Thread Tools Search this Thread Rating: Thread Rating: 67 votes, 4.99 average. Display Modes
Old 08-17-2008, 03:21 PM   #1
TKC
My Ride: 330cic & R6
Send a message via AIM to TKC
Oil Level Sensor DIY with pics.
Hi,
I just saw a thread with someone wanting a general idea on how to replace your Oil Level Sensor.
Here is my DIY on how to do it.
I would say on a scale of 1 to 10, this was really easy to do. Maybe a level 2 just cause taking off the metal panel and then trying to re-install it by myself was a pain, but can be done alone.
NOTE: My car came with a metal protection panel under my oil pan. If your car does NOT have this, you can probably skip to step 4.
1) Unplug your Car Battery.
Drain Oil.
Remove the front splash panel under your motor.
Pic of the front couple screws:
2) Pic of the rear couple screws that are attached to my metal protection panel. Also, remove the Access Door to the Oil Drain Plug (Circled in red):
3) Now that the front is exposed, remove the metal protection panel (Circled in red). These nuts and bolts were a little rusty and needed some convincing to knock loose, but it's not too bad. CAREFUL, it's a little heavy and will drop!! I supported it with my leg. When re-installing, I used my jack to jack it up into place and then easily bolted it in.
4) Here is a pic of the Oil Level Sensor in comparison to the Drain Plug. My splash panel is on the floor.
5) One more pic for you of where the Sensor is in comparison to the Drain Plug:
6) First, unplug the sensor. Then, remove the 3 nuts holding the Oil Level Sensor on:
7) Here is the sensor removed. Now all you have to do is reverse the steps with your new sensor and you're done!! I tightened the new sensor at a tight, 6.5 - 7 ft. lbs.
8) Have a beer and feel good about doing something today.
EUROPROJEKTZ - Director, NorCal Chapter
TKC is offline   Reply With Quote
Old 08-18-2008, 10:14 AM   #2
ericsonp325i
My Ride: 01 Black 325i
nice and quick
MODS:Harmon Kardon System// HK Drive+Play// CCFL Angel Eyes// Motorola HF850 BT Kit// Black Headlight Corners// Clear Side Markers// M3 Style Side Mirrors W/ LED Turn Signal// 20% Tint// LED Rear Tailights// M3 Style Front Bumper
ericsonp325i is offline   Reply With Quote
Old 08-25-2008, 07:21 AM   #3
max123
My Ride: e90 / e46 / R6
nice..!
Do you know what is the torque spec for the bolts from the metal panel?
max123 is offline   Reply With Quote
Old 08-25-2008, 10:29 AM   #4
ssm1991
My Ride: 2004 325i
The metal panel (aka "front suspension carrier reinforcement plate") bolts are 16mm. Torque them in 2 stages: first to 59 Nm (44 ft-lbs), then tighten another 30.
ssm1991 is offline   Reply With Quote
Old 08-25-2008, 02:39 PM   #5
max123
You sure know your stuff......!!
Old 08-26-2008, 09:14 AM   #6
Jay631
My Ride: E46 330ci
WOW thanks thats a god save DIY I am gonna do mine today...
Thank you..
Jay631 is offline   Reply With Quote
Old 08-26-2008, 09:21 AM   #7
dwvcfii
My Ride: 98 328is, 06 330ci
So those bolts are torque to yield? Haven't checked the TIS, but if that's the case, they're one-time use and need to be replaced with new bolts.
dwvcfii is offline   Reply With Quote
Old 08-26-2008, 09:29 AM   #8
ssm1991
My Ride: 2004 325i
That's right. Even Bentley recommends replacing them. Most people and indy shops reuse them though. I doubt that most of the dealerships replace them too.
Old 09-04-2008, 08:14 AM   #9
Titanium 325
My Ride: '01 325Ci
Very cool and good to know. The dealer told me they have to drop the pan to do this and wanted nearly $400 for it... I am much more wililng to do this now knowing how easy it actually looks.
Good DIY!
Mods - M3 Style Lip Spoiler, ACS Replica Roof Spoiler (bowed in the middle), Predator Chromium Angel Eyes, P46 Xenons, Smoked Side, Corners and LED Tails, Blacked out Kidney Grills, Self Painted Bumper Reflectors, K&N Drop-in Filter, 19" Miro M6 Reps in Time Attack
Titanium 325 is offline   Reply With Quote
Old 09-15-2008, 01:06 PM   #10
ddobbins
My Ride: 323i
Seems to me that 59 Nm is almost nothing for an M16 bolt so I would be surprised if 59 Nm plus 30 would take this bolt into yield, assuming it's at least a Class 8.8.
ddobbins is offline   Reply With Quote
Old 09-15-2008, 01:10 PM   #11
davidwarren
Halfway to 2L
davidwarren's Avatar
My Ride: 2010 335i
they are supposed to only be used once. I think they are actually 59Nm + 45* +30* or something. I remember they are supposed to be angle torqued twice.
I have reused my a couple times though.....
You down with UCC? Ya you know me!
sowing the seeds of jiggery pokery
davidwarren is offline   Reply With Quote
Old 09-23-2008, 04:02 PM   #12
nathancarter
My Ride: 02 330i
Pretty sure the Bentley says 59Nm + 90* + 30*.
I wasn't able to get them that tight, I just didn't have the clearance to do so with my car on Rhino Ramps. I got them to about 59Nm + 45*, maybe a bit less on the ones that are the most angled.
nathancarter is offline   Reply With Quote
Old 09-23-2008, 04:09 PM   #13
Define ///M3
My Ride: E92
sweet looks simple, ill try and get mine dont next time i change the oil which should be next month! how much did the sensor run you?
Define M3
tiag 2000 323ci - sold
BSM 2004 325ci - sold
AW 2013 328i - sold
MWM 2012 e92 328i - current
Looking 4 e46 M3
Define ///M3 is offline   Reply With Quote
Old 11-29-2008, 02:19 PM   #14
e46vert
My Ride: 330ci
just wondering how much is the oil sensor?
e46vert is offline   Reply With Quote
Old 12-03-2008, 05:59 PM   #15
richyboycaldo
My Ride: Mx5 300zx 240z 330c
usually 100 bucks.
What if I cant torque it to specs and I just use a simple old fashion wrench, any problems?
richyboycaldo is offline   Reply With Quote
Old 12-03-2008, 06:56 PM   #16
e46JAB
My Ride: 2000 323CI, 2004 M3
Nice DIY. Did you replace it because your yellow oil level light would come on for a while after start-up?
e46JAB is offline   Reply With Quote
Old 01-04-2009, 10:30 PM   #17
hk_e46
My Ride: 2000 318Ci
i know is an old thread. just search to find out.... i probably need a new oil level sensor too...
questions: by simply removing the reinforcement plate, i saw those screws were attached to the chasis, is it safe to do so? as far as i remember there were 6 large screws on it...
secondly, i found there is a leak of engine oil between the engine block and oil pan, i am thinking to do the oil pan gasket and the oil level sensor together since both diy require to remove the reinforcement plate.
how hard is the oil pan gasket diy? could somebody link a oil pan gasket diy instruction URL?
many thanks =)
Spec.: E46 318Ci 2000'
A bimmer fans from Hong Kong
hk_e46 is offline   Reply With Quote
Old 01-05-2009, 01:23 PM   #18
TKC
Thanks for the replies everyone. It seems I left out of my original post the symptoms that lead to this replacement.
So what happens:
IF your oil light comes on AFTER you drive, when you shut the car OFF, it means you're low on oil, check your dip stick.
IF your oil light comes on A FEW SECONDS AFTER YOU START YOUR CAR, and then it turns off after about 10 seconds, it means your oil level sensor is faulty, and following my DIY above will fix this.
I just did this replacement again this weekend on my 328 as well. Also, just to note, the 328 did NOT have the large metal body panel that covered the oil pan. The whole oil pan, drain plug, AND THE SENSOR were fully exposed, so I literally jacked the car up, drained the oil, and then unbolted the old sensor, put in the new one, tightened everything up, filled the car with oil and new filter, and was done with the whole process in less than half an hour!
Hope this helps everyone!!
Old 01-05-2009, 05:41 PM   #19
elbee
My Ride: 2001 325I Sedan
Thanks for posting this. I might have to do this one. Unfortunately I just changed the oil, so I will just have to live with the oil level light coming on until the next oil change.
elbee is offline   Reply With Quote
Old 03-02-2009, 11:06 AM   #20
Nicker
My Ride: 323ci
Hahaha.
I JUST changed my oil. The NEXT day, the light comes on then goes off (sensor bad).
Pshh.
00' 323ci - 170hp
Nicker is offline   Reply With Quote
oil level sensor, oil light, oil sensor
