Old 08-08-2008, 03:34 AM   #1
RASCO
My Ride: E46 323i
O2 Sensor Codes
I just replaced my Intake Cam Sensor with the D.I.Y guide on my 2000 323i and the car doesn't stall anymore. I also got the Peake tool to reset the ECU because of the CEL. Now Im throwing some O2 sensor codes:
E3- O2 Sensor Adaptation Limit Cyl#1-3
E4- O2 Sensor Adaptation Limit Cyl#4-6
CA- O2 Sensor Control Limit Cyl#1-3
CB- O2 Sensor Control Limit Cyl#4-6
97- Precat O2 Sensor Short to Ground Cyl#1-3
Do these codes mean I need to replace all my O2 Sensors? I wanna make sure this is the main problem before I go out and buy the parts. I still can't pass smog. Any help is appreciated. Thanks
Rob
RASCO is offline   Reply With Quote
Old 08-08-2008, 05:14 AM   #2
ssm1991
My Ride: 2004 325i
With the 97 code, yes. But it doesn't guarantee it will solve the other 4 codes. You may have other problems that cause those (i.e. vacuum leak, busted MAF, clogged fuel filter, bad fuel pump, etc.).
ssm1991 is offline   Reply With Quote
Old 08-08-2008, 02:48 PM   #3
RASCO
My Ride: E46 323i
How can I check for vaccuum leaks? Any common areas? Thanks. I have 116,000 miles on my car. I got a quote from checker and the bosch precat sensors are going for $150 each. I will try to replace the fuel filter as well.
I just wanna pass smog
Old 08-09-2008, 12:53 AM   #4
sdbimmer
My Ride: 2004 325Ci
you have a 323i right? Those cars use the older 4-wire O2 sensor and is a lot cheaper.
http://www.autohausaz.com/search/pro...xygen%20Sensor
sdbimmer is offline   Reply With Quote
Old 08-09-2008, 06:25 AM   #5
RktJhn
My Ride: 03 E46 330 CI
Mine was throwing O2 sensor codes, mechanic found boot after MAS was leaking and the idle valve was stuck, ran a little over $400. Went to a good non dealership shop. They recomended a smoke test to see if any other vacum leaks, didn't do that, but after several months I have had no codes at all.
RktJhn is offline   Reply With Quote
Old 08-09-2008, 08:17 PM   #6
RASCO
My Ride: E46 323i
Thanks guys..I purchased a new fuel filter, a MAF Hose, and Cleaner at the dealer along with some fresh NGK Plugs. I found a D.I.Y write up here and I'll be working on this tonight. I'll be ordering the O2 Sensors at that website as well. Thanks again.
Rob
Old 08-30-2008, 05:27 PM   #7
330Bryan
My Ride: 2010 BMW E92 Coupe
Any updates?
I've been having the exact same issue.
Same codes with the Peake tool:
E3
E4
CA
Cb
In the past week I've replaced:
All 6 spark plugs with Bosch Platinum+ 4
New oem coil boots
BOTH pre-cat o2 sensors with oem sensors.
BOTH post-cat o2 sensors with Bosch sensors.
Reset using the tool, drive 20-25 miles and the same codes come back.
Pulling my hair out trying to figure this out as I'm due for smog inspection on Monday the 1st and the police near my office really enjoy handing out tickets for inspired stickers since I cannot currently pass.
330Bryan is offline   Reply With Quote
Old 09-22-2008, 01:31 AM   #8
RASCO
My Ride: E46 323i
I still have the same codes E3,E4,CA,Cb...except 97 which seems to be resolved. I replaced the plugs,cleaned the maf, replaced the intake hose, replaced both precat bosch O2 sensors, new fuel filter, Oil change.
It gave me another set of codes with a cylinder misfire on #1 #2 and #3. Im gonna reset the CEL and see if it comes up again. I can't find or hear any vaccuum leaks. Last resort is to take it to the shop tomorrow. Or trade it in for another car.
Old 09-22-2008, 01:35 AM   #9
e4sixxx
My Ride: 2000 328ci
im throwing the e3 and e4 as well ive been trying to figure it out, ive replaced the intake boot aswell.
e4sixxx is offline   Reply With Quote
Old 09-22-2008, 02:32 AM   #10
RASCO
My Ride: E46 323i
Yeah this sucks. I forgot to mention I also replaced the intake Cam sensor and got a new Gas Cap at Desert BMW. It solved the other problems I had earlier. Now Im down to these 4 codes.
I've been searching and found some stuff online that might hopefully solve the problem. I will check these out first before I give in and take it to the dealer this week.
Found this on another thread: Copied and Paste
" Dirty oil will not cause fuel mixture faults. Check the Crankcase vent valve (PCV). With the engine idleing crack open the oil filler cap just barely. If there is a lot of vacuum holding the cap down or the motor starts making a strange whistle/honking noise the valve is bad. Have you checked the throttle boots for tears? You have swapped the Air flow sensor. These symptoms sound like a bad air flow sensor. Have you put new front O2 sensors in the car?"
and
"Just wanted to follow up for anyone that finds this post through a search. The problem ulimately was that the "Idle adjuster" broke. This is number 7 in the attached pic and slides into the side of the intake manifold above the throttle body. The base of the door/gate that rotates to open/close the airflow broke off the the stub that operated it. This was causing a vacuum leak directly into the side of the intake manifold. When I bought a new one at the dealer (~$215+ tax) I was surprised they had it in stock. The parts guy said they had 18 of them on the shelf! So appearenly this is a common thing to break. Two screws and one electrical connector. About a 5-10 min job to replace it."
Old 09-22-2008, 02:48 AM   #11
e4sixxx
My Ride: 2000 328ci
damn im gonna have to check that out it seems that it might be the problem because i still have a whistling noise after i changed the boot. thanks for the info
Old 09-22-2008, 03:52 AM   #12
RASCO
My Ride: E46 323i
Im gonna try out the pcv first. I noticed my check oil level light stays on for a few seconds after I start the car.
Old 09-29-2008, 01:42 AM   #13
RASCO
My Ride: E46 323i
! No luck yet. I added some SeaFoam to the CrankCase and Fuel Tank and the car seems to be running a lot smoother. But the CEL came on again after 5 miles. It would usually come on within 2 miles.
Its down to either replacing the PCV or the #7 Idle Adjuster. I researched the DIY on the PCV and looks too complicated. I can't work with tight spaces. The intake boot alone was a PITA. How much would the dealer usually charge for this? I don't hear any leaks and the car idles just fine.
Old 09-29-2008, 11:15 AM   #14
hummer
My Ride: 2001 330CI
Originally Posted by 330Bryan View Post
Any updates?
E3
E4
CA
Cb
New oem coil boots
My 01 330ci was reading similar codes which are error codes. Try plugging in the Peake and then turning the ignition on. When I did this I got table 19 and codes. Could be you have the same problem?
Old 09-29-2008, 11:34 AM   #15
ken@bimmertools
Is NOT A Mechanic
ken@bimmertools's Avatar
My Ride: F30
Have a look for a detailed how-to post about smoke testing written by Seth from jbeurotech here on the forums. It reads as a little complicated if you're not experienced, but it is not a very difficult procedure. If you cannot do this test properly yourself, save yourself some money and have an experienced tech take care of it. Throwing money at replacing parts that may not necessarily need replacing is not the right approach.
One of the benefits of the BMW specific codes you guys are getting with the Peake tool is that you see exactly what BMW wanted their techs to see. For vacuum leak issues, however, more testing is necessary to find a leak. Having the best codes is a great way to start, but it is just the first step in truly diagnosing the problem.
Seth is very knowledgeable and experienced, and his posts should help you narrow this down.
Good luck!
Ken
Bimmertools is under new ownership! Please welcome Taylor@bimmertools.com.
Click Here to say hi.
ken@bimmertools is offline   Reply With Quote
Old 11-12-2008, 10:20 PM   #16
GermnBlt
My Ride: 323Ci
Send a message via AIM to GermnBlt
any updates on these codes? Anyone
So, how many pounds you push
Photobucket
GermnBlt is offline   Reply With Quote
Old 11-13-2008, 12:00 AM   #17
johnnatalie
My Ride: 330i
had the same thing, replaced intake boots (total of 3) from intake to (but not )mass air flow, replaced air pump hose (left side of engine) and also small hose that runs along valve cover, also replaced 2 hoses off intake boots: problem fixed
johnnatalie is offline   Reply With Quote
Old 11-13-2008, 01:06 AM   #18
GermnBlt
My Ride: 323Ci
done all of them, even replaced a broke/faulty PCV....Still got those 2 codes....i wish i could find a smoke machine, but geez no one in my area has one and half of them look at me like im crazy for asking..haha
Photobucket
Old 11-22-2008, 10:16 PM   #19
reynaldo
My Ride: 2001 325i Sedan
Send a message via Yahoo to reynaldo
Could you please clarify the parts that you replaced? What (3) Intake? Hoses. I have E3 code which is Oxygen sensor adapatation limit Cyl #3
1. So clean the MAF? 2. Replace the elbow tube?
Rey
reynaldo is offline   Reply With Quote
Old 12-27-2008, 11:45 AM   #20
reynaldo
I have no intake boot leaked. Replaced Ignition coil/boots/sparkys (6 of them). Cleaned MAF sensor. Code 0174 or E3 as I mentioned above vanished. I have no error code at all.
