Go Back   E46Fanatics > Everything Else > Other BMW Models
Other BMW Models
All other BMW model questions! For additional model specific forums check out bimmerfest.com!
Please post all E90/E91/E92/E93 and new M3 news at E90Fanatics.com
Old 08-18-2008, 03:58 PM   #1
NisoCrew
My Ride: 08 AW M3 Coupe
Send a message via AIM to NisoCrew
Question M3 V1 Install w/ CF roof
So, I just picked up the new M3 coupe on Friday and have already begun to have fun. I looked at the post from Tim330 on V1 DIY, however, my M3 has the carbon fiber roof. Turns out that there are no bolts to which you can mount the ground wire. There are holes in the sheet metal, but after a couple hours at Lowe's I gave up on finding a bolt that would fit. Has anyone else run into this problem yet? So far I have come up with a couple possible solutions:
A. Remove the stock prong thing for the ground wire put a tap on, and just tap into a ground wire.
B. Sand off an area of the metal that is present and just use conductive epoxy or some other type of adhesive to attach the prong right to the metal.
C. Just get a metal screw, and drill it right into the metal.
I posted on E90, but figured I would ask some folks on here...I still look here, so I figure someone that can help still does too.
If anyone has any suggestions or easier/more elegant solutions, feel free to send them my way. Thanks.
"The Verdict: Every other manufacturer should give up building their own cars and just make M3's instead".
--Car and Driver
NisoCrew is offline   Reply With Quote
Old 08-20-2008, 11:24 AM   #2
NisoCrew
Well, I decided to go with C. Drilled a short sheet metal screw into the metal part and attached the ground. It's working just fine.
--Car and Driver
Old 08-20-2008, 01:09 PM   #3
simsima325
'a certain moderator'
simsima325's Avatar
My Ride: Honda Civic
brave! i dunno if i could drill into my new M3 like that
Old 08-20-2008, 01:23 PM   #4
NisoCrew
I caught the metal filings, ! I didn't want to do it, but it was definitely the easiest and best solution. Tapping into another wire is messy and just introduces more to go wrong. I made sure there was nothing behind the metal. It was pretty weird putting a hole into a car I had for 3 days though!
--Car and Driver
