Thread Tools Search this Thread Rating: Thread Rating: 32 votes, 4.97 average. Display Modes
Old 01-25-2011, 12:30 PM   #41
BlackPearl_Custom
My Ride: 318i N42
Send a message via Yahoo to BlackPearl_Custom
sorry to resurrect this thread again, one question here, is it supposed to be able to fold the mirror while the car is running? i've followed this guide but i cant fold my mirror after driving for a while, and i need to shut off the car first to make the fold/unfold fucntion works again
BlackPearl_Custom is offline   Reply With Quote
Old 01-25-2011, 12:38 PM   #42
paraklas
My Ride: ESS TS2 320ci
Yes, that's how the module works, it's using a 60 second timer to do so. Timer starts when it receives power from ignition switched 12v. you can install a cutoff switch (push off/release on) in line with the switched 12v to "trick" the module to think that engine is not running anymore; this will reset the timer to 60 seconds again.
I also think you can just skip the ignition switched 12v supply, since the mirrors work with the always on power but I wouldn't recommend that, as you may accidentally press the fold button while doing 150mph
Old 02-19-2011, 12:09 PM   #43
BlackPearl_Custom
My Ride: 318i N42
Originally Posted by e46addicted View Post
Hi again
3/ The Brown/Red wire :
This wire is intended to be connected to the WHITE wire (Lock 12v signal) of the 54pin connector of the General Module, not to the BLUE wire (Unlock 12v signal). So no Relay or Zeiner Diodes needed here, they will be useless. If you leave the car and lock it (with remote or key in keyhole), if the mirrors are folded they will stay folded, if they are unfolded they will fold upon locking. When you unlock your car, mirrors WILL NOT UNFOLD (German Logic, u don't want to unfold your mirrors on a car that has come and parked very close to yours).
The tricky part here is, if you get in your car, unfold mirrors manually, turn on engine and drive away in less than 60sec, there will be a risk of your mirrors folding when you doors autolock at 20kmh. So be careful with that if you have the Autolock doors at 20kmh activated.
Thanks for your patience and hope it helps
can i tap both white and blue wire so that the mirror can fold up/down when i lock/unlock my car?
Old 02-19-2011, 09:44 PM   #44
TerraPhantm
My Ride: M3 & ZHP
The door modules can be coded to do this without messing with the wiring
Old 02-20-2011, 02:04 AM   #45
BlackPearl_Custom
My Ride: 318i N42
still trying to understand according to e46addicted's writing, the SAM module cant fold down the mirror when you unlocked the car because it only connected to the white wire, so basically im thinking what would happen if i connect the brown/red wire to both of white and blue it should do the fold up and down i think.. thats my thought.. but i dont know wether its safe or not
E46 Modified Car Club
Old 03-02-2011, 03:30 PM   #46
stevoboy
My Ride: E46 Compact
Hey there,
I got a question. The switch you are using is a ...689 with two connectors.
I just bought a switch with the part number 61 31 6 901 383 and it has only 4 pins in total in one connector only. The part information says I need a 61 31 8 373 732 for my car (no memory seats). What's the difference between als the switches and are they interchangable?
stevoboy is offline   Reply With Quote
Old 03-02-2011, 04:13 PM   #47
paraklas
You mean mirror switch? Does the switch you bought have the fold button?
Old 03-02-2011, 04:39 PM   #48
stevoboy
Yes, I mean the switch. But the one I bought got only one connector with 4 pins inside and it is purple. The one shown here is yellow and got two connectors with numerous Pins. So I guess I bought the wrong switch - don't know yet because I haven't removed the door panel yet (wanted to have all parts ready before I drive to the shop).
But what is it with all those switches? How are they different?
Old 03-03-2011, 01:33 AM   #49
paraklas
They are different because of the changes / options on the E46. Memory seats + auto dip function is one switch, facelift E46 with ribbon mirrors is another switch, mirrors with fold option another switch as well.
Old 03-03-2011, 01:37 AM   #50
paraklas
Various switches/Cigar lighter - BMW parts catalog
From what I see here, 383 is not the correct one as it is for cars with memory seats
Old 03-03-2011, 12:57 PM   #51
stevoboy
Yeah, that's what I figured. I thought I could just put the Pins differently. But obviously not. So I just sell the switch and buy the other one at the dealer .
Old 05-27-2011, 07:14 AM   #52
younGun392
My Ride: S.L.O.W
Excellent writeup! I'm doing this as soon as I get the mirrors
younGun392 is offline   Reply With Quote
Old 06-01-2012, 06:14 PM   #53
Tiag46
My Ride: e46
Where else can I buy a SAM Module?
They seem to be sold out on the innoparts website.
Its the only thing I need to do the retrofit.
*Wrecking* - Heaps of parts available.
http://forum.e46fanatics.com/showthread.php?t=1103190
Tiag46 is offline   Reply With Quote
Old 06-01-2012, 09:46 PM   #54
TerraPhantm
My Ride: M3 & ZHP
Do you have memory seats? If so, just recode your existing modules. Like so:
Old 06-02-2012, 04:29 AM   #55
always15nagi
My Ride: x
Hi! I know this is random, but I was wondering if you know where to purchase side view mirrors for 2001 330ci in this forum because I recently broke my man's side view mirror and I wanna repent...lol it would be very much appreciated if you can help me with this issue. thanks!
always15nagi is offline   Reply With Quote
Old 06-03-2012, 09:48 PM   #56
Alex323Ci
My Ride: M3 & 323Ci (sold)
for Used look in here:
http://forum.e46fanatics.com/forumdisplay.php?f=31
or here:
http://forum.e46fanatics.com/forumdisplay.php?f=76
GL
Old 06-05-2012, 03:20 AM   #57
Tiag46
My Ride: e46
Anyone know where I can get a SAM Module, or something similar?
Innoparts are no longer producing them.
Old 04-18-2013, 03:10 PM   #58
Arty
My Ride: 1999 328i
eBay.
you have two choices
http://www.ebay.com/itm/ZMC-Auto-Fol...-/121003932537
http://www.ebay.com/itm/Universal-Sm...-/111016438613
The appear to be the same device only inverted, however the ZMC one appears to have dip switches to select how they unfold, which the AER may not have.
Personally I want them to fold on ACC off, and manual unfold/fold via the button. This is because I have a tight garage and don't want auto unfolding.
These modules also appear to be a bit smarter, with code to stop the mirrors folding when driving and with repeated door operations.
However the schematic seems to show the need for two lines from the switch rather than the single momentary fold/unfold button the BMW uses, which would be a problem for retaining the original switch function.
I also had a browse through Alibaba and found the innoparts but the MOQ is 100 pieces. I didn't have time to investigate deeper.
http://www.alibaba.com/product-gs/61...ge_System.html
Arty is offline   Reply With Quote
Old 04-18-2013, 03:26 PM   #59
dre8119
My Ride: destroys my wallet
Excellent DIY!! I am truly grateful for this!!
dre8119 is offline   Reply With Quote
Old 04-18-2013, 04:11 PM   #60
Tiag46
My Ride: e46
Thanks for the above Arty. Yeh i noticed the same thing with the above modules.
All I want is to fold/unfold at the push of the button on the switch, so not sure if they will suffice.
