Thread Tools Search this Thread Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Old 08-09-2008, 06:31 PM   #1
j0n228
My Ride: 2001 bmw 330i
how to improve mpg
hi guys i got 120k miles on my car and im getting 17.5 mpg i wanted to know what the best thing to do to help improve mpgs besides driving slower like what can i change to help improve this and get it to where its sapouse to be like 23 mpgs
j0n228 is offline   Reply With Quote
Old 08-09-2008, 06:36 PM   #2
reez777
My Ride: 325i SPORT AUTO '04
I'm not sure if this will work for all E46 owners, but I increased my MPG from 20 to 25.5 by doing two things
i) taking the spare wheel out of the car.
ii) taking my girlfriend out of the car.
Weight Loss of the two items combined was enough to get my MPG shooting up.
reez777 is offline   Reply With Quote
Old 08-09-2008, 06:37 PM   #3
j0n228
iight can someone be a better help
Old 08-09-2008, 06:40 PM   #4
kartele
My Ride: 2000 323ci SOLD!
check your tire pressure, I filled my tires on my daily driver a couples of psi below the max. got me some more mpgs. Rides a little rougher but its just my work car so its cool
kartele is offline   Reply With Quote
Old 08-09-2008, 07:04 PM   #5
xxepoccaxx
My Ride: 04 MB_ZHP
Send a message via AIM to xxepoccaxx
if you are approaching a red light from a good distance, just free ride it to the light, chances are it will turn green by the time you approach the light without coming to a halt and accelerating off.
xxepoccaxx is offline   Reply With Quote
Old 08-09-2008, 07:38 PM   #6
Alex323Ci
My Ride: M3 & 323Ci (sold)
tire pressure and spark plugs.
A/C and windows up after 40mph. no A/C and windows down less than 40mph.
gear oils changed to high grade synthetics helped some too.
Old 08-09-2008, 07:49 PM   #7
CirrusSR22
My Ride: E36 318ti, E46 323it
Do you still have the original oxygen sensors at 120,000 miles? Fresh ones help.
CirrusSR22 is offline   Reply With Quote
Old 08-09-2008, 08:01 PM   #8
gferil
My Ride: 06 Z4MC, 2000 323ci
Also, if you are going to do spark plugs (which helped me to improve my mileage a bit and improved response too), then you might as well clean the MAF sensor, replace the fuel filter, and if you haven't already, replace the air filter. Plus what all the other people said above...
gferil is offline   Reply With Quote
Old 08-09-2008, 09:11 PM   #9
GrayGhost
My Ride: 2004 330Ci
Reduce the use of the biggest gas waster in your car... the brakes. Every time you get on the brakes some amount of gas is effectively going up in wasted heat. Watch traffic and signals way ahead and drive so as to miminize the need to use the brakes. Coasting to a stop and then accelerating (gently) away cost very little gas, but staying on the gas until you have to get on the brakes hard to stop is just throwing gas away.
I average 25 - 27 mpg in suburban driving and 32 - 33 on the interstates.
2004 330Ci: Sport Pkg, TiAg, gray leather, UUC Swaybars, H&R Springs, Blistein shocks, UUC SSK, Autobaun miles (Euro.delivery)
GrayGhost is offline   Reply With Quote
Old 08-09-2008, 09:25 PM   #10
sandman0615
My Ride: loaded 2002 330xi
^ 27 city thats pretty good im usually 22mpg. i picked up my boy at laguardia about 90 mins away trying to get good mileage and i clocked 37mpg i couldnt believe it
sandman0615 is offline   Reply With Quote
Old 08-09-2008, 09:37 PM   #11
Squeak
My Ride: M3 -> 135
Send a message via AIM to Squeak
using GOOD gas also improves millage. dont use regular!!
Squeak is offline   Reply With Quote
Old 08-09-2008, 09:47 PM   #12
SteveX82
My Ride: 2001 325i
Funny...my last fillup on regular netted 31.9mpg. YMMV (pun)
SteveX82 is offline   Reply With Quote
Old 08-09-2008, 09:51 PM   #13
Squeak
My Ride: M3 -> 135
REALLY, hmm i just heard that some where. o well
but you put regular IN A BMW.... TISK TisK
Old 08-09-2008, 10:32 PM   #14
TheBrooklynZoo
My Ride: '02 325ci
what does that mean?
TheBrooklynZoo is offline   Reply With Quote
Old 08-09-2008, 10:33 PM   #15
GoingNuts
Just Nuts
My Ride: 2004 330Ci
You can buy a driver upgrade to get better mpg. An upgraded driver should get around 25mpg in city driving. The upgrade can be DIY'ed and will cost about 50% of your ego. But you can keep the AC on at full blow at all times to keep the bruised ego cool.
GoingNuts is offline   Reply With Quote
Old 08-09-2008, 11:29 PM   #16
blingman
My Ride: 01 330ci manual
It means to use air conditioner and roll up all the windows if your driving 40mph or higher and if not going that fast, roll windows down and turn air conditioner off to save gas. At high speed, having all the windows up will reduce drag even though you will have the air conditioner on, it will still save gas in the long run.
blingman is offline   Reply With Quote
Old 08-09-2008, 11:33 PM   #17
NOVAbimmer
My Ride: E60M
regular gas isn't going to hurt it
NOVAbimmer is offline   Reply With Quote
Old 08-09-2008, 11:38 PM   #18
kurtnhl
My Ride: 330i
I have always thought spending money on things that are not part of maintenance was pointless, since you could spend that money on gas. The only thing that I have noticed that helps is changing ones driving style. Maybe instead of trying to save money on guess, cut out other needless spending in your life and use that for gas money. (not saying that you have any)
kurtnhl is offline   Reply With Quote
Old 08-10-2008, 10:05 AM   #19
maxm50
My Ride: 1999 Steel Blue 328i
Switching over to using proper punctuation increased my mileage by at least 2-3 mpg.
maxm50 is offline   Reply With Quote
Old 08-10-2008, 10:28 AM   #20
jamesthebikeguy
My Ride: Is a ugly POS
Send a message via AIM to jamesthebikeguy
Check those O2s
I bet the pre-cats could use some love.
jamesthebikeguy is offline   Reply With Quote
