Thread Tools Search this Thread Rating: Thread Rating: 15 votes, 5.00 average. Display Modes
Old 08-21-2008, 06:40 PM   #1
david @ eas
Past Site Sponsor
My Ride: E46 M3
eas | Full Listing of Carbon Fibre Parts for E46
eas has been the leading vendor for your Carbon Fibre Accessories.
We would now like to introduce our full line of Carbon Fibre for your cars. Our beautiful 2x2 and 1x1 Fibre comes with a glossy clear coat that has become a forum favorite. These pieces are NOT overlays; they are full OEM replacements for your car.
** Please check the models supported underneath each product to make sure your car is applicable to the product in question **
e46 Carbon Fibre Interior Trim set - 1x1 Plain Weave (Coupe)
Transform your 3-series Coupe or M3 to new heights with our 8-piece Carbon Fibre Kit. All pieces are 100% carbon fiber with that perfect weave pattern you come to expect in your BMW, emulating the same pattern found on original CSL M3s.
Set your BMW apart from the rest with Fibre. Our 1x1 Plain Weave Fibre Interior kit is available in Black only.
http://www.europeanautosource.com/pr...oducts_id=1855
Models Supported:
2000-2006 3-series Coupe, including M3
e46 Carbon Fibre Interior Trim set - 2x2 Twill (Coupe)
This 8 piece carbon fibre kit comes with a 2x2 weave with a glossy clear coat. These carbon fibre pieces are not overlays; they are full replacements of your original trim. They come with a UV coating that resists any yellowing or fading of the carbon fibre. Optional colors come in Black, Silver, and Titanium.
http://www.europeanautosource.com/pr...roducts_id=369
Models Supported:
e46 Carbon Fibre Interior Trim set - 2x2 Twill (Convertible)
This will be the same 2x2 kit but for the convertible. Some slight adjustments for the convertible allow this kit to work perfectly with the e46 convertible. Same quality and options will apply for the convertible as the 2x2 coupe kit does. Optional trim colors come in Black, Silver, and Titanium.
http://www.europeanautosource.com/pr...roducts_id=553
Models Supported:
2000-2006 3-series Convertible, including M3
Carbon Fibre SMG Dome
A perfect compliment for those that already have our Carbon Fibre interior trim kits, or a good start for those that don't - our Carbon Fibre SMG domes are just the ticket for individualizing your M3 while adding a bit of class. Optional colors include Black, Silver, and Titanium to match your carbon fibre interior trim.
http://www.europeanautosource.com/pr...oducts_id=1120
Models Supported:
2002-2006 M3 with Sequential Manual Gearbox (SMG)
e46 Carbon Fibre Battery Terminal Cover
Give the items underneath your hood some flash with carbon fibre from eas. Beautiful 2x2 twill weave features a deep gloss clearcoat for that look and finish that you are looking for. Replaces your stock [+] battery terminal cover, snapping right into place in seconds.
http://www.europeanautosource.com/pr...oducts_id=1313
Models Supported:
1999-2006 3-series, including M3
Carbon Fibre Competition Steering Wheel
Our Competition steering wheel can dramatically improve the look of your BMW's interior immediately. Using an original BMW steering wheel, this is disassembled and reconstructed to to your specifications.
The wheels feature high-quality perforated leather or alcantara construction with "trigger" grips molded into the 9-o'clock and 2-o'clock positions for a thicker, aggressive grip, while paying close attention to comfort. Our Competition steering wheels can be specified with or without Carbon Fibre inserts on the upper or lower portions of the wheel, or both.
Your current Upper Multifunction Steering Wheel (MFSW) Controls, round airbag and lower steering wheel trim transfer to your new wheel making a quick and easy swap in about an hour.
http://www.europeanautosource.com/pr...oducts_id=1317
Note: Steering wheel only. Existing round airbag, upper steering wheel controls and lower trim are reused from your existing wheel. Refundable core charge for your e46 steering wheel will be applied if applicable.
Models Supported:
2001-2006 3-series, including M3
2000-2003 5-series, including M5
2000-2001 7-series
1999-2006 X5
2004-2007 X3
e46 Carbon Fibre Cabin Air Filter Cover
This beautiful Carbon Fibre Cabin Air Filter Cover, will replace your OEM plastic cabin air filter, and add some flash of carbon fibre. This piece is a full replacement, NOT an overlay piece. Installation will snap into place in just a few seconds to make you engine bay look more beautiful.
http://www.europeanautosource.com/pr...oducts_id=1314
Models Supported:
e46 Carbon Fibre DME/Computer Cover
Incorporating our beautiful 2x2 weave of carbon fibre will add some flash of fibre underneath your hood. This will replace your stock DME/ECU computer cover located on the driver’s side of the car located to the right of the Cabin Air Filter.
http://www.europeanautosource.com/pr...oducts_id=1316
Models Supported:
e46 Carbon Fibre e-brake handle
Give that worn out leather e-brake a facelift with our Transform your 3-series Coupe or M3 to new heights with our Carbon Fibre e-brake handle. Constructed in 100% carbon fiber with that perfect weave pattern you come to expect in your BMW, this is the perfect complement to our Carbon Fibre Interior Trim kit.
http://www.europeanautosource.com/pr...roducts_id=376
Models Supported:
2000-2006 3-series, including M3 (not for i-Drive models)
e46 Carbon Fibre Lower Headlamp Trim
Original BMW lower headlamp trim beautifully wrapped in 2x2 carbon fibre with a double clearcoat to prevent yellowing and add durability. Perfect accent for those with our fibre interior kits.
For those that demand the best, this is it. Available in black fibre only. Not for BMWs with headlight-washer systems.
http://www.europeanautosource.com/pr...oducts_id=1779
Models Supported:
1999-2002 e46 3-series (Coupe/Convertible only)
2000-2006 e46 M3
e46 Carbon Fibre Radio Trim w/ Carrier (centered)
When installing an aftermarket radio in your 3-series, the radio is normally shifted over to the left due to clearance issues. Rather than modifying your own trim to make it fit we have the correct pieces to center the radio and make everything look correct. Kit includes Centered radio trim and carrier.
These pieces are ultra-rare, not many BMWs will be seen with these.
http://www.europeanautosource.com/pr...oducts_id=1121
Models Supported:
1999-2006 e46 3-series & M3
e46 Carbon Fibre Roundel Master Set (Black/Silver)
Our Carbon Fibre Roundels replaces your boring stock pieces and are a 100% perfect fitment. Constructed with real high-quality carbon fibre, a clearcoat is then applied for protection from road debris or pitting. The clearcoat also features a deep gloss finish and protection from harmful UV rays.
For Roundels on your BMW - there is nothing on the market that can compare to the quality of this master set. Full replacement 7-piece Roundel set replaces hood & trunk Roundels, wheel centercaps and steering wheel emblem
http://www.europeanautosource.com/pr...roducts_id=947
Models Supported:
1999-2006 3-series including M3*
2001-2006 3-series Convertible & M3 Convertible*
* intended only for e46 models
e46 Carbon Fibre Steering Column Cover
Original BMW steering wheel column beautifully wrapped in 2x2 carbon fibre with a double clearcoat to prevent yellowing and add durability. Perfect accent for those with our fibre interior kits.
Package includes both top/bottom pieces with crash support padding. For those that demand the best, this is it. Available in black fibre only.
http://www.europeanautosource.com/pr...oducts_id=1849
Models Supported:
1999-2006 e46 3-series, including M3
2004-2008 X3
e46 Carbon Fibre Sunglass Holder – Convertible
Original BMW Sunglass Tray beautifully wrapped in 2x2 carbon fibre with a double clearcoat to prevent yellowing and add durability. Perfect accent for those with our fibre interior kits.
http://www.europeanautosource.com/pr...oducts_id=1717
Models Supported:
1999-2006 e46 3-series, including M3 (Convertible only)
e46 Carbon Fibre Sunglass Holder - Coupe/Sedan
The Carbon Fibre Sunglass Holder for the Coupe/Sedan offers the same quality from the convertible 2x2 carbon fibre kits. These specific sunglass holders are full replacements of your OEM sunglass holder located underneath the air conditioning units.
http://www.europeanautosource.com/pr...oducts_id=1716
Models Supported:
1999-2006 e46 3-series, including M3 (Coupe/Sedan only)
e46 Carbon Fibre Tool Box
Don't forget in the trunk! Give your items inside your trunk some flash with carbon fibre from eas. Beautiful 2x2 twill weave features a deep gloss clearcoat for that look and finish that you are looking for.
Replaces your stock toolbox cover, bolting right into place in seconds.
http://www.europeanautosource.com/pr...oducts_id=1318
Models Supported:
e46 Carbon Fibre Upper Steering Wheel Trim
This is an original BMW upper steering wheel trim wrapped in beautiful carbon fibre, giving the interior the style it needs to differentiate your M3 from the rest. Optional colors include Black, Silver, and Titanium to add that extra amount of fibre to match your carbon fibre interior kit.
http://www.europeanautosource.com/pr...oducts_id=1322
Models Supported:
e46 Carbon Fibre Upper Steering Wheel Trim - M3 ZCP
Now ZCP owners have the same options as other M3s with fibre! This is an original BMW ZCP upper steering wheel trim wrapped in beautiful carbon fibre, giving the interior the style it needs to differentiate your M3 from the test.
http://www.europeanautosource.com/pr...oducts_id=1321
Models Supported:
2005-2006 M3 ZCP
e46 Carbon Fibre Xenon Controller Cover
This piece fully replaces your stock Xenon Controller Cover with beautiful 2x2 carbon fibre. This will snap into place in just a matter of seconds with correct holes for wiring to the xenon controller inside.
http://www.europeanautosource.com/pr...oducts_id=1315
Models Supported:
1999-2006 3-series with Xenon headlamps, including M3
e46 M3 Carbon Fibre Intake Snorkel
This piece will fully replace your stock Intake Snorkel located just above the kidney grills/radiator. This Piece of beautifully woven carbon fibre will replace your stock intake snorkel in seconds with a simple bolt-in application.
http://www.europeanautosource.com/pr...oducts_id=1837
Models Supported:
2000-2006 M3
M3 Carbon Fibre Mirror Covers
Transform your M3 to new heights with our Carbon Fibre Mirror Covers. All pieces are BMW OEM mirror covers carefully laid with Carbon Fibre with close attention paid to the pattern for that perfect weave pattern you come to expect in your BMW.
http://www.europeanautosource.com/pr...roducts_id=389
Models Supported:
2000-2006 M3 or 3-series with M3 mirror retrofit. Not compatible with M3 replica mirrors
M3 Carbon Fibre SMG Paddles
Our M3 Carbon Fibre SMG Paddles will extend those short SMG paddles for easier reach as well as accent your interior. Constructed of 100% Carbon Fibre, these are functional as well as stylish. These carbon fibre SMG paddles only come in Black or Silver.
http://www.europeanautosource.com/pr...roducts_id=374
Models Supported:
2001-2006 M3 w/ SMG
M3 Carbon Fibre Steering Wheel Trim
Set your M3 apart with Carbon Fibre Steering Wheel Trim. Constructed in 100% carbon fiber with that perfect weave pattern you come to expect in your BMW, this is the perfect complement to our Carbon Fibre Interior Trim kit.
Set your BMW apart from the rest with Fibre. Our Carbon Fibre Steering Wheel Trim is available in Black, Silver or Titanium colors.
http://www.europeanautosource.com/pr...roducts_id=375
Models Supported:
2000-2006 M3 or BMWs with M3 Steering Wheel Retrofit
M3/M6 Carbon Fibre seat outer trim
Original BMW seat trim beautifully wrapped in 2x2 carbon fibre with a double clearcoat to prevent yellowing and add durability. Perfect accent for those with our fibre interior kits.
For those that demand the best, this is it. Available in black, silver and titanium fibre. Available for power seats only.
http://www.europeanautosource.com/pr...oducts_id=1686
Models Supported:
1999-2006 e46 3-series, including M3 (Coupe only)
2005+ e63/e64 M6
M5/M6 SMG Carbon Fibre Shift Knob
How can the finest shifter get better? With fibre of course. Original BMW M5/M6 shifter beautifully wrapped in 2x2 carbon fibre and leather with a double clearcoat to prevent yellowing and add durability. Shifter features illuminated shift pattern and is a direct replacement for SMG M5/M6 applications. M3 SMG owners can benefit from this retrofit with a tiny bit of rewiring.
http://www.europeanautosource.com/pr...oducts_id=1685
Models Supported:
2004+ e60 M5 equipped with SMG
2005+ e63/e64 M6 equipped with SMG
2002-2006 M3 equipped with SMG
Note: M3 applications will require custom work for fitment.
Carbon Fibre Wheel Center Cap Set (Black/Silver) and (Black/White)
Our Carbon Fibre Wheel Roundels replaces your boring stock pieces and are a 100% perfect fitment. Constructed with high-quality carbon fibre, a clearcoat is then applied for protection from road debris or pitting. The clearcoat also features a deep gloss finish and protection from soaps or cleaners.
The Wheel Caps also include the assembly caps for a quick and pain-free installation. Simply remove your old tired roundels and replace with new.
http://www.europeanautosource.com/pr...roducts_id=858
Carbon Fibre Wheel Center Cap Set (Black/White)
http://www.europeanautosource.com/pr...oducts_id=1856
Models Supported:
1992-2007 3-series, including M3
1997-2003 5-series, including M5
1996-2001 7 series
2004-2007 X3
2000-2006 X5
1996-2002 Z3, including M-Roadster/Coupe
2003-2007 Z4, including M-Roadster/Coupe
2000-2003 Z8
If you have any questions about the Carbon Fibre products, please feel free to send a PM, or an email. Customers are also welcome to give us a call about the products as well
david @ eas is offline   Reply With Quote
Old 08-21-2008, 06:40 PM   #2
david @ eas
Past Site Sponsor
My Ride: E46 M3
Reserved
Old 08-21-2008, 10:04 PM   #3
Brian N
My Ride: 2001 330i Jet Black
Huh I always thought you guys had a sedan interior kit! But otherwise that CF weave looks amazing as usual!
Brian N is offline   Reply With Quote
Old 08-21-2008, 11:05 PM   #4
AznGuilty
My Ride: 330CI
kidney grill silver cf prefacelift convert?
AznGuilty is offline   Reply With Quote
Old 08-22-2008, 11:48 AM   #5
tom @ eas
european auto source
tom @ eas's Avatar
My Ride: e92 S/C M3
We discontinued the sedan kits a while back but I just had another one made on our last run and it's here in stock - feel free to stop by and check it out in person.
We don't offer the kidney grilles in fibre - typically they get destroyed by rock chips in about a year.
tom @ eas is offline   Reply With Quote
Old 08-22-2008, 12:37 PM   #6
SWINFORD
///PIITB
SWINFORD's Avatar
My Ride: Low Life Marie
Send a message via AIM to SWINFORD Send a message via MSN to SWINFORD
for a good looking interior kit
Swinford-Hypnotyzd : Dirty South-Swinny
| Hypnotyzd FB |Tischer BMW|
SWINFORD is offline   Reply With Quote
Old 08-22-2008, 12:40 PM   #7
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
wow
| 435 HP 328Ci | RRT Racing | Designer Wraps | Active Autowerke | Vorsteiner | STATUS Racing |
Timeless Motor Group
Old 08-22-2008, 12:43 PM   #8
david @ eas
Past Site Sponsor
My Ride: E46 M3
wow
Yeah wow is right... I didn't even know how much fibre we had here until we laid it out and just stared at it all... It's pretty incredible
Old 08-22-2008, 01:42 PM   #9
Brian N
Sounds good to me. I think I will come down with Sillie one of these days to check them out.
Old 08-22-2008, 02:21 PM   #10
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
Sillie beat you to it - here was already here this week looking at Silver tool boxes.
Old 08-22-2008, 02:27 PM   #11
sillieidiot
My Ride: '06 AW 330ci
lol i will come again like always. maybe try today. cause i'm missing a few things that i need from last time.
Old 08-23-2008, 03:11 PM   #12
CTD
My Ride: 2016 F36 435dx
Thanks Jurrian and Tom!
I went to LA this week and bought a set of 1x1 black CF trims for my Coupe. Together with the Black/silver CF roundel master set, E-light comfort and F2P.
Now I just have to wait for the trunk, hood and steering wheel roundels (got the wrong colours, needed Black/silver CF and got Black CF/White).
The front pieces (dash) are allready installed and let me tell you, they look AWSOME!
The rest of the installation I will do tomorrow (tired from the flight back home).
I'LL POST PICS!!!
2000 E39 525Tds (sold)
2003 E46 330Cd (sold)
1998 E36 316ia (sold)
2015 F36 435dx (totaled)
1973 E9 3.0CS (weekend)
2011 E91 320d (wifes ride)
2016 F36 435dx (daily)
CTD is offline   Reply With Quote
Old 08-23-2008, 08:40 PM   #13
Brian N
Yeah I think those tool boxes look fanatic. It is on of my favorite CF products you guys make. I am sure we will come down some time soon.
Old 08-25-2008, 07:15 PM   #14
david @ eas
Past Site Sponsor
My Ride: E46 M3
Sooooo when you comin down huh!? Anything you were specifically looking at? I can help you out with anything you need, just send a PM
Old 08-25-2008, 07:59 PM   #15
Brian N
Not too sure actually maybe some CF interior trim, and the tool box I was eyeing. I will come down with Sillie one of these weeks when school is a little less busy and check out all your goodies.
Old 08-26-2008, 12:01 PM   #16
david @ eas
Past Site Sponsor
My Ride: E46 M3
Well we only have ONE of the sedan interior trim so do your best to get here soon! I don't want to see that trim go away when you get here!
That would be quite upsetting
Old 09-17-2008, 07:47 PM   #17
david @ eas
Past Site Sponsor
My Ride: E46 M3
Bump!
Old 09-17-2008, 08:01 PM   #18
HardPark'd TT
My Ride: is parked hard.
Send a message via AIM to HardPark'd TT
Gawwwwwwwwwwd so many nice pieces!
Bagged e85 Z4 | www.ogretrograde.com
Bagged TT 225Q SOLD - e46 M3 SOLD - W202 SOLD - e46 325i SOLD
HardPark'd TT is offline   Reply With Quote
Old 09-23-2008, 01:45 PM   #19
david @ eas
Past Site Sponsor
My Ride: E46 M3
Yes they are... So when are you going to get some!
Old 09-30-2008, 01:01 PM   #20
david @ eas
Past Site Sponsor
My Ride: E46 M3
Bump!
