Sponsored by BimmerWorld
Old 08-03-2008, 10:07 PM   #1
wiedrick2005
My Ride: POS
Unhappy Help! Anoying snapping front suspension.
This issue is getting really anoying. Whenever I got for a drive i hear a snapping noise coming mainly from the left front side of the car and sometimes the same spot on the right side.
The only way it makes this noise is if the road is uneven and one front wheel is going up while the other one is going down or stay stationary. It never happens when I got over a speed but straight on.
This led me to believe it was the sway bar links. So, I took it to a bmw tech and he said there was nothing wrong with the swaybar links and they are "tight." The problem is still present today and is very noticable.
It happens when...
- driving over uneven roads causing the front wheels to move up and down at different times
- Hitting an incline at a diagonal (Again one side of the suspension being compressed while the other is still on flat ground).
And it doesn't happen when...
- Hitting a speed bump or any change in the road head on (ie. both sides of the suspension go up in the same fashion) or driving on fairly flat roads.
That's the best I can describe it. Any help would be greatly appreciated.
wiedrick2005 is offline   Reply With Quote
Old 08-04-2008, 08:19 PM   #2
wiedrick2005
My Ride: POS
Anyone have any input? Any way to diagnose the problem better?
Old 09-10-2008, 05:26 AM   #3
UK BM
My Ride: Scirocco GT TSI
Sway bar. Thats all it can be from what your describing. Try new end links they are only cheap and you can fit them easily. Actually try tightening them up before buying new ones.
UK BM is offline   Reply With Quote
Old 09-10-2008, 12:32 PM   #4
n2Bimmer
My Ride: Loves Corners
ya end links are what come to my mind, they are cheap, other things can be cotrol arms , i see you have a 2000 323, if your suspension has not been changed at all its time.
