Sponsored by BimmerWorld
Old 10-31-2008, 08:41 AM   #21
shady3one3
Banned
shady3one3's Avatar
My Ride: gets replaced soon.
Send a message via AIM to shady3one3
Lowering a car affects toe as well as camber. Just because the car is lowered doesnt mean camber is wearing the tires.
I run -3.5* front and -1.5* rear camber....no tire wear issues. At all. Ever. Across a range of different tires.
Just get an alignment and fix your toe. If the alignment shop can't get close enough to acceptable spec, you've got a bent arm or badly torn bushing somewhere.
shady3one3 is offline   Reply With Quote
Old 10-31-2008, 11:50 AM   #22
keso
My Ride: 2000 323i SP
Thanks much to all replied!
i'm gonna look at it this weekend.....what you say maybe the bilstein, my front end looks like it's too low and cupping the tires. So, definitely camber kit is out of the question....coz most here have the same set up in their car with no camber kit installed, right?
Bimmer Dude Xi...where you go for alignment(NYC)?
keso is offline   Reply With Quote
Old 10-31-2008, 12:48 PM   #23
Bimmer Dude Xi
My Ride: 03 325XI 07 ZX-6R
Send a message via AIM to Bimmer Dude Xi
I used to do my own alignments when I used to work in Strauss.
I recommend Bimmer Clinic, I hear a lot of good things about them guys. They are located in Elizabeth, NJ.
|Dinan High Flow Air Box|Eibach Pro Kit|Koni Sport|UUC Strut Barbarian|UUC TSE3|UUC Underdrive Pulleys|18" VMR V710|
|BMC Race Air Filter|CRG Spectrum Levers| Galfer Steel Braided Brake Lines|Volar Motorsport Spiked Frame & Bar-end Sliders|
Bimmer Dude Xi is offline   Reply With Quote
Old 10-31-2008, 09:45 PM   #24
shady3one3
Banned
shady3one3's Avatar
Check your tire pressures as well.
Old 10-31-2008, 10:00 PM   #25
brewster240
My Ride: 02 325it, 95 m3
i wouldnt go where he recomends.
also have them check your trailing arm bushings.
they can affect your tire wear if the are worn, and the toe is changing drasticly between acceleration, braking, etc.
they have also been known to not be centered properly, and not allowing the toe adjustment to come into spec.
yadda yadda yadda
brewster240 is offline   Reply With Quote
Old 11-01-2008, 02:13 AM   #26
Bimmer Dude Xi
yadda yadda yadda
HAHA He must be a comedian. Don't go where I recommend.
Do you even know about Bimmer Clinic. If not, look them up and see there reputation.
Old 11-01-2008, 03:09 AM   #27
brewster240
the reason i said that is because you said you used to do your own alignments, yet you dont even know how rear toe affects tire wear vrs rear camber.
its a valid point.
im not a comedian, im a bmw trained technician.
