Sponsored by BimmerWorld
Old 08-19-2008, 06:43 PM   #1
enter
My Ride: 330 ci
Settling time for new springs and alignment
Hi guys, got my car lowered on eibach prokits and the ride height is only alittle lower than stock, ive waited a week and its still the same, will the spings stil settle after this and possibly lower?...will alignment make it lower?
http://www.allglobaltk.com/artansalpaca.gif
enter is offline   Reply With Quote
Old 08-19-2008, 10:13 PM   #2
ThunderRobo
My Ride: E46 Sedan
Send a message via MSN to ThunderRobo
Prob not... Prokit are only a tad lower then the stock sport springs.
Get them out and get some SportLines or H&R springs.
ThunderRobo is offline   Reply With Quote
Old 08-20-2008, 01:17 AM   #3
Chris-TK
My Ride: Mk VI GTI
If you want it lower get some H&R Race springs.
K.
Chris-TK is offline   Reply With Quote
Old 08-20-2008, 02:14 AM   #4
kuksul08
My Ride: M3
I would say put about 100 miles on it and that's the best you're going to get granted you seated them properly when installing.
Look at that subtle jet-black coloring. The tasteful thickness of it. Oh my God, it even has a 6mt.
S54 Valve Adjustment Spreadsheet & Info: http://dl.dropbox.com/u/28231781/S54...ent%20info.zip
S54 VANOS DIY Video: http://www.youtube.com/watch?v=9SkT2j3jsU0
kuksul08 is offline   Reply With Quote
Old 08-20-2008, 12:06 PM   #5
enter
My Ride: 330 ci
how can i tell they are seated properly?....
Old 08-20-2008, 02:19 PM   #6
kuksul08
My Ride: M3
When you installed them, they had to be aligned properly on the spring perches. when I changed my shocks I marked the existing springs and made a mental note to make sure they go back the same way. Basically the end of the spring has to butt up against that lip in the perch, and the rubber pad should be aligned in there as well.
