Thread Tools Search this Thread Rating: Thread Rating: 87 votes, 5.00 average. Display Modes
Old 01-02-2010, 04:18 PM   #41
York
My Ride: 01 330Ci
Originally Posted by Nabil_Leb View Post
+1
Unfortunately I replaced my actuator before this DIY was posted, and I removed the central bolt of the window rail as described in this DIY http://www.e46toronto.ca/forums/showthread.php?t=8893
{in 3. It's the left star-like bolt in (2) and it can be removed with a 6mm? socket. Remove the bolt completely (this detaches the window from the rail). Please note this bolt is reverse threaded.}.
But watch out, something fell down inside the door, and it took me another hour of work after i have finished work to find out that there were 3 parts inside that part (see attached picture: in fact it is not my car, I took it from a DIY).
1-a plastic black cylinder, 2- a round metallic piece with a hole in it to fit the bolt, and 3- a rectangular 4x5 cm metallic piece with a rectangular hole in it .
You have to put the black plastic cylinder inside the hole of the round metallic piece, and put all this inside the rectangular hole of the big piece, and put all that inside the piece shown in the picture, with the stripes facing towards you - to inside the car-. Or else you will have your window play when you open and close it, I guess it is on the coupe models only.. so be careful .
Apart from that, all went smoothly and the lock opens and closes like brand new.
I'm changing my driver's door lock actuator right now. All has been going fine until these extra parts fell into the door - they hold the back side of the window and attach to the window regulator. Does anyone have a detail picture or drawing of the order in which they go together? I can probably take a "best" guess, but would rather have something more exact. Four pieces: plate with hooks that the window sits on?, tapered piece with lots of groves, round cambered washer and black plastic hex bushing. Any help would be appreciated.
Name:	Window Parts 1.JPG
ID:	343188   Click image for larger version
Name:	Window Parts 2.JPG
ID:	343189   Click image for larger version
Name:	Window Regulator 5.JPG
330Ci
York is offline   Reply With Quote
Old 01-02-2010, 06:20 PM   #42
York
My Ride: 01 330Ci
Replacing Door Lock Actuator
OK - I figured it out. What a good DIY project! I started at 11:15am and finished around 3:50pm. Just over 4 1/2 hours and some of it was sitting, reading, surfing - trying to figure out how those dang loose pieces went back together. Anyway, the actuator is now working fine, just like its suppose to. My key would lock the doors, but would not open the driver's door - I always used the key manually. Now, just a push of a button and the door unlocks. Thanks to everyone that posted here with helpful steps.
330Ci
Old 01-03-2010, 08:13 PM   #43
AMCINK
My Ride: 2000 323CI
I have a problem with the driver side window on a e46 2000ci the window is not doing the up and down motion when open or close and they the dealership parts department tells me that the sensor is inside the actuator and not on the lock part that stays in the body like the e36- any inside? since the actuator cannot be open (per this DIY) I will need to change the whole actuator is this correct?
AMCINK is offline   Reply With Quote
Old 01-04-2010, 12:31 AM   #44
genuity
My Ride: 2001 330iS
Is another symptom of a bad door lock actuator when the window fails to scoot down when you pull on the handle to open the door (then come back to when you close the door)? Thanks.
genuity is offline   Reply With Quote
Old 03-01-2010, 11:22 AM   #45
richtn
My Ride: 2000 323ci
Unhappy can't open door
Hey guys, need help i have 2000 323 coupe my proplem is this in trying to take off lock cylinder I removed the bolt on the acutator that adjust the door that controls the release of the door latch. After doing this I took the acutator off replace the bolt put it back in the door but forgot to test to see if door latch would open before I closed the door. I closed the door and now can't open it from outside or inside. My question is there anyway to open the door. Any ideas would help.
richtn is offline   Reply With Quote
Old 03-01-2010, 10:30 PM   #46
York
My Ride: 01 330Ci
Originally Posted by richtn View Post
... now can't open it from outside or inside. My question is there anyway to open the door. Any ideas would help.
Damn! If your door panel is still off, can you reach up inside and pull or push on one of the actuator levers? (Picture is from (paraklas)'s post.)
330Ci
Old 03-21-2010, 12:46 PM   #47
Stan 24v
My Ride: F21 M135i
Just done this fix myself. Couple of points:
You dont need to take the airbag off
You do need to be forceful with the window guide when pulling it
two pairs of hands makes it a fair bit easier
All in all, with rain breaks, took my about 40 mins.
Stan 24v is offline   Reply With Quote
Old 04-21-2010, 07:33 PM   #48
York
My Ride: 01 330Ci
Just posting some pictures of the pieces that fell apart in my door when I was trying to remove the window. Hope these help someone.
Name:	Window Reg 1.JPG
ID:	357079   Click image for larger version
Name:	Window Reg 2.JPG
ID:	357080   Click image for larger version
Name:	Window Reg 3.JPG
ID:	357081   Click image for larger version
Name:	Window Reg 4.JPG
Name:	Window Reg 5.JPG
ID:	357083   Click image for larger version
Name:	Window Reg 6.JPG
330Ci
Old 04-30-2010, 07:37 PM   #49
Pimpwerx
My Ride: 2002 BMW 325Ci
This happened to me today. The damn forum ate my last, long post, but it seems you did all the work for me. I think those pics will help me put it back together properly. Right now, the glass rattles when I close the door. PEACE.
Pimpwerx is offline   Reply With Quote
Old 05-26-2010, 09:05 AM   #50
stalgra
My Ride: Subaru Legacy 3.0R
@paraklas I ****ing love a Man!
This saved me $400
Thank you very much!
stalgra is offline   Reply With Quote
Old 06-15-2010, 05:30 AM   #51
warrior9504
My Ride: 330ci
I just did this repair and it wasn't too hard. Just have a couple of hours and take your time. My symptoms were:
  1. driver's door would not unlock with fob but would manually (i.e. with key in door)
  2. window would not do the 1/4" auto up/down thingy the coupes do when you open/close the door
  3. the display would not indicate that the door was open--actually the car always thought the driver's side door was closed (so no interior lights, no warning when left keys in or headlights on).
Here are my notes for the DIY:
  1. The female Torx listed by the OP to losen the window rail bolt that is reverse threaded is and E7 (stands for "external torx" size 7).
  2. I didn't unhook the airbag. I just pulled it off and then losely rebolted to the door when I got the insulation off
  3. getting the actuator out and the new one in was the hardest part you just have to really move the window guide all over to make space. I had to put the door lock pin in after I got the new actuator inside the door.
Now all my symptoms are cured. It's great having a fully functioning Bimmer...until the gremlins strike again!
FYI - I ordered the actuator from Bimmerspecialist.com. Apparently in my model year they changed the part. Well of course I got the wrong part and of course I couldn't tell until my car was apart. But the guys at Bimmerspecialist were great. Answered my panicked email w/in 24 hours (sent on a Saturday got an answer on a Sunday) and overnighted me the right part. Good guys there.
warrior9504 is offline   Reply With Quote
Old 07-10-2010, 12:41 AM   #52
Tate325xi
My Ride: 325xi 5MT
just paid $800 to have mine replaced. stupid stealership.
-Tate
Originally Posted by 217Bimmer View Post
sometimes i'm into it and my one hand gets tired, i try switching, but then it's like someone with lou gehrig's trying to peel a carrot.
Tate325xi is offline   Reply With Quote
Old 07-17-2010, 10:12 AM   #53
warrior9504
My Ride: 330ci
so i just after I did the actuator replace everything works great...except that now my key doesn't work manually in the door....hmmm anyone have any thoughts?
Old 07-17-2010, 12:04 PM   #54
paraklas
My Ride: ESS TS2 320ci
Did you properly connect the door lock cylinder with the actuator?
Old 07-18-2010, 08:48 PM   #55
2003 325i
My Ride: '03 Orient Blue 325i
Wondering where you folks got your replacement actuators from. I'm looking at doing this soon
Old 07-19-2010, 01:33 AM   #56
paraklas
Only resort for mine was dealer. 256 Euro ($330)
Old 07-21-2010, 05:18 AM   #57
warrior9504
My Ride: 330ci
hmmmm....
I believe I reconnected everything as it was on the old one. My only question during the DIY was what is the point of the door lock key. not sure exactly what that was...i bet that has something to do with my problem. It's only a problem if my batter goes dead
Old 07-21-2010, 05:22 AM   #58
warrior9504
My Ride: 330ci
Bimmerspecialist.com The part was about $100
just be sure to give them your VIN so they can make sure you get the right part. BMW switched part mid 01 model year so I got the wrong part first but the people at bimmerspecialist.com didn't charge me return shipping or restocking or for the new part and I only had to pay $12 to get it next day AM delivery...not bad for something that wasn't their fault.
Old 07-21-2010, 05:24 AM   #59
warrior9504
My Ride: 330ci
yes.
Old 08-02-2010, 09:20 PM   #60
mybmwisallst0ck
My Ride: BMW '02-330Ci, '99M3
Just did this whole thing... Biggest project Ive done by myself. Really nothing went wrong and it is working great..
HOWEVER: should note that you need to put the white key thing in the proper position... I had it spun the wrong way (clockwise) and the manual unlock wont work.
removed old sig
mybmwisallst0ck is offline   Reply With Quote
