Sponsored by BimmerWorld
Old 08-25-2008, 02:39 AM   #1
TrippinBimmer
My Ride: Just Fast!
Shock questions....
Well, I decided I will be dropping my Bimmer when the V710's wheels come in... I was thinking about using my stock ZHP 48k Shocks. Or should I save up and get some Koni FSD or ToKico Blue? Not sure I want to spend 700 bucks on shocks...
Input guys...Need some help... deciding
Alpine White M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
Old 08-25-2008, 03:58 AM   #2
Chris-TK
My Ride: Mk VI GTI
Get coilovers instead so you can adjust it to the height you want. Shocks alone won't give you a good drop, you'll need to do a paired spring/shock combo. If you can spend a bit more you'll be much happier.
K.
Chris-TK is offline   Reply With Quote
Old 08-25-2008, 05:46 AM   #3
SL Blak Soldier
My Ride: 3 Pedal SG S54B32
Send a message via AIM to SL Blak Soldier
I roll stock sport shocks on my drop, and its fine for everyday driving.. and they are pretty friggin' blown. Its only when i get into the canyons where i really hate my stock shocks. so i think if your not going to be doing any aggressive driving, just roll stock shocks.
SL Blak Soldier is offline   Reply With Quote
Old 08-25-2008, 11:55 AM   #4
TrippinBimmer
My Ride: Just Fast!
I do not want CoilOvers. To me its to much of a hassle. I will have to get it corner balance everytime I adj the height and get an alignment. I just prefer just to do the traditional spring and shock setup. I will not be tracking the Auto ZHP since it will be no fun doing so until I do the 6 speed tranny swap one day.
Alpine White M3
MaximumPSI Stage4
Old 08-25-2008, 12:31 PM   #5
simsima325
'a certain moderator'
simsima325's Avatar
My Ride: Honda Civic
pretty bad advice. why did you buy a bmw?
just get an H&R Cupkit. its a matched shocks and spring setup that is made to compliment each other. Drop is moderate, ride is nice, cost is low. And you won't have to worry about ur shocks going and you hating yourself within 10k miles.
-Brendan
Old 08-25-2008, 01:37 PM   #6
TrippinBimmer
My Ride: Just Fast!
I really dont want H&R.. Reason, I already bought my EiBach ProKit Springs and I dont like the rake look. At this moment I have a Reverse Rake Look now...
Alpine White M3
MaximumPSI Stage4
Old 08-25-2008, 03:23 PM   #7
Chris-TK
My Ride: Mk VI GTI
The reverse rake is an optical illusion. The front fenders of our cars are higher than that of the rears, making it appear that the car is higher in the front. Don't look at the fenders alone, but the angle of the sideskirts.
K.
Old 08-25-2008, 03:31 PM   #8
Z-PDX
My Ride: 330ci, R6, XR650R
stock shocks, even sport or zhp are underdamped with the stock springs. Adding higher rate drop springs will only make this worse. Get better shocks.
As for waiting for a manual swap before you hit the track... have you really been to a racetrack? Any transmission is good times.
-Z
Z-PDX is offline   Reply With Quote
Old 08-25-2008, 03:55 PM   #9
TrippinBimmer
My Ride: Just Fast!
-Z
I guess I wait and get some FSD Shocks then.... How are the EiBach Pro-Damper Kit? Since it will be similar to the H&R Sport Kit...
Alpine White M3
MaximumPSI Stage4
Old 08-25-2008, 04:20 PM   #10
SL Blak Soldier
...I really wasn't expecting a comment like that from a Mod/Member like you.
Old 08-25-2008, 05:05 PM   #11
simsima325
simsima325's Avatar
^ what does my being a moderator have anything to do with you giving the guy bad advice?
ride quality and performance aside, its simply not safe to roll around on blown shocks. ever seen a car rolling down the highway with its wheels bouncing all around? not only does it hurt ur handling, it decreases braking traction etc.
FWIW, matched setup > blowing out your shocks, any day.
-Brendan
Old 08-25-2008, 06:31 PM   #12
daniel_zhp
My Ride: 03 330i zhp
You should be fine with the stock shocks for now because the Pro kit springs aren't going to lower the car that much from stock. However it's not that much more to get the pro dampers as well and just do it all at once, especially if you're paying someone to do the work. I have the Eibach dampers/springs and I love it...same ride quality as stock but just enough drop to get rid of the wheel gap in the fender.
daniel_zhp is offline   Reply With Quote
Old 08-25-2008, 07:32 PM   #13
TrippinBimmer
My Ride: Just Fast!
I will be doing this myself. I just don't want to spend another $$$ to get the alignment done. I heard the FSD will lower my car even more then the pro-kit itself....
Alpine White M3
MaximumPSI Stage4
Old 08-25-2008, 07:56 PM   #14
shady3one3
Banned
shady3one3's Avatar
My Ride: gets replaced soon.
Send a message via AIM to shady3one3
Actually, stock shocks can be fine. For example, oem m3 shocks are better on paper than H&R's and Bilsteins. That said, stock shocks are going to be bad by 60k no matter what springs you run with them. At 48k, I'd say best bet is to grab some Koni's.
shady3one3 is offline   Reply With Quote
Old 08-25-2008, 08:49 PM   #15
TrippinBimmer
My Ride: Just Fast!
Thanks for the input.... This is what I needed to pull the gun....
Alpine White M3
MaximumPSI Stage4
Old 08-27-2008, 07:41 AM   #16
kaput
My Ride: 2002 M3 SMG
Send a message via AIM to kaput
Koni FSDs and Eibach srping set up. tire Rack sells the set for $870 I think, and honestly, you could get them a little cheaper if you look around.
As for the alignment, you will need to get one, just pony up the $40 and get it done...
You will be much happier.
2002 M3
kaput is offline   Reply With Quote
Old 08-30-2008, 03:28 AM   #17
TrippinBimmer
My Ride: Just Fast!
$40 bucks for an alignment? What type of an Alignment are u getting? I was quoted for $145 from the dealership for a 4 wheel alignment.
Alpine White M3
MaximumPSI Stage4
Old 08-30-2008, 09:55 AM   #18
shady3one3
Banned
shady3one3's Avatar
Do NOT have your alignment done by a place that uses anything other than the Beissbarth BMW approved alignment rack (unless they do it by hand).
Old 09-02-2008, 01:23 AM   #19
ModBargains
ModBargains's Avatar
My Ride: M3
We carry ST coilovers that will fit around your budget. You will be much happier with them than just a normal spring/shock setup. Let me know if you need any help.
Blake Brunner|blake@ModBargains.com|(714) 582-3330 ext. 8011
We Specialize In:
BMW Brakes | BMW Suspension | BMW Parts | BMW Exhaust Experts | BMW Tail Lights |
BMW Wheels | BMW Intake
Hours
Check out our Blog for updates!
ModBargains is offline   Reply With Quote
