Old 08-04-2008, 10:44 PM   #1
preethm
My Ride: 2001 BMW 325XI
Mycarr 60+ LED angel eyes
Hi, so I took apart my depo e46 projector lenses...took off the old angel eyes and im trying to snap the new ones on with the alligator clips... only problem is that they wont fit. the allligator clips are spaced wider than the area i can work with is...Should I just super glue it on? Or did I get the wrong product.... the DIYs I have found are all for e46 projectors without current angel eyes... someone pleeease help... kinda lost here...
preethm is offline   Reply With Quote
Old 08-04-2008, 10:49 PM   #2
sillieidiot
My Ride: '06 AW 330ci
so you have p46's? you don't really use the clips on the p46's. you take off the circuit board inside and put them in the plastic covering, then put that cover back on
Old 08-04-2008, 10:52 PM   #3
KHOALTY, Inc.
My Ride: BMW
Send a message via AIM to KHOALTY, Inc.
Exactly what sillieidiot said, you need to crack the board apart from the plastic housing of the angel eyes first, from there, you can remove your CCFL in your projector46 and insert the circuit board with the LEDs and it should fit right in. You can put a dap of silicone in the back of the circuit board on top to keep it in place and place the snap on rings that the projector46 has to lock it in place.
KHOALTY, Inc. is offline   Reply With Quote
Old 08-04-2008, 11:06 PM   #4
preethm
Crack the board apart??? Wow... I can't believe I didn't realize it would take so much work... is there a DIY available for this? How do I "crack apart the board apart"... you mean crack the board from the plasting housing of the NEW angel eyes? You mean basically...break off the plastic on the new LEDs....put the circuit board into the old area..then use the old plastic to put back on?
Old 08-04-2008, 11:07 PM   #5
sillieidiot
it's not that hard. he's just making it sound harder than it is. just take it apart pretty much.
Old 08-04-2008, 11:09 PM   #6
preethm
Do either of you have an AIM sn I can contact you via? Im standing right here in front of my car with my laptop...not sure how exactly to take the plastic off the LEDs without snapping the circuits behind it....I get the jist of what youre saying tho.. basically put the circuits from LED into the halo opening...then put the old piece back in....bt how do I get the LED plastic apart from LED circuits?
Old 08-04-2008, 11:15 PM   #7
preethm
Should I just snap the LED plastic til the circuit comes out? isn't that risky...
Old 08-04-2008, 11:24 PM   #8
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
Just peel the clips off and use an exacto knife to clear out the rest of the glue. Pretty straight forward to pull apart but make sure not to bend or crack the PCB board.
Old 08-04-2008, 11:51 PM   #9
sillieidiot
are you still working on it? if so give me a call, and i can walk you through it i guess. 714 299 9470
Old 08-05-2008, 12:01 AM   #10
preethm
Thanks! I got it... Appreciate the help from all of you guys...Silliidiot...Khoa...and Nick Jlewis... got it to work on my right side... figure I wil get the wiring all done and make sure it works... then work on the left side.... much appreciated... thanks =) Wish me luck on the rest! =)
Old 08-05-2008, 12:17 AM   #11
deadpass
My Ride: 01 330i
is this true for just aftermarket P46s? what about OEM Xenons?
deadpass is offline   Reply With Quote
Old 08-05-2008, 12:32 AM   #12
jamesthebikeguy
My Ride: Is a ugly POS
Send a message via AIM to jamesthebikeguy
OEM uses supplied clips ^^^^^^^^^^^^
jamesthebikeguy is offline   Reply With Quote
Old 08-05-2008, 12:52 AM   #13
sillieidiot
goodluck. if you want, you can check them all by putting them to a 12v source so you don't have to do all the wiring before being able to check. plus that way, you can tell if it's the wiring you did wrong or the rings aren't working (by eliminating their failure beforehand)
Old 08-05-2008, 12:58 AM   #14
preethm
I connected their wires up....put the ground where it is supposed to be.... and then just put both the red positive wire and the trigger wire touching the positive + battery terminal to see if it works....turned key to second position yet it doesnt work..... what does this mean?
Old 08-05-2008, 01:02 AM   #15
sillieidiot
i would recommend to check the rings to see if they light up first. they way we can eliminate them. just take each one and touch it to the respective positive and negative points. then we will go from there
Old 08-05-2008, 01:02 AM   #16
issacsierra06
My Ride: bmw 325i
are ccfl they same way sillie??? do u have to crack them open and use the stock angel eyes the p46's came with?
READ BEFORE YOU BUY
issacsierra06 is offline   Reply With Quote
Old 08-05-2008, 01:06 AM   #17
sillieidiot
what do you mean?
if you have p46's, and you replace one of the angels with another ccfl tube, then yes you need to open it and do it.
if you have OEM xenons/bixenons/halogens, then all you need is to clip them on as they should be.
Old 08-05-2008, 01:11 AM   #18
preethm
Gonna sound like such a kid here but where's the negative place where I touch the negative wire in the hood (I know where it is in the trunk)
Old 08-05-2008, 01:12 AM   #19
issacsierra06
My Ride: bmw 325i
i have some p46's from ddm , i tried installing cclfs but the aligator clips won't work with them?? so i take the ccfl tube out and put it behind the original angel eyes the p46's came with?
READ BEFORE YOU BUY
Old 08-05-2008, 01:13 AM   #20
Dan99
My Ride: 2001 330xi
Good Luck Preethm, but yeah I had the same problem at first with the 2nd ignition thing. But yeah like what sillieidiot said, first test to see if the angle eyes work. You can check this by placing the red trigger wire to the positive jumper, it should be in the DIY that I gave you, on how to check it.
Dan99 is offline   Reply With Quote
