Old 08-11-2008, 08:53 AM   #1
jjp201
My Ride: 00 328ci
Replacing Hydraulic A/C Tensioner Pulley
How do you R&R the Hydraulic A/C tensioner pulley. I got the part (#11281748131) from the dealer and went to replace but couldn't get the old one off. After removing the dust-cap, I wrenched on the nut with a torx bit. When I turn it clock-wise it loosens the tension but should I turn it counter-clockwise to remove it?
jjp201 is offline   Reply With Quote
Old 08-11-2008, 11:24 AM   #2
hummer
My Ride: 2001 330CI
It's an allen wrench head and yes turn it CCW.
Old 08-11-2008, 01:00 PM   #3
ssm1991
My Ride: 2004 325i
There's no hydraulic tensioner for the A/C belt. Were you talking about the tensioner pulley for the engine belt (for water pump, alternator, power steering pump)? Others just call it the serpentine belt. The part number you mentioned is the pulley for the hydraulic tensioner of the engine belt. Yes, it gets confusing at times ...
If you were trying to service the tensioner pulley for the A/C belt, then you'll have to replace the whole tensioner. There's no replacement just for the pulley.
And yes, CCW using AFAIK Torx T-45 or T-50, not an allen wrench.
ssm1991 is offline   Reply With Quote
a/c, hydraulic, pulley, tensioner
