Go Back   E46Fanatics > Tuning & Tech > Suspension & Braking
Old 08-05-2008, 05:24 PM   #1
AlexB.
My Ride: Is not as slow
Send a message via AIM to AlexB.
Brake Issues?
I recently got new pads put on my 323. When I started driving down the street as soon as I depress the brake I hear a clunk. It is only as soon as I hit the brakes (it does not continually clank). It only does it when I am going above 5 MPH. I took it back to get another set of pads thinking that it was the bads that were the problem. The new pads still do the same problem. It sounds like metal on metal and when driving sounds like it is coming from the front of the car. I checked the rear subframe for damage and there is known. I am stumped on what it could be. Any ideas?
AlexB. is offline   Reply With Quote
Old 08-05-2008, 06:20 PM   #2
Chris-TK
My Ride: Mazda
Did you touch the rotors at all? Your calipers might not be seated properly.
K.
Chris-TK is offline   Reply With Quote
Old 08-05-2008, 09:18 PM   #3
AlexB.
How can I tell if they are seated properly or not?
Old 08-05-2008, 09:18 PM   #4
AlexB.
Old 08-08-2008, 03:32 AM   #5
NorCal Einstein
My Ride: E92 335i
Send a message via AIM to NorCal Einstein Send a message via Yahoo to NorCal Einstein
Brake components fit together pretty well. You should be able to really see if something isnt seated correctly.
Recheck your install for loose bolts, and make sure your caliper pins are greased.
Current:
2009 E92 335i Alpine White/Coral Red
Past:
2007 E92 335i Sparkling Graphite/Black
2000 E46 323i Steel Blue/Grey
NorCal Einstein is offline   Reply With Quote
Old 08-08-2008, 06:56 AM   #6
jinthekoreankid
My Ride: 03 BMW Z4 2.5i Sport
Send a message via AIM to jinthekoreankid
caliper bolt might be loose causing it to hiccup
2003 BMW Z4 2.5i Sport
jinthekoreankid is offline   Reply With Quote
