Thread Tools Search this Thread Rating: Thread Rating: 18 votes, 5.00 average. Display Modes
Old 08-17-2008, 12:59 PM   #1
steelerfan
My Ride: F30 335i Silver 6MT
Trying to jump my car, sparks when i connect negative
Hey Guys,
Well i get back from vacation only to find my battery is dead. I just installed the factory alarm before i left & had BMW service active it (as well as the second key fob, disable DRL & software updates from a recall).
When i connect the negative terminal to what i assume is the ground terminal to the left of the positive terminal in the engine bay, the negative sparks. Maybe i have the wrong negative terminal all though i highly doubt it b/c it's the same bolt as the positive terminal & that would be a really bad trick by BMW.
Any thoughts on the sparks!!!!!
Any thoughts on why my battery went dead after the new service? The only thing i could think would be the OEM alarm. I don't drive my car daily anyway, it sat for over a week. Any thoughts????
steelerfan is offline   Reply With Quote
Old 08-17-2008, 01:04 PM   #2
NorCal Einstein
My Ride: E92 335i
Send a message via AIM to NorCal Einstein Send a message via Yahoo to NorCal Einstein
Have you ever jump started a car before?
Current:
2009 E92 335i Alpine White/Coral Red
Past:
2007 E92 335i Sparkling Graphite/Black
2000 E46 323i Steel Blue/Grey
NorCal Einstein is offline   Reply With Quote
Old 08-17-2008, 01:04 PM   #3
Bimmerboii
My Ride: is refreshed
did u leave any lights on by mistake, or was a door not shut fully?
or u could have a short somewhere in the car.
01 325Ci Black | Caught On Fire
01 325i Silver | Muffler Delete | 3.46 Diff | White Halo's | H&R Sport Springs | OEM Style 67 | 15mm Spacers | Smoked Corners |
Bimmerboii is offline   Reply With Quote
Old 08-17-2008, 04:20 PM   #4
steelerfan
Yeap, I have jump started many cars before, just the first time jumping the beamer
I know the battery is completely dead b/c when i first got in the car to crank it up & take it for a ride, I noticed the window didn't roll up. Also, the trunk celenoid (i'm a terrible speller) will not open the trunk b/c it doesn't have any power, even though i put the key in the trunk. Kind of a smal problem considering the battery is in the trunk . i guess i could crawl in through the back seat & pull the release lever in the trunk. Sorry guys, not too familiar w/ the car, just bought it less than a month ago.
I only had a few minutes before my soccer game, sorry i wasn't more descriptive. I had to take a different car but i found this post before i tried to jump the car:
http://forum.e46fanatics.com/showthr...tery+dead+jump
Any ideas????? I don't like the sparking. I am jumping this off w/ a 97 accord. Not sure if it matters but in the post listed above someone mentioned don't do it w/ a certain type of battery.
I am thinking about using one of the strut bolts as an alternate ground b/c that one bolt that i think is the ground bolt sure does spark up w/ i have everything hooked up.
Old 08-17-2008, 05:13 PM   #5
steelerfan
well..... when in doubt, read the instructions on the jumper cables It states in caps & bold, don't hook the negative cable to the negative terminal, actually use engine or chassis ground. Like i mentioned, i used one of the strut bolts. It sparked temporarily....
As Bimmerboii mentioned, there was probably an interior light left on or my drivers side door wasn't shut fully, hence the spark when i connected the negative cable.
One of my buddies was feading my cat this past week & he hadn't checked out the car yet since i bought it. I bet he was looking at the interior & just didn't shut the door fully. I will ask him when i get a chance. I also noticed the right side map light was burnt out so maybe that was on. Oh well, thanks for your help guys.
Old 08-17-2008, 05:34 PM   #6
BMW_Matt
My Ride: Has AWD
hahaha. +100.
sparks are normal when jumping as long as you have neg to neg and positive to positive.
the sparks will disapear once you connect it fully for a second
BMW_Matt is offline   Reply With Quote
Old 08-17-2008, 06:10 PM   #7
FWD BLOWS
My Ride: e46/CBR600RR
Send a message via AIM to FWD BLOWS Send a message via Yahoo to FWD BLOWS
I mean batteries spark all the time after one of the leads is connected to it whether it be the positive or the negative it doesn't really matter, im sure some of you have seen it spark a little bit when putting on or removing jumper cables....unless the sparks your talking about are huge then possibly shorting out somewhere along the path or your putting the leads on the wrong terminals.
FWD BLOWS is offline   Reply With Quote
Old 08-17-2008, 08:02 PM   #8
Xcelratr
My Ride: 04 330Ci ZHP
If you're talking about it sparking when you make the last connection (i.e. you've gone + to + with one cable, you've connected one end of the other cable to the - on the live battery, and you get the spark just at the instant you connect the last -) then that's normal and nothing to worry about. Just make sure the clamp takes a good bite the first time so you're not moving it around, disconnecting and reconnecting a bunch of times.
That sparking is the exact reason why it's recommended to hook the jumper cables to the terminals of the live battery and the + of the dead battery, but hook the last cable to a ground on the dead battery's car away from the battery. Batteries produce hydrogen gas as they discharge, and if the gas leaks out of the battery, it will be densest near the battery. You connect the last cable to the - terminal of the battery, the spark ignites the hydrogen gas and BOOM! If you connect to a chassis ground away from the battery, then you're away from the hydrogen gas and the spark won't be a problem.
Since your battery is in the trunk and your jumper posts are under the hood, you should be using the jumper posts. The sparking when you make the last connection should be kept to a minimum by making a solid connection the first time. But a little sparking is ok and normal.
If you're talking about it continuing to spark after you've make the connection, or spitting out sparks when you turn the key to try to start your car, then STOP. Right now. Don't do anything else and have it towed back to the dealer. There's a bigger electrical issue and (sorry for being so blunt) if you're asking this question about sparking when jump starting, the problem is beyond your ability to diagnose or fix.
- Our need for a trigger warning might be your trigger.
- Offend our inclusive values, we'll exclude you.
- We will not tolerate challenges to our ideal of tolerance.
- We seek diversity of appearance, but uniformity of thought.
- We always want to start a dialogue, unless we find your opinion unacceptable, then we'll silence you.
Xcelratr is offline   Reply With Quote
Old 08-17-2008, 08:20 PM   #9
steelerfan
Thanks for all the responses guys. The last connection I was making was the negative to the drained battery side as per the instructions. I have jumped several cars in the past, I just never remembered the sparks before.
I have installed several car audio systems in previous cars & it reminded me of when you reconnect the positive terminal the sparks you get. Like I said I just didn't remember sparks from connecting the ground when i jumped cars in the past.
Man i had some fun driving the car to charge up the battery, took it on a good curvy road behind my house, i missed her last week
After I got back in the garage, cut the car off it cracked back up. So hopefully a light was left on. I will probably drive it tomorrow night to my softball game so we will see!
Old 08-18-2008, 07:40 AM   #10
Arsevader
My Ride: '90 325i, '02 325it
If the battery was dead then what you are doing is a good way to kill your alternator. Alternators weren't made to charge batteries from dead, it puts too much strain on them.
Just charge the battery with a proper battery charger then go for a drive.
- James
'85 E30 325e
'90 E30 325i
'02 E46 325it
'03 E46 320i
'96 Volvo 850R
Arsevader is offline   Reply With Quote
Old 08-18-2008, 11:52 AM   #11
hummer
My Ride: 2001 330CI
There is a positive terminal to be used for jumping. It's under a plastic cover labeled + on the inner fender wall. I've never seen a negative terminal? Negitive cable is connected to the engine somewhere. I use the hoist bracket. If you are putting both cables to positive = SPARKS!
Old 10-14-2011, 04:24 PM   #12
roblowsta
My Ride: 318is
Bump
I had to bump this old thread because this also happened to me and I was wondering if the OP ever solved the problem.
After initially discovering that my battery was dead, I was thrown for a loop because I just installed a new alternator and a new battery. I tried to jump the car using the terminals under the hood. Just as the OP experienced, I got a spark when connecting the NEGATIVE terminals. I was able to jump it directly from the battery in the trunk but am concerned that something is sending a positive charge through the chassis causing this. There is an obvious electrical problem but I have no idea where to start. Can anyone help?
roblowsta is offline   Reply With Quote
Old 10-14-2011, 05:45 PM   #13
jasonbimmer
My Ride: 2001 BMW 330xi
nah, its normal, the initial current when connecting the battery is very high. I was plugging and unplugging my battery and it would spark.
spark is nothing abnormal.
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser
2008 YAMAHA YZF-R6
Old 10-14-2011, 07:17 PM   #14
Stinger9
My Ride: '04 330Ci
Sparks are normal even when jumping correctly
The sparking is the result of the voltage difference between one side to the other when making contact. This causes current to flow. Like a mini-welding set-up.
If you have a problem now, please restate it clearly. I'm not understanding whether the new battery and alternator cured your problem, or you still have abnormal behavior? If the new parts are still leading to a dead battery, you have a current drain that is too high when your car is at rest.
What did your new alternator cost you? From where?
