, can also put a nasty inverted dent in your bonnet (hood)
David McMahon is offline   Reply With Quote
