Old 08-14-2008, 12:57 PM   #1
hoveringuy
My Ride: e30
Tech question: head coolant flow
I've been trying to figure out how the M54 head is different than the earlier M50/M52 heads in regards to coolant flow. I've seen plenty of references to the fact that "BMW redesigned the coolant flow...".
Does anyone have the details on how it is different and why?
hoveringuy is offline   Reply With Quote
Old 08-16-2008, 01:17 PM   #2
hoveringuy
My Ride: e30
No one knows?
Old 08-16-2008, 01:20 PM   #3
Snik
Snik's Avatar
My Ride: IR M3 Vert.
listen to me.
IT WONT WORK.
i have a buddy thats a BMW tech, he has a 528iA with the M52TU, he acquired a M54 head. this is what he found after pullin goff his entire head. the bolts and stuff line up perfectly, but the cooling jackets DO NOT... so no, the two are not interchangeable.
youre welcome
Do you ride a sportbike?
Old 08-17-2008, 10:14 AM   #4
hoveringuy
My Ride: e30
Originally Posted by snikwad View Post
listen to me.
IT WONT WORK.
youre welcome
Did I say I was trying to put an M54 head on an older block? I'm not stupid. I have an M54 head going on an M54 block, I'm pretty sure that will work.
So back to my original question... how is the coolant flow path different on this head??
Old 08-17-2008, 12:13 PM   #5
Snik
Snik's Avatar
if if its the same head why wouldnt it fit?
the M54 head flows better thats why he tried it, and the block is the same.
Old 08-17-2008, 01:08 PM   #6
hoveringuy
My Ride: e30
The block has stayed almost unchanged since the M50 first came out. Most of the changes have been up in the head. The M52tu was the first head that didn't fit on the old block because of the change in the coolant layout. The M50 had the spider hose that distributed coolant to the cabin and the resevoir tank.
The M54 no longer has a spider hose and I don't think it has a connection at the back for the heater core.
I know that valve geometry has changed on it with higher lift and I'm sure it flows better because of it.
I'm interested in knowing how the coolant flow through the head has changed from the earlier heads. Does it go a different direction? Has a new coolant passage been incorporated? If they changed it was it for power, reliability or emissions?
Old 08-17-2008, 01:20 PM   #7
Snik
Snik's Avatar
ohhhh, i read wrong, my bad, i thought you were comparing m52 to m54 only.
Old 08-26-2008, 04:27 PM   #8
lefortez
My Ride: e39 528
ok the m52tu m54 head as well as the block is different from earlier m50-m52 designs.
please find attached a technical writeup on the m52tu-m54 engine. look up page 15-17 on the cylinder head changes which also necessitates changes to the block coolant passages as well. the gasket for for single vanos m52 and m52tu/m54 is entirely different in designs.
lefortez is offline   Reply With Quote
Old 08-26-2008, 04:29 PM   #9
Snik
Snik's Avatar
from what i understand the vanos on the M54 and M52TU are the same. matter a fact i just bought a vanos unit off a M54 for my M52TU.
if you swap vanos unit im pretty sure it has to be a dual vanos unit too.
Old 08-26-2008, 09:33 PM   #10
hoveringuy
My Ride: e30
Thank you lefortez! That's exactly what I was looking for.
Next question: Is the electronic thermostat backwards-compatible with the old "dumb" thermostats?
Disregarding the fact that the ECU would protest, could the electronic thermostat simply be replaced with the older mechanical one?
Old 08-27-2008, 07:41 AM   #11
Activ3
My Ride: gets DRIVEN.
Send a message via AIM to Activ3
I opened the PDF, and searched all over, but can't find anywhere that states a difference between the M52tu and M54B30 head. Many sources even give the same part number for the two? How sure are you of this, snikwad?
btw, lefortez, great PDF! Thanks!
-David www.e46nonm.com | My Videos
2000 328i - Custom Turbo tuned by AA
Activ3 is offline   Reply With Quote
Old 08-27-2008, 12:12 PM   #12
Snik
Snik's Avatar
how sure am i about what? the vanos, or the difference between the M54 and M52TU heads?
Old 08-27-2008, 12:12 PM   #13
Activ3
The difference between the heads.
Old 08-27-2008, 12:16 PM   #14
Snik
Snik's Avatar
i have a buddy thats a BMW tech, he has a 528iA he acquired a M54 head as his master tech told him it had better air flow, he took hois entire head off, and tried to fit the M54 head, and thats when he saw it, the water jackets are totally different, but everythign else matches, it can even be bolted on, but the water jackets between the M54 head and the M52TU head, dont match.
I also asked my parts guy and the same buddy and they both say as far as they can tell the vanos units of the M54 and M52TU are all interchangeable, whats different are the actual cams and the cranks. and as mentioned, the water jackets.
As for the M52 and the M52TU, i cant say for sure what the little differences are.
Old 08-27-2008, 05:47 PM   #15
lefortez
My Ride: e39 528
the m52tu-m54 engine has a new design for its coolant passages which optimizes the flow directly to the cylinder head. the block is entirely different from the previous m50-m52/s50-s52 engines, hence the block and head of both engines cant be interchange. the block casting is different, the head is different, the gasket is different. the head can be bolted on but whats the use when the coolant cant flow.
sigh....how i know? well i got my hands into a m54 based R35 racing dynamic short block and thought of mating it to my s52 head for 3.5l stroker but now looks like i can only instead. ARGHHHHH
Old 08-27-2008, 05:50 PM   #16
Activ3
I know that the m52tu/m54 is different from the iron block M50/52 and S50/52, but snikwad was stating that the M52TU head and the M54B30 head were different. However, I couldn't find anywhere else that confirmed that. I need a new vanos unit and was considering just getting a ported/polished M54B30 head, but now I'm not sure if they are the same.
Old 08-28-2008, 10:36 AM   #17
hoveringuy
My Ride: e30
My guess is that the cam profiles between the M54 and M52tu are different, but the castings are the same.
Getting back to the thermostat, is the design backwards-compatible with M50/M52 thermostats??
Old 08-28-2008, 10:38 AM   #18
Snik
Snik's Avatar
like i said, my tech buddy had the same thought, it wont work, but the vanos will.
Old 09-09-2008, 08:04 PM   #19
Ivegotissues666
My Ride: 88' BMW E30 SETA
Send a message via AIM to Ivegotissues666
That is correct. For instance ZHP cams will fit in an M52TU Head and vice versa for any Non-M US E46 platform
Jared
Ivegotissues666 is offline   Reply With Quote
Old 09-09-2008, 08:27 PM   #20
Snik
Snik's Avatar
I almost bought some M54 cams on here to put into my sharked M52.
I was told that I'd prolly have to remove the shark injection since it wouldn't match the M54 cams.
Then when I enquired about the actual cam swap, my tech buddy asked his master tech. He said there is a special tool that is required to replace the cam brackets, I believe they're called journals. Well anyway, this tool is to ensure that they are not over tightened when replacing the cam. I 1st thought, hmm, what about regular ass torqueing it to specs. But I guess our BMW heads are too sophisticated for that simple method. Since its already 2 for the master tech and 0 for us, I decided to just take his word on this one.
Besides after contacting TMS they said I'd have to get custom software or a piggyback type setup to correct my AFR that the cams would throw off. So I've decided to research swapping M3 brakes unto my 328i and maybe dropping a S52 motor inplace later on, instead of boosting.
