Sponsored by BimmerWorld
Old 08-13-2008, 06:52 PM   #1
kaotek323i
My Ride: red 1999 323i
real bad camber
hey guys. i have tokico blues and h & r sport springs on my car. i checkd and my tires are getting really ate up on the inside of the tires. what do you guys recommend i get to fix my issue. do i need a complete front camber plates and all that? rear camber arms?
1999 BMW 323i... MR. CARBON FIBER
raceland coils, ACS Front Tower bar-Rotora Rear, 19's 8.5 front & 9.5 rear,
Carbon Fiber- kidney grill, shark fin, headlight eyebrows/inner trim, rear window wing, acs mirrors, b-pillars, front splitters, Oem hood, Csl trunk, gas lid, interior trim
VF stage1, v2 compressor w/ v1 internals, ebay headers
kaotek323i is offline   Reply With Quote
Old 08-13-2008, 07:54 PM   #2
jpr
My Ride: '99 323i
Just get an alignment and cut back on the toe settings. You do not need camber plates or arms.
jpr is offline   Reply With Quote
Old 08-13-2008, 08:05 PM   #3
kaotek323i
i got an alignment a few months ago. its mostly in the rear that has the most problem
Old 08-13-2008, 08:36 PM   #4
jpr
My Ride: '99 323i
Then try getting a good alignment?
You've got too much rear toe.
Old 10-22-2008, 03:28 AM   #5
-Oli-
My Ride: 328Ci
my car is lowered at the rear and there is a camber problem on the rear meaning that tyres are wearing more on the inside. Is it possible to straighten these out and keep it lowered so that the tyres is in even contact with the road. i asked a mechanic and he said that with a lowered car you need to live with the wheels on a bit of an angle??
thanks
-Oli- is offline   Reply With Quote
Old 10-22-2008, 03:31 AM   #6
Bimmer Dude Xi
My Ride: 03 325XI 07 ZX-6R
Send a message via AIM to Bimmer Dude Xi
thanks
You need to buy rear adjustable control arms to fix the negative camber caused by the lower springs
|Dinan High Flow Air Box|Eibach Pro Kit|Koni Sport|UUC Strut Barbarian|UUC TSE3|UUC Underdrive Pulleys|18" VMR V710|
|BMC Race Air Filter|CRG Spectrum Levers| Galfer Steel Braided Brake Lines|Volar Motorsport Spiked Frame & Bar-end Sliders|
Bimmer Dude Xi is offline   Reply With Quote
Old 10-22-2008, 03:38 AM   #7
Bimmer Dude Xi
Since you drop your car, you given yourself negative camber, meaning the top of the tire points inward and also rides on the inside of the tire. To fix this you need to buy camber plates for the front and adjustable control arms for the rear. Then you go for another alignment.Then you're set.
He does not have too much rear toe. Toe does not cause the tire to get eaten up on the inside. Too much negative camber causes that.
Old 10-22-2008, 04:05 AM   #8
-Oli-
My Ride: 328Ci
are adjustable control arms expensive? do the dealers supply them?
Old 10-22-2008, 05:05 AM   #9
Eurobahn BMW
Eurobahn BMW
Eurobahn BMW's Avatar
My Ride: BMW Greensboro
the rear doesnt look low enough to be too agressive for the RTA to not be adjusted for camber properly.
and the front, i supposse the only thing to do is get camber plates.
Eurobahn BMW MINI Mercedes Benz Audi of Greensboro is your local independent BMW Greensboro We offer BMW service at the dealer-level Service & expertise at a fraction of the cost at our BMW Greensboro dealership.
Eurobahn BMW is offline   Reply With Quote
Old 10-22-2008, 08:12 AM   #10
jpr
My Ride: '99 323i
BZZZZZT!
I'm sorry, the correct answer is that the rate of tire wear is primarily determined by toe. Fix the toe settings and you can run plenty of negative camber without having a wear issue.
Both camber and toe are adjustable front and rear on the E46. Unless one's car is completely slammed you will have enough adjustment range to get a good alignment without using aftermarket parts.
As for camber plates and adjustable control arms, the main reason to get them is if you want MORE camber than you can get from stock adjustments. The second reason to get them is to make it quicker and easier to adjust your camber. This is especially handy when you want to change your camber settings in response to the tire tread temp profile you are getting on the track that day.
But thanks for playing!
Old 10-22-2008, 08:57 AM   #11
-Oli-
My Ride: 328Ci
thanks mate. i will get it to the garage that said it was possible in the first place just wanted to check that alignment can be done in the rear, as mine def isn't completely slammed.
Old 10-22-2008, 10:03 AM   #12
jpr
My Ride: '99 323i
No worries.
For reference, camber is a good thing and for general street use the rear should be in the range of about -1.5 to -2.1 depending upon preferences and the load condition of the car at the time you take the readings. For the front, a reasonable range is about -0.5 to -1.2 with the same caveats.
Old 10-22-2008, 10:07 AM   #13
howie
My Ride: CLK55 AMG, E90 335i
Send a message via AIM to howie Send a message via Yahoo to howie
jpr > bimmer_dudeXi
howie is offline   Reply With Quote
Old 10-22-2008, 11:06 AM   #14
n2Bimmer
My Ride: Loves Corners
well what are you expecting when your slammed in the back, you need to have an allignment shop fix the camber, or get a camber kit if you know your tires wont rub on the fender when you fix the camber.
Old 10-30-2008, 04:13 PM   #15
keso
My Ride: 2000 323i SP
I got the same problem today, the wheel allignment shop said to get a front camber kit - coz the car have -2.5 camber both sides and they cannot do anything w/out the front camber kit. The rears are fine and they set it to specs. Do I need a front camber kit? This summer I just replaced my control arm(mielke)/aftermarket bushing and my setup is H&R/Bilstein(sport) combo running 18" wheels. The shop is asking for 4hr job + allignment again after the install of the camber kit.... What do you guys think? help!
keso is offline   Reply With Quote
Old 10-31-2008, 01:56 AM   #16
Bimmer Dude Xi
http://www.aa1car.com/library/tire_wear.htm
Lets be serious. Its obvious here. Lowered suspension and inner tire worn down. Toe unlikely. Its camber. I'd like to see the result of the alignment, before and after.
Old 10-31-2008, 05:21 AM   #17
elite53
My Ride: Twin Screwed 325Ci
Have them punch out the factory alignment locating pin on the top of the struts and adjust your camber. If they don't know what your talking about go somewhere that knows BMW's. You should definately be able to get your car within spec with the setup you are running.
elite53 is offline   Reply With Quote
Old 10-31-2008, 05:34 AM   #18
elite53
So are you trying to imply that the only change in suspension geometry that takes place when lowering a car is the camber setting? If so, you may want to read a little more about the subject. Toe and camber both will cause some tire wear but camber does so to a much lesser extent than toe.
Old 10-31-2008, 06:39 AM   #19
dubplaya
My Ride: a car
Send a message via AIM to dubplaya
Then why are many of us rocking good amounts of camber without tread wear issues?
Toe is a leading factor of tire wear.
dubplaya is offline   Reply With Quote
Old 10-31-2008, 07:08 AM   #20
Eurobahn BMW
Eurobahn BMW
+1 learned about this yesterday when I was getting my alignment. Got everything to spec. Rolls great!
At first I was like, ummmm i think that might belong there.... but he assured me and showed me another car that happened to come in at the same time and same thing happened to theirs and they said it was A okay!
