Driveline, Engine & DME Tuning
Talk about driveline improvements, NA tuning and DME tuning your E46 BMW here. This includes diffs, intakes, exhausts, chips, software and OBD tuning. |
#61 | |
My Ride: 04' 330ci & 99' 540i
I originally took mine out because it saves 7 lbs off the front of the car and looks a lot cleaner in the engine bay with it out. I left it in my basement thinking I could just re-install it once inspection time comes around, but my basement got flooded during a storm and pretty much destroyed it....so now I'd rather get a simulator than spend all that money on a new one.
#62 | |
#63 |
My Ride: have 5 doors and FI
that sucks
![]() /_________\ OO=[][]=OO |
#64 |
Contact them. They will do it but unless you really have a special car or special needs it isn't worth it. They even told me that. But the more built your car is and the higher your desire to stay legal becomes, the more they look like the only option!
#65 |
contact eurocharged, as well. they tune all sorts of e46's
#66 | ||
So now I wonder, why would BMW add a MAF to the SAP if it wasn't to monitor whether it was working or not? And if that was the case, does that mean the DME isn't checking the O2 sensors as a way of monitoring the SAP? And then finally, does that mean that in the ms45.1 cars removing the SAP is as easy as making a SAP MAF sim, and there's no need to touch the O2 sensors at all? If only I could find a document like the one TxZHP04 posted but for the ms45.1....
2003 BMW 330i ZHP BMW Performance Intake and SSK - Headers - Magnaflow - ESS Tuning Turner Motorsports Pullies and Reinforcements - H&R Spacers - StopTech - And more... ![]() Last edited by rkneeshaw; 01-28-2013 at 09:26 PM. |
#67 |
My Ride: ZHP Custom Stage 3.5
I do have a question about the SAP Procedures...
I know that during cold start up. It will come on and my AFR will hit 22 for a few seconds and then turn off. Then I see my Timing goes all over the places for a good 10-15 sec and then go away. Do any of you guys experience this? -Trip
..::|TrippinBimmer's Boost Build with Cool Parts|::.. 4**whp/3**tq SAE Corrected Last edited by TrippinBimmer; 01-28-2013 at 09:39 PM. |
#68 |
well I think thats what we're trying to figure out; if we can disable that SAP system just by using a SAP MAF sim. It doesnt appear that the SAP sims designed for the MS43 DME's would work because they dont address the MAF on the SAP found in our MS45.1 cars
2003 BMW 330i ZHP BMW Performance Intake and SSK - Headers - Magnaflow - ESS Tuning Turner Motorsports Pullies and Reinforcements - H&R Spacers - StopTech - And more... ![]() Last edited by rkneeshaw; 01-28-2013 at 09:40 PM. |
#69 | |
..::|TrippinBimmer's Boost Build with Cool Parts|::.. 4**whp/3**tq SAE Corrected |
#70 |
Maybe thats an option. I did ask ESS a while back and they said they could not turn off the SAP monitoring, but someone else said evolve or eurocharged might be able to do it. Being that your boosted might complicate things further. Maybe ask AA if they can turn off the SAP monitoring or tune around it somehow?
2003 BMW 330i ZHP BMW Performance Intake and SSK - Headers - Magnaflow - ESS Tuning Turner Motorsports Pullies and Reinforcements - H&R Spacers - StopTech - And more... ![]() |
#71 | |
My car is in the garage of the winter so I'm going to wait for good weather to test this..... unless anyone else in the southern states wants to give this a shot?
#72 |
I would do it but mine is boosted. So wont work...
#73 |
For you guys with MS45.1 that want to remove the SAP, we can use the same concept that we did with the MS43 with one additional circuit. So for they MS43 we used two resistors (75ohm I believe) to pull the pre-cat O2 sensor signal to ground through a DPDT relay and make the voltage go down to .200V.
So if you look at the small MAF you have three wires, 5v+, ground and a signal wire. If you measure between the signal wire and ground at rest and upon SAP activation you might find about .025V at rest and about 3.50V at normal pump flow. If you take a DPST relay and use is to switch between two resistors that come from the 5V+ wire and have a value that gives you a voltage drop down to the level you need. Once you find the right values your DME will see the rest voltage because it is always checking the MAF circuit for disconnection. And when triggered you will have the voltage needed to simulate flow. With the MS45.1 it's way more work to go through for the 7lbs. and the cleaner engine bay, but honestly I would be doing it too. Maybe just for the challenge. For the ultimate challenge the SULEV cars with their wide-band pre-cat O2 sensors would be a real tough one to fake. |
#74 |
F1004fun, do you know for a fact that the MS45.1 DME is checking pre-cat O2's AND the SAP MAF for proper SAP function? I'm entertaining a theory that the O2's might not be monitored for proper SAP function with a MS45.1 DME because it seems that would be redundant as it is being done by monitoring the SAP MAF....
#75 |
I installed M54 engine in E36 chassis and I do not run any of the emissions stuff. I am using MS42 and MS43. But for MS45 I did not get that far into it.
It can all be deleted from the program and it won't trow check engine light, emissions rediness will always stay 'not ready' for the deleted components. |
#76 | |
#77 |
well that sucks.
