Old 05-14-2002, 10:17 AM   #1
Ed328ci
Too many rock chips!
My Ride: E90 325i
Send a message via MSN to Ed328ci Send a message via Yahoo to Ed328ci
Brakes: "85% Front, 35% Rear" This is amount of brake pad that still there, right?
Why is there such a huge difference between the wear of on the rear verse the front brakes? Shouldn't it be the other way around?
Aprox. how many more miles between I have to change the pads?
I just have to change the brake pads, right? What high performance DUSTLESS brake pads would you recommend?
What good BMW brake shop would you recommend in the Vancouver area?
Thanks!
Ed
Ed328ci is offline   Reply With Quote
Old 05-14-2002, 10:22 AM   #2
vinnymac
St. Louis BMW Fanatic
My Ride: 2011 335is
Send a message via AIM to vinnymac
Wow, that is a strange breakdown of your pad-wear...
You should get Axxis dustless pads from www.justbmws.com ...should be around $70 for the entire car. I've been running them for about 20k miles and love em! No dust at all and my wheels look great!
vinnymac is offline   Reply With Quote
Old 05-14-2002, 10:25 AM   #3
dennisf
My Ride: BMW 330Cic
Question Why?
I'm wondering why BMW doesn't fit those brakepads themselves on our cars? Is it the costs? Are they a lot more expensive than OEM pads???
dennisf is offline   Reply With Quote
Old 05-14-2002, 10:26 AM   #4
sergiok
Because when you hit your brakes the weight shifts to the front of the vehicle... thus the front brakes need to do more 'work' in order to stop the car.
If you ever get a big brake kit, it must be matched to your rear calipers if not, you will have even more front brake bias. In other words, your rear brakes won't be doing enough braking and when you slam on the brakes, the car will lunge forward.
sergiok is offline   Reply With Quote
Old 05-14-2002, 12:08 PM   #5
Ed328ci
My Ride: E90 325i
Then why is there more pad left on the front wheels (85% vs 35% rear). Perhaps the 85% number represents the amount of pad used? Sounds strange.
Ed
Old 05-14-2002, 02:21 PM   #6
vinnymac
My Ride: 2011 335is
That's a possible explanation...
Ed
even though I was always given brake wear in % pad life remaining...not vice versa...strange indeed.
Old 05-14-2002, 02:23 PM   #7
Karl
Engineer
My Ride: 2001 330xi
Front pads are usually a lot thicker than rear pads because of front brake bias, therefore, your rears *may* wear down more quickly. I don't know how it is with BMWs, but on my mother's Accord, the rear pads wear down (percentage-wise) about 1.5x as fast as the fronts do.
Karl is offline   Reply With Quote
Old 05-14-2002, 03:15 PM   #8
topazmania
Ogler of Women and Mods
My Ride: '01 M3 cab, '90 325i
I think those numbers are for the amount of pad used. There's no way your rears could wear that much more than the fronts unless you constantly drive around in reverse.
topazmania is offline   Reply With Quote
