Old 08-07-2008, 03:30 PM   #1
Rayce185
Modifiziertes ///Mitglied
Rayce185's Avatar
MAF Tuning?!
I read somewhere that removing the plastic fence in the MAF unit may bring benefits when installing an aftermarket air filter, since it optimizes air flow.
Troof?
dun dun duuuunnnn
Rayce185 is offline   Reply With Quote
Old 08-07-2008, 03:39 PM   #2
NightRunner
My Ride: Slowmobile
dont do it. you wont gain anything but ruining your sensor. its there to straighten the air flow over the sensor. taking it out only leads to bad.
Myth busted! its there for a reason other than eye-candy
NightRunner is offline   Reply With Quote
Old 08-07-2008, 03:59 PM   #3
Rayce185
Rayce185's Avatar
Yeah, that's why I was wondering what FUBAR I read. I can't even remember where that was
Thanks!
dun dun duuuunnnn
Old 10-07-2008, 02:26 PM   #4
TheRiddle
Sofa-king-what
My Ride: M52TUB28-Vert
i remember that thread...
someone agreed someone not..
i removed the screens but honestly i think that it ws a placebo effect...
anyway take a read here...
http://forum.e46fanatics.com/showthr...threadid=38959
TheRiddle is offline   Reply With Quote
Old 10-07-2008, 04:54 PM   #5
n2Bimmer
My Ride: Loves Corners
ive heard this too. but i dought it.
Old 10-07-2008, 06:55 PM   #6
simsima325
'a certain moderator'
simsima325's Avatar
My Ride: Honda Civic
A better trick would be figuring out how to run a larger 330 MAF on a 325. Good half inch diameter difference. Same with inlet tube.
-Brendan
Old 10-11-2008, 02:40 AM   #7
mkodama
mkodama's Avatar
Yeah, doesn't provide much benefit and read it causes damage or incorrect readings to for the sensor. Also air resistance things like that only have a small benefit at higher RPMs and when you are at full throttle. No difference in the first half of your RPM range.
One step better would be the entire 330 intake and manifold. Most of the power increase of a 330 over 325 is solely from the intake and manifold.
If I remember correctly, the longer stroke 330 cranks provides 30% or the power increase and the 330 intake and manifold provide like 50%, and the rest is a few smaller things.
Old 10-11-2008, 04:10 AM   #8
Bimmer Dude Xi
My Ride: 03 325XI 07 ZX-6R
Send a message via AIM to Bimmer Dude Xi
So basically the 330 intake manifold has larger runners?
Will the 330 maf sensor connect into a 325?
Are throttle bodies the same? Or is the 330 have a larger bore?
What is exactly needed?
|Dinan High Flow Air Box|Eibach Pro Kit|Koni Sport|UUC Strut Barbarian|UUC TSE3|UUC Underdrive Pulleys|18" VMR V710|
|BMC Race Air Filter|CRG Spectrum Levers| Galfer Steel Braided Brake Lines|Volar Motorsport Spiked Frame & Bar-end Sliders|
Bimmer Dude Xi is offline   Reply With Quote
Old 10-23-2008, 04:38 AM   #9
mkodama
mkodama's Avatar
I'm not sure whether it is the design, length, diameters or what with the inatke runners. But I am pretty sure that the 330 has a larger diameter intake tube, MAF sensor, and throttle body. Also likely proper software is needed to make sure everything runs smoothly.
Old 10-23-2008, 07:51 AM   #10
Rayce185
Rayce185's Avatar
330 intake system retrofit DIY FTW
dun dun duuuunnnn
Old 12-22-2008, 12:43 PM   #11
n2Bimmer
So anyone do this, can you just sway the MAF sensor or what.
Old 12-22-2008, 04:56 PM   #12
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
It's been done. Recently. Search around. I think wooboodoo did it.
Old 12-22-2008, 05:00 PM   #13
Rayce185
Rayce185's Avatar
I need a DIY for a complete 330 intake system (including manifold) onto a 323...
dun dun duuuunnnn
Old 12-22-2008, 07:57 PM   #14
n2Bimmer
i heard the gains are only on the low end and you losse high end power
Old 12-28-2008, 04:10 AM   #15
GaffasCompact
My Ride: e46 320td compact
Troof?
well i own a e46 compact 320d, i have unpluged the maf and the car is running fine , its actually running better .only down sideto it is that the engine managment light appears on the dash.
GaffasCompact is offline   Reply With Quote
Old 12-28-2008, 04:17 AM   #16
paraklas
My Ride: ESS TS2 320ci
And your fuel consumption will increase too
Old 01-02-2009, 08:34 PM   #17
muly
My Ride: 330 sport vert
If the the car is running better with the maf disconnected, the car will be running in limp mode( pre set base map) and the maf is very likely broken hence why it runs better unplugged
muly is offline   Reply With Quote
Old 01-04-2009, 12:51 AM   #18
sirch
My Ride: 330i, 545i
Most MAF are heat sensitive, the more the air flow the more they cool. If you remove the honeycomb to increase flow you will just increase the rate in which the wires in the MAF are cooled, thus reducing performance. In the past I have taken out my MAF and sanded it larger to make reduce the flow the MAF sees while increasing the air flow. The result was an increase in timing and a increase on the dyno, but I it is not as easy as it sounds and other areas need special attention to correctly tune the engine. In all, remove the honeycomb and you could lose performance.
sirch is offline   Reply With Quote
Old 01-04-2009, 09:35 AM   #19
GaffasCompact
it seems to have more power and run better frm stand still. normally from standstill it would b a bit lumpy
Old 01-04-2009, 12:51 PM   #20
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
this thread has a lot of interesting (and some bad) information going around
/_________\
O==[][]==O
