Sponsored by BimmerWorld
Old 08-09-2008, 08:47 PM   #1
chay2263
My Ride: 330i Sport Package
What's causing my passenger side tire to be toed in at the top?
I went to Firestone today to get a lifetime alignment and after about 10 mins the guy comes up and shows me that my tire is toed in at the top. He claims that it is a strut but the cars suspension and handling feel rock solid besides a slight pull to the left since the tire is toed in. I don't think its a strut. You guys have any idea of what it may be?
chay2263 is offline   Reply With Quote
Old 08-09-2008, 09:20 PM   #2
maxm50
My Ride: 1999 Steel Blue 328i
First off, there is no such thing as being "toed in at the top". Toe-in means that the front edge of the wheel is more inboard than the rear edge. Camber is probably the term you're looking for - negative camber means the top of the tire is more inboard than the bottom.
As far as what the cause is, it really depends. First off, is it the front or rear? If it's the front, I suppose a bad strut mount could cause the top of the knuckle to be tilted inboard, thus causing too much negative camber. Our cars use a MacPherson strut design, meaning that the strut is an actual structural member of the suspension. In theory, a bent strut could cause too much camber. Likely? I seriously doubt it.
If it's in the rear, then there is now way that a bad strut would cause camber issues. At all.
I'm gonna go with Accam's Razor on this one, and say that the most obvious solution is probably the correct one - the dude at Firestone probably doesn't know what the hell he's talking about.
Anyway, if you could give us some more info and/or pics, we could probably help you out more.
maxm50 is offline   Reply With Quote
Old 08-09-2008, 10:45 PM   #3
chay2263
Its in the front and I will try to post some pics tomorrow...
Old 08-10-2008, 09:25 AM   #4
jpr
My Ride: '99 323i
It's Occam's Razor BTW, but you've got the correct idea. The tech is most likely confusing toe and camber which certainly doesn't inspire a lot of confidence in his analysis. Besides, a certain amount negative camber is a good thing and you tire should be "toed in at the top"
jpr is offline   Reply With Quote
Old 08-10-2008, 09:52 AM   #5
budman
-not a mod-
budman's Avatar
My Ride: ..
is the car lowered? camber plates will help get the camber back to spec
-Gunnar
budman is offline   Reply With Quote
Old 08-10-2008, 11:02 AM   #6
JohnBlaze
My Ride: Black Sunshine
you may have a bent strut tower,
look for cracks or slight bends at the top of the tower,
happened to me...
05 ZHP w/Epic tuned s54, Euro headers&Sect.1, Dinan 3.91 and a lot of other things built by Road Race Technologies
JohnBlaze is offline   Reply With Quote
Old 08-10-2008, 03:41 PM   #7
maxm50
Thanks for the spelling correction
How did you manage to bend your strut tower?? Yikes!
