Old 12-30-2012, 11:20 PM   #1
eddiebmw
My Ride: BMW E46
Differential problems
Big question, I noticed there is a noise coming from the back of the car and it sounds like something would be rubbing and making the noise as if it were the tire. I've looked up videos and I believe it is the differential, but I not sure how to get rid of the problem. Please help thanks.
Sent from my Nexus 7 using Bimmer App
eddiebmw is offline   Reply With Quote
Old 12-31-2012, 08:12 AM   #2
markusmarkus
My Ride: 2001 330Ci
Eddie, have you checked the differential lube? That's what I'd do first.
Old 12-31-2012, 09:16 AM   #3
eddiebmw
My Ride: BMW E46
Mark no I haven't, well after I check that would should I do next?
Old 12-31-2012, 04:51 PM   #4
markusmarkus
My Ride: 2001 330Ci
Check...
....to see if your tire lugs are properly torqued to ~85ftlbs. Use torque wrench if you can.
Check to see if one of the rear tire's bearing is going bad by:
- removing one of the rear tires
- spread the brake pads away from the disc (I use a screwdriver between the inner pad and the disk; you won't hurt the disk)
- rotate the hub and listen for binding or grinding.
Happy New Year!
Old 12-31-2012, 06:04 PM   #5
eddiebmw
My Ride: BMW E46
Okay, but I earlier did the differential oil change and I realized one of the bushings is really worn out so I believe that's the problem.
Old 01-01-2013, 09:38 AM   #6
markusmarkus
My Ride: 2001 330Ci
Eddie, I have 2 questions:
- what diff fluid did you put in the diff?
- which bushing is worn?
Happy New Year to everyone!
Old 01-01-2013, 10:37 AM   #7
eddiebmw
My Ride: BMW E46
I used Castro 75w-90, and I think it's the bigger one that's right where the differential is, towards the end.
