Thread Tools Search this Thread Rating: Thread Rating: 21 votes, 5.00 average. Display Modes
Old 08-23-2008, 07:42 AM   #1
ScoobyBoo
My Ride: 2002 BMW 325i (E46)
Question How to do I replace the EVAP Purge Valve (a.k.a. Fuel Tank Breather Valve)?
I downloaded the OBDII code and discovered that I need to replace my Evaporative Emissions (EVAP) Purge Valve [some people know it to be the Fuel Tank Breather Valve]. I've located the EVAP purge valve mounted beneath the intake manifold. It looks like I either need to remove the intake manifold or remove the air filter housing to even have a chance to reach it. Unfortunately, there isn't much detailed DIY information on this subject for the 2002 325i (E46).
What's the easiest way to gain access to the EVAP purge valve/fuel tank breather valve and replace it?
ScoobyBoo is offline   Reply With Quote
Old 08-25-2008, 08:29 AM   #2
NoVaDreier
My Ride: 2001 325i
Why don't you check the fuel tank breather line connections and vacuum test the breather lines before replacing the fuel tank breather valve?
NoVaDreier is offline   Reply With Quote
Old 08-26-2008, 01:27 PM   #3
ScoobyBoo
It's not the tank breather line. The OBDII fault code was PO444 which indicates an open circuit on EVAP purge valve (fuel tank breather valve). I spoke with one of the service techs at the local dealer. He says it's most likely the solenoid on the EVAP purge valve went bad.
If I'm looking to replace the EVAP purge purge valve, what's the easiest way to get to the purge valve? Is it by removing the air filter housing?
Old 08-26-2008, 01:42 PM   #4
Tom Busby
My Ride: 2001 325i, 1995 318i
Slide under the car, and look up, at the rear of the passenger side below the trunk and right below the fuel tank filler-neck where you add gasoline. There is a black plastic box, a little smaller than a shoe box. Unlatch the bottom-cover by sliding the little button-ears under the latches. Look for the solenoid, which will look like an iron core with a lot of copper wires wound around it. Unclip the solenoid and the wires. Pop off the front end of the solenoid, clean the o-ring with alcohol, and lightly regrease the o-ring with di-lectric grease or vasoline jelly. Re-install everything and clear the codes. This worked for me. My trouble code was something like "small leak at the evap purge valve." That was 50,000 miles ago and it has not returned.
Tom Busby is offline   Reply With Quote
Old 08-26-2008, 03:16 PM   #5
ScoobyBoo
Hmm...I thought the purge valve was located underneath the intake manifold on a 2002 325i (E46) and the solenoid was integral to the purge valve body (one part). That's what was mentioned to me by the dealer service tech [and what I observed first hand opening the hood]. The BMW part number is 13901433603. Can anyone else confirm this?
Old 08-26-2008, 06:58 PM   #6
Tom Busby
Yes you have a different CES than I described.
So, look for a black plasic (charcoal filled) canister about the size of a 1 lb. coffee can. Or look for the vent line off of the throttle. The valve is in between the can and the throttle body.
Here is someone else's description.
http://tech.bentleypublishers.com/th...ssageID=356079
Here's the part you are describing
http://www.realoem.com/bmw/showparts...98&hg=13&fg=15
Old 08-26-2008, 08:21 PM   #7
ScoobyBoo
Thanks Tom for your input and the links. It's much appreciated. The only thing I don't see in the other person's description is how he actually got access to work on the purge valve. It just describes how they traced out the breather line to find the purge valve.
After contemplating about it some more and looking at it under the hood again, I think I'll try to remove the air filter housing to try to reach the purge valve under the intake manifold. It just seems like it may turn out to be a bit of a challenge if I discover that the breather lines are tough to disconnect from the old purge valve and if re-connecting the breather lines to the new purge valve are tough (because I'll be reaching under the intake manifold to do it and may have to feel my way around without a complete visual as I disconnect/re-connect breather lines). But, removing the air filter housing seems to easier than removing the intake manifold. I just wanted to confirm with someone who had done the work before on the same model of vehicle [before I start taking things apart].
Old 08-27-2008, 09:59 PM   #8
NoVaDreier
My Ride: 2001 325i
After removing the air filter housing, the fuel tank venting valve is located right under the front corner of the intake manifold directly behind the power steering fluid reservoir. See the bottom picture on page 113-7 of the Bentley manual. According to TIS 13 90 500, (1) disconnect the electric plug connection on the front of the valve, (2) release the bottom vent hose by pressing the locking bar and detaching, and (3) detach the rear hose from the venting valve. You might have to loosen the reservoir retainer and move the reservoir out of the way so you can get to the rear hose connection.
Old 08-27-2008, 10:12 PM   #9
ScoobyBoo
Thanks a bunch NoVaDrier! I appreciate the detailed information. I'm glad that my plan wasn't that far off. Yeah...it looks like I may have to also loosen the power steering fluid reservoir retainer and move the reservoir out of the way to get to the rear breather hose connection.
Old 08-31-2008, 07:11 PM   #10
ScoobyBoo
Just a follow-up update after I replaced the EVAP purge valve (a.k.a. fuel tank breather valve) on my 2002 BMW 325i (E46). As I did it, I discovered that all that needs to be removed is the air filter housing in order to get access to replace the EVAP purge valve. It turns out that I didn't have to loosen the power steering reservoir retainer and move it out of the way. There is enough slack in both fuel breather hoses that you can slightly unhook the purge valve from the mount and slightly pull it out from under the engine intake manifold.
Before I started the replacement work, I first disconnected the negative terminal at the car battery to kill power to the car. Then I began work by removing the 2 bolts holding the air filter housing with a 10mm socket. I also had to unclip the 2 metal clips holding the round air intake boot to air filter housing. After I unclipped the clips, pull the round intake boot from the housing. Separate the other plastic retangular-shaped intake on the opposite side of the top portion of the air filter housing from the housing by squeezing the plastic retangular-shaped intake as you carefully pull the rectangular intake and the housing apart. There is another plastic rectangular air intake connected to the bottom portion of the air filter housing with a grey foam seal around the inlet; I left this air intake connected to the air filter housing. Now, I carefully lift out the whole air filter housing. After I removed the air filter housing, I just followed NoVaDreier's instructions (previous posted message) for the EVAP purge valve replacement. I've cut-n-pasted and italicized his instructions below:
A couple of footnotes...in order to separate the electric/power plug connection from the purge valve, there is a small metal wire clip I had to depress. The plug connection slides off the purge valve easily when the metal wire clip is pressed. Also it helps to apply a little Vasaline petroleum jelly to the plastic hose barb of the new purge valve; the breather hose slides back on the new purge valve easily if you apply a little Vasaline. After I completed the replacement work and reconnected the car battery, I also used a handheld OBD-II code scanner to erase/reset the old purge valve error code from the vehicle computer. The "Service Engine Soon" indication disappeared and the OBD-II scanner showed zero error codes which hasn't re-appeared. That's great news!
Tools I used:
- Ratchet with 10mm socket (used to loosen/re-tighten nut on negative terminal of car battery and to remove/re-install 2 bolts holding air filter housing to the top of the front driver's wheel well)
- Flat head screwdriver (used mainly to assist in unlatching the 2 metal clips holding air filter housing to the round intake boot)
- Pliers (used to pull the larger breather hose off from old EVAP purge valve...I'm talking only about the hose without the plastic compression clip on the end. The other breather hose with the plastic compression clip can be disconnected using your bare hands)
- Vasaline petroleum jelly (applied a little to the plastic hose barb of the new purge valve...it made sliding back on the larger breather hose to the new purge valve much easier)
- Actron PocketScan OBD-II Code Scanner (used to erase/reset the initial purge valve error code from the vehicle computer after I replaced the valve...the "Service Engine Soon" light turned off after reset it and it never came back on)
- Evaporative Emissions (EVAP) purge valve [BMW lists the part as a Fuel Tank Breather Valve...part# 13901433603] - approx. $80 from the dealer
Old 09-12-2008, 08:15 AM   #11
stolleee
My Ride: 2001 325
Where did you buy the part as I cannot find a replacement purge valve for my 2001 325i.. I am having the same code P0444??
stolleee is offline   Reply With Quote
Old 09-12-2008, 11:05 AM   #12
ScoobyBoo
I didn't have any luck either finding the purge valve replacement part online. So, I bought it from the parts department at the local BMW dealership. They have it listed as the "Fuel Tank Breather Valve" on their parts list database at the parts department. It is $80+ without the BMWCCA member discount or $70+ with the BMWCCA member discount.
Old 09-12-2008, 11:22 AM   #13
jbeurotech
Regional Sponsor
My Ride: 2000 E46 with 254K
LOl you don't know where it is but you know its bad from the "code" thats a good laugh for me for the day!!! Test TEST TEST TEST TEST THEN REPALCE!!!!!!!!!!!!!!!
Seth Thorson
Service Manager/BMW Tech
JB Eurotech Service "Your Reasonable Dealer Alternative"
General Questions can be sent to appointment@jbeurotech.com
1. Do not argue with an idiot. He will drag you down to his level and beat you with experience.
2. Light travels faster than sound. This is why some people appear bright until you hear them speak.
jbeurotech is offline   Reply With Quote
Old 09-12-2008, 12:41 PM   #14
stolleee
My Ride: 2001 325
Not sure who you are mocking on this thread, I merely asked where the part was purchased as the MIL triggered last night at 11PM and I have been at work all day. I looked online to determine the worst case scenario (replace) however will diagnose tomorrow to determine if the part is at fault vs. something else. And yes, I have seen your threads about how to diagnose the part on the car.
I dont have the luxury of your job with an abundant of tech's, diagnostic equiptment and part's available to repair as soon as the problem comes up. Remember, their are many people here that are using the forum as a tool for information gathering rather than mocking threads.
Old 09-12-2008, 01:06 PM   #15
ScoobyBoo
jbeurotech, this thread is just about how the malfunctioning EVAP purge valve on my car was replaced which resolved the PO444 fault code in my situation. In my situation, it was a solenoid that went bad on the purge valve [which seems to be a likely culprit of the PO444 code from the feedback that I've heard from a few other customer-oriented BMW service professionals]. Certainly the PO444 fault code could possibly be other issues such as loose wiring, relays/switches, etc. Some of us posting on this online board are spare time DIY'ers and not professional techs like yourself that do this everyday. Your comment about testing before you replace the part is a valid point. But, I believe that I speak for many on this board, that mocking people is not in the spirit of this board. Being a professional tech yourself, perhaps you can contribute to the posts with more detailed and helpful information about what to test, how and where to test, and with what kind of testing tool you recommend using {if you've already posted on the subject of testing for this fault code and situation, posting the link would be helpful}.
Old 09-12-2008, 02:15 PM   #16
jbeurotech
Regional Sponsor
Sorry if it was offensive but replacing a part just because a code said so is stupid! I have posted many times how to test the part to make sure it has failed. I have even posted how to test it with DIY tools. I can do a search for you but I know I have posted at least two times how to test this part. I DO HELP on this board and sometimes my posts are not the most politically correct BUT if you ask for help I will help if you ask to replace a part that you don't know where it is on the car and want to replace it because of a code I KNOW YOU did not test the part. Another member mad e a valid point about the breather line may be broken or have a small hole in it going back to the tank and you dismissed him and said that NOT YOUR ISSUE how do you know if you didn't test. This is were my comments came from. It was not ment as an attack on you just the procedures you used to make this repair.
Seth Thorson
Old 09-12-2008, 02:27 PM   #17
jbeurotech
Regional Sponsor
Heres one
http://forum.e46fanatics.com/showthr...highlight=evap
Seth Thorson
Old 09-12-2008, 02:32 PM   #18
jbeurotech
Regional Sponsor
Another one where I spent time and during proper diagnostic (sorta replaced an expensive maf instead of testing) but the result was a fix would have been quicker if he built the smoke machine and did the test
http://forum.e46fanatics.com/showthr...ht=evap&page=2
Seth Thorson
Old 09-12-2008, 02:59 PM   #19
jbeurotech
Regional Sponsor
Comment was not aimed at you knowing potencial costs and blindly re[placing parts are different things
Seth Thorson
Old 09-12-2008, 03:02 PM   #20
jbeurotech
Regional Sponsor
You have 8 posts on this board before condemning me ask others. I help alot of people here.
Seth Thorson
