Sponsored by BimmerWorld
Old 08-12-2008, 03:22 PM   #1
kylezee
My Ride: 2004 Jet Black 325XI
Send a message via AIM to kylezee
OEM Sports Package
I have a 2004 325Xi Sedan with the sports package. Do i have coilovers?Is my suspension adjustable? Because when i got new tires and i had goodyear put them on i notices now that my passenger side sits higher then the drivers side
any ideas?
kylezee is offline   Reply With Quote
Old 08-12-2008, 03:35 PM   #2
eBean
My Ride: '04 330ci
Send a message via AIM to eBean Send a message via MSN to eBean
No
Sponsored By: Carrozzeria Design
eBean is offline   Reply With Quote
Old 08-12-2008, 03:36 PM   #3
simsima325
'a certain moderator'
simsima325's Avatar
My Ride: Honda Civic
No
-Brendan
Old 08-12-2008, 03:45 PM   #4
Chris-TK
My Ride: Mk VI GTI
No you don't have adjustable coilovers. You have a spring/shock combo.
K.
Chris-TK is offline   Reply With Quote
Old 08-12-2008, 04:25 PM   #5
kylezee
so is are they adjustable?
Old 08-12-2008, 05:27 PM   #6
Chris-TK
My Ride: Mk VI GTI
No
K.
Old 08-12-2008, 07:00 PM   #7
shointake
My Ride: 2001 e46 330i
NOT ADJUSTAbLE
OEM sport Package is Upgraded Sport TUned SHocks.. and Sport Springs that Lower ur ride .5 of a Inch.. like Hence the EIBACH PRO KIT
SInce one side is higher then the other.. its either.. u BLEW a shock.. or u BLEW A SHOCK..
cause if u swap out suspension or jack the car really high for the springs to get off the base of the shock eer shock tower.. then the springs have to settle again.. to be all perfect all around..
try driving for a Bit and hit some pot holes.. and bumps.. it should get u back to OEM height all around.. nOw if u dont.. its a BLOWN SHOCK!
shointake is offline   Reply With Quote
Old 08-12-2008, 07:54 PM   #8
maxm50
My Ride: 1999 Steel Blue 328i
Originally Posted by shointake View Post
NOT ADJUSTAbLE
I don't even know where to begin with this...
maxm50 is offline   Reply With Quote
Old 08-12-2008, 08:01 PM   #9
jaymar88
My Ride: Acura
any ideas?
All bimmers have "coilovers".. A spring coil over a strut. What you might be thinking of are adjustable treaded struts or spring collars. In that case no. You more than likely DONT have threaded adjustable "coilovers" (unless you bought the car with them previously installed)
First.. How off is the pass' height from driver's? Second, what is the condition of the suspension as it stands? all stock high mileage? Lastly, if you don't know where to begin, I'd take the car to a reputable mechanic and have them inspect all the strut mounts (both front and rear) the bushings, springs(which have been known to crack) and finally the struts and shocks (which are probably already blown)
jaymar88 is offline   Reply With Quote
Old 08-12-2008, 08:02 PM   #10
k7780446
My Ride: 323i
so if it sits higher on one side then it could be blown?
i have a 330ci that was hit on the passenger side and raplaced the tower and fender ect....
now that side sits high so is the shock needing to be replaced?
all is rebuilt correctly what do you think
5492_121783803182_586518182_2342960_2124492_n
k7780446 is offline   Reply With Quote
Old 08-12-2008, 08:24 PM   #11
maxm50
Stuff like this is nearly impossible to diagnose over a forum. Suspension ride height differences could be due to something as simple as variance in the springs to something as scary as bent suspension components. There's no way to tell without a close up inspection.
If you don't feel comfortable diagnosing it, take it to someone who is. K77, in your case, I would guess that either the shock tower was not correctly repaired or that the newer spring on that corner simply doesn't match the others in age (obviously), ride height, or spring rate.
Old 08-13-2008, 11:49 PM   #12
kylezee
Thanks a lot guy i think i'll have some one take a loot at it.
Old 08-24-2008, 06:32 AM   #13
shointake
Dont hate maxm50
Jealous i cant type LOL
Old 09-10-2008, 12:09 AM   #14
kylezee
test
Old 09-10-2008, 12:09 AM   #15
kylezee
nb
suspension
