Old 08-05-2008, 01:16 AM   #21
Dan99
My Ride: 2001 330xi
The ground is the negative, and that was also where you put your relay w/ the black trigger wire.
Dan99 is offline   Reply With Quote
Old 08-05-2008, 01:21 AM   #22
sillieidiot
My Ride: '06 AW 330ci
Originally Posted by issacsierra06 View Post
i have some p46's from ddm , i tried installing cclfs but the aligator clips won't work with them?? so i take the ccfl tube out and put it behind the original angel eyes the p46's came with?
yes, exactly the same thing as what the OP is doing. be careful not to break the tubes, they are very fragile
Old 08-05-2008, 01:23 AM   #23
sillieidiot
Originally Posted by Dan99 View Post
Good Luck Preethm, but yeah I had the same problem at first with the 2nd ignition thing. But yeah like what sillieidiot said, first test to see if the angle eyes work. You can check this by placing the red trigger wire to the positive jumper, it should be in the DIY that I gave you, on how to check it.
i'm having his test the angels by bypassing the relay altogether first. then once we know they all work. do it again, the way you described to make sure the harness works.
Old 08-05-2008, 01:26 AM   #24
preethm
My Ride: 2001 BMW 325XI
Ahah! So I touched it to the positive terminal, and the negative to the car ground...but nothing..on either...soooo I was thining maybe the positive terminal isnt working...so I used the trunk positive/negative terminals (the actual battery)..and it worked! What the hell does that mean? I'm not getting any juice from the positive terminal in front... how do I fix that?
preethm is offline   Reply With Quote
Old 08-05-2008, 01:29 AM   #25
preethm
issa...like he said... be careful... I used a tiny tiny tool I had but you can use an exacto knife...and carefully peel back the back panel piece...between the back panel and the plastic front is the circuit... be careful not to break it.... then after you get the tiny back panel off....break the alligator clip.... take out the circuit and wire..and place it in your p46's (behind the existing plastic cover).... not sure if that's explanatory or not... but you have to be careful or you will snap it.
Old 08-05-2008, 01:31 AM   #26
issacsierra06
My Ride: bmw 325i
thnks guys, sorry for butting in on ur post!! hope ur angel eye install goes smoother after this
READ BEFORE YOU BUY
issacsierra06 is offline   Reply With Quote
Old 08-05-2008, 01:33 AM   #27
sillieidiot
you probably just didn't get a good connection on the jumper points. it also depends on which you used. if you used the ecu trigger the first time and it didn't work, could be the fuse.
then used the footwell the second time, and that may explain why it went on, when tapped to the same source
Old 08-05-2008, 01:34 AM   #28
sillieidiot
all good, then i don't have to open a separate window on this crappy hospital computer to check for your response lol. i can't even type fast, too much noise for the people that are sleeping
Old 08-05-2008, 01:35 AM   #29
preethm
no... I am talking bout just the separate AEs... touching positive to the positive terminal under the hood does not work (with neg. touched to car body)... but when I use the trunk battery positive it works... is there any way i'm not getting juice in my hood positive terminal? car fuse gone or something?
Old 08-05-2008, 01:36 AM   #30
Dan99
My Ride: 2001 330xi
You might not be getting a good connection with your ground wire, try a different location or try tightning that screw.
Old 08-05-2008, 01:40 AM   #31
preethm
Ah yes... thanks! I tried it again.. this time touching the OEM ground terminal bolt...touching that works perfect! however... the car body or even the 10mm bolt isnt working.... I will just connect the wire to the 12mm OEM ground instead...should do the trick.
Old 08-05-2008, 01:42 AM   #32
sillieidiot
are you touching both the jumper points to make a closed circuit? if you just touch the car, you have to sand/file down the paint to the bare metal. else you're not getting a good connection
Old 08-05-2008, 01:43 AM   #33
sillieidiot
you're not supposed to use the 10mm bolt as the grounding point. it should be the OEM ground.
Old 08-05-2008, 01:45 AM   #34
Dan99
My Ride: 2001 330xi
The DIY by fastM showed using the 10mm bolt and that's what I'm using and it's working fine.
Old 08-05-2008, 01:46 AM   #35
sillieidiot
yea i know, but that's not generally a good connection. i always go straight to the OEM point.
Old 08-05-2008, 02:32 AM   #36
preethm
Not sure if you guys ahve had a problem with this (issue #3 so far..haha), but I cannot get to the positive terminal behind the black plastic piece...after i disconnect the plug and try to lift the cap...it wont lift...can I just use the other positive terminal that is facing up? unscrew that bolt and use that?
Old 08-05-2008, 02:39 AM   #37
sillieidiot
just keep at it man. On some cars it is hard as hell to pull it. You will eventually get it.
You can use the other one, but you will have a fire or some other problem later on. Trust me, you don't want to do it lol.
Old 08-05-2008, 02:41 AM   #38
Dan99
My Ride: 2001 330xi
Yeah that part took me awhile too. The plastic peice, the whole peice should just go up vertically. Also there is a small button towards the bottom of the plastic peice that goes through the metal, so make sure you get that out of the way when trying to take the black plastic+ off.
Old 08-05-2008, 03:08 AM   #39
sillieidiot
and take off the hood shock sensor while you're at it
Old 08-05-2008, 03:39 PM   #40
budwab
My Ride: 330D
So will LED angel run straight off any 12v switched supply....i.e. without the relay harness ??
What is the relay harness for....sorry to ask a noob question, but you guys know your stuff
budwab is offline   Reply With Quote
