Old 08-27-2008, 12:52 AM   #1
monkeyjuice5150
My Ride: ///M3 droptop
Send a message via AIM to monkeyjuice5150
So what is with your MPG with the 3.46 diff now?
As the title said, after you installed your 3.46 diff. What is your MPG now. Normal driving of course.
State your other mods, and tranny.
I have a full catback, with headers. Intake and 3.46 diff on a 5speed.
I'm doing around 15.5 MPG. Pretty low. Used to be around 21-24 MPG with the 2.93 Diff.
Can someone also answer this question for me. If I was to get a chip. Would it be able to fix my MPG to accomandate the headers, and gears?
monkeyjuice5150 is offline   Reply With Quote
Old 08-27-2008, 08:26 AM   #2
Activ3
My Ride: gets DRIVEN.
Send a message via AIM to Activ3
Seems like you lost a lot more than usual... With headers, aa flash, and the 3.46 I was getting ~21mpg.
-David www.e46nonm.com | My Videos
2000 328i - Custom Turbo tuned by AA
Activ3 is offline   Reply With Quote
Old 08-27-2008, 08:33 AM   #3
Custom3
My Ride: HellRot 330CI
i got a full cat back...intake and a 3.46 diff and i went from 21/23 mpg to 19/21 mpg....and this is what my instrument cluster is telling me...i really cant tell a difference...i been filling my car up once a month like before when i had my old diff....surely worth the upgrade...regardless of gas prices
Old 08-27-2008, 08:37 AM   #4
Custom3
and to answer the question about the chip saving you gas...since it raises the red line a bit it probably will save u some gas but it wont be much....
Old 08-27-2008, 12:28 PM   #5
ridin325
My Ride: 2013 911 C2S
In the summer i am averaging 29.9 mpg with 3.46 diff, supercharger @ 8lbs, headers, exhaust, pulleys, and others. In colder weather I average around 33mpg.
ridin325 is offline   Reply With Quote
Old 08-27-2008, 01:46 PM   #6
monkeyjuice5150
wow, is there something wrong with my car then? It's been like this for almost a year now.
Old 08-27-2008, 01:50 PM   #7
keith_m3-4
My Ride: 02 325iT
Wow! "That's Incredible!" You must have no hills, wind and only freeways there.
I can't get any better than 26mpg with conversative driving.
02 Steel Gray VF ZSP 325iT
keith_m3-4 is offline   Reply With Quote
Old 08-27-2008, 02:25 PM   #8
simsima325
'a certain moderator'
simsima325's Avatar
My Ride: Honda Civic
5spd 325, gruppem, shark, RE pullies, 3.46. lots of city driving to work, some highway. 21.5mpg
hung have u done spark plugs lately? injectors? maybe ur ish is gunked up.
-Brendan
Old 08-27-2008, 03:06 PM   #9
monkeyjuice5150
Yeh, I did replace my spark plug with the colder one from when I had the Turbo. Should I put that back to regular spark plug?
I did had injectors at the time too, but since then I put back my oem one.
Probably want to replace the spark and maybe clean the injector huh?
Old 08-28-2008, 02:11 PM   #10
simsima325
simsima325's Avatar
depends on the milage u have on the plugs and injectors i guess, but yes.
hope the turbo didn't eff anything up for u, and all ur seals are still good.
-Brendan
Old 08-29-2008, 12:49 AM   #11
monkeyjuice5150
I think it actually did, ever since I took it off, my engine been giving me problems. Pulled a couple codes.
I need to get a compression tool to test the heads and all.
Just been lazy with it lately since it just sits in the garage most of the time.
Old 08-29-2008, 10:06 AM   #12
simsima325
simsima325's Avatar
that sucks.
o well as long as it has enough power for ya, eff the mileage, u have a DD right? ha.
-Brendan
Old 08-29-2008, 12:10 PM   #13
NightRunner
My Ride: Slowmobile
yes put it back. the "coldness/hotness" level of the sparkplug determines how quicker or slow is dissipates the heat it gets. it helps to know how to read the plugs when tuning.
here's a quick overview that'll give you the gist of it and why you need to correct heat range:
http://www.globaldenso.com/PLUG/basi...nge/index.html
NightRunner is offline   Reply With Quote
Old 09-01-2008, 04:44 PM   #14
simsima325
simsima325's Avatar
i just drove 3hrs, 200 miles, 29mpg.
-Brendan
Old 10-05-2008, 10:24 PM   #15
BMW Loe
My Ride: is dirty
this is late, but I'll log my mpg with my mods....an easy 30+mpg on the highway for me
E92 335i 6spd
BMS JB4 stg 3, BMS DCI, CM methanol injection
04 M3 sold
03 330Ci sold
BMW Loe is offline   Reply With Quote
Old 10-06-2008, 03:52 AM   #16
monkeyjuice5150
I just got done cleaning my CAI filter. I gained 2mpg extra. LOL I guess it makes a world difference.
