Old 10-10-2008, 09:50 AM   #21
shady3one3
Banned
shady3one3's Avatar
My Ride: gets replaced soon.
Send a message via AIM to shady3one3
To properly maximize gains from building internals and/or changing compression...you need a new ECU. To get any appreciable power at all...you need a new ECU. So you need a little under $3k to buy it, you'll need someone familiar with it to help you wire it for at least another $1k, then you need a tuner who has done it before and lots of hours on a dyno....and now we're at $5k on top of the cost of new internals and the labor to swap them. And you still wont be making as much power as an NA S54 with cams and headers, you wont have VANOS anymore, and your motor will need a rebuild it otherwise wouldnt.
Get cams and headers and generic software. If that isn't enough power for you, you need a new motor/car.
shady3one3 is offline   Reply With Quote
Old 10-10-2008, 03:59 PM   #22
Bimmer Dude Xi
My Ride: 03 325XI 07 ZX-6R
Send a message via AIM to Bimmer Dude Xi
where would i find performance camshafts for a 325
|Dinan High Flow Air Box|Eibach Pro Kit|Koni Sport|UUC Strut Barbarian|UUC TSE3|UUC Underdrive Pulleys|18" VMR V710|
|BMC Race Air Filter|CRG Spectrum Levers| Galfer Steel Braided Brake Lines|Volar Motorsport Spiked Frame & Bar-end Sliders|
Bimmer Dude Xi is offline   Reply With Quote
Old 10-10-2008, 10:37 PM   #23
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Stick a supercharger kit on and call it a day.
Rebuilding an M54 isn't for the meek.
Old 10-11-2008, 02:51 AM   #24
mkodama
mkodama's Avatar
+1
Swapping engines or internals would give you electronic nightmares. E46's have tons of electronics and security features and what not.
Bolting on a supercharger and having the ECU reflashed with appropriate tuning would be soooooo much quicker, cheaper, and easier.
Old 10-11-2008, 07:42 AM   #25
shady3one3
Banned
shady3one3's Avatar
VAC sells two different Schrick options somewhere between $1200 and $1300.
Old 10-11-2008, 09:50 AM   #26
gialaur
My Ride: 323
I just saw on e bay some one selling internals for $300
gialaur is offline   Reply With Quote
