Sponsored by BimmerWorld
Old 08-18-2008, 09:04 PM   #1
lioe46
My Ride: e46
H&R Cupkit fitment with CSL wheels??
can i fit 18" csl with H&R cup kit?
lioe46 is offline   Reply With Quote
Old 08-19-2008, 12:26 AM   #2
Chris-TK
My Ride: Mk VI GTI
Do you have a coupe or sedan? Yes if you get the correct offsets and tires. Max tire width for a sedan is 255 and a coupe is 265. Are you getting a square setup, if so then 18x8.5 40mm offset will work perfectly. If you are going staggered with a 9.5 rear and a 255 or 264 you might need to roll your fenders.
btw...Worst thread topic title ever.
K.
Chris-TK is offline   Reply With Quote
Old 08-19-2008, 09:37 AM   #3
simsima325
'a certain moderator'
simsima325's Avatar
My Ride: Honda Civic
as long as u get wheels that are made for non-M, yes.
2nd, awful title. fixed for the n00b.
-Brendan
Old 08-19-2008, 10:35 AM   #4
Arrows
My Ride: 2000 323i.
Send a message via AIM to Arrows Send a message via MSN to Arrows
Yes they will fit. I've personally had that setup before. If you have the right offsets and tire sizes you shouldn't have a problem. If you decide to do a staggered setup, you might have to roll your fenders to avoid rubbing with 2-3 people in the car.
Arrows is offline   Reply With Quote
Old 08-19-2008, 10:11 PM   #5
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
Yep you can run that setup so long as you have rear ET45 wheels and nothing larger than a 255 rear tire.
Old 08-27-2008, 04:47 AM   #6
dmisc
My Ride: a car
I have this cupkit and CSL 19's in the rear. i rub a little bit with fenders rolled, but I have 265's in the rear. 18's should be fine.
dmisc is offline   Reply With Quote
