Sponsored by BimmerWorld
Old 08-28-2008, 12:17 AM   #1
THXZHP
My Ride: IR ZHP sedan
Lowering ZHP Sedan, Couple Questions
hey everyone, so i'm gathering information about lowering my car. i have a 2004 330i ZHP so as yyou know it already comes with a lower suspension setup than your average sport package equip sedan ... with that said could i get away with an eibach pro or sportline lowering spring kit? i have 19x8.5 in 235/35/19 in the front with a +40mm offset and 19x9.5 in 265/20/19 in the rear with a +39mm offset. i rub slightly in the rear even after rolling my fenders and am worried that the problem will only worsen depending on how low i go. what can i do to prevent rubbing when lowering my car and what would give me the best drop given that i want to rid my car of any fender gap that exist (don't think i want to slam it but what'd you think?) opinions and comments please, i'm dying here!
regards,
tyler
THXZHP is offline   Reply With Quote
Old 08-28-2008, 12:26 AM   #2
Define ///M3
My Ride: E92
hey tyler, i also have a 330 whatcya-ma-call it and have just completely took of my shocks and suspension for ultimate lowering appearance. i highly recomend you do this aswell as it would compliment your offsets.
Regards,
Rob chavis
Define M3
tiag 2000 323ci - sold
BSM 2004 325ci - sold
AW 2013 328i - sold
MWM 2012 e92 328i - current
Looking 4 e46 M3
Define ///M3 is offline   Reply With Quote
Old 08-28-2008, 12:37 AM   #3
samBROchill330i
My Ride: Dinan 330i
Regards,
Rob chavis
Performance: Dinan Stg 3, Dinan Perf Tranny Software, Dinan High Flow Throttle Body, Dinan High Flow Intake, UUC TSE3~TMS Power Pulleys
Suspension: Eibach Sportlines, Koni Sports, Ground Control RSMs, Dinan Strut Brace, Eibach Sways, Ground Control Endlinks, Poly RTABs
Exterior: Painted Kidney Grille, BSM Roundels, Clear Sides, Corners, & Tails, 3M Tint 20% Rear, 35% Front, Halogen to P46/AE
Wheels: Staggered 19" V710s on T1Rs
samBROchill330i is offline   Reply With Quote
Old 08-28-2008, 01:14 AM   #4
Arrows
My Ride: 2000 323i.
Send a message via AIM to Arrows Send a message via MSN to Arrows
regards,
tyler
Firstly, I hope your running 265/30/19 and not 265/20/19. Sedans have a little less rear clearance for tires than coupes, so the max I suggest on sedans is 255. If you get 255's in the rears, you're rubbing should go away, unless fenders weren't rolled well.
As for springs, what kind of drop are you looking for? I'd suggest getting coilovers if funds permit, it gives you the ability to adjust your ride height to what your satisfied with, or at the minimum a spring and shock combo like the H&R Cupkit.
Arrows is offline   Reply With Quote
Old 08-28-2008, 08:46 PM   #5
THXZHP
huggy1989
okay? that's why you go off and install struts only to have them blow through your trunk liner and stop searching every post of mine and commenting on it.
arrows
the drop i'm looking for is similar to that of xjunmoonx though i believe he has coilovers ... and if not then just enough to rid my car of the fender gap, even with the h&r cup kit there's still some it seems like.
regards,
tyler
Old 08-28-2008, 09:08 PM   #6
BreakMyWallet
My Ride: B6 A4/ Mini Cooper S
jun is on coils. coils are your best bet man as for the rubbing maybe u need a more aggressive rol.. did u take all the gunk out of the lining?
265 is just too wide.. 255 will be better but i would rock 245's. thats my preference... with a sloped sidewall just to be safe
BreakMyWallet is offline   Reply With Quote
Old 08-28-2008, 09:49 PM   #7
04 ZHP in UT
My Ride: 04 330i ZHP
I think coilovers are going to be your best bet. I just put Bilstein PSS on my ZHP about a month ago. I did it for the same reason you're looking for. I didn't want it slammed just wanted to get rid of the gap. I think in the long run the ability to adjust the height to what YOU want is well worth the extra $$.
2007 RS4/Tubi Exhaust
2004 Imola Red ZHP (Sold)
04 ZHP in UT is offline   Reply With Quote
Old 08-28-2008, 09:52 PM   #8
Define ///M3
My Ride: E92
they blew through the trunk so i could get the appearance of hydrolics for my bimmer
regards, Rob Chavis Jr.
Define M3
AW 2013 328i - sold
Looking 4 e46 M3
Old 09-07-2008, 01:31 PM   #9
ModBargains
ModBargains's Avatar
My Ride: M3
The best solution is to go with a good set of coilovers and just be done with it. With lowering springs you are going to have to replace your shocks a little more down the line. Then you will end up paying more with parts and labor, rather than just getting a set of coilovers in the first place. I recommend going with some ST coilovers. They are very affordable and we have received nothing but great reviews from all of the people who have purchased them. Including the owner of ModBargains.com. Let me know if I can help you get a set.
Blake Brunner|blake@ModBargains.com|(714) 582-3330 ext. 8011
We Specialize In:
BMW Brakes | BMW Suspension | BMW Parts | BMW Exhaust Experts | BMW Tail Lights |
BMW Wheels | BMW Intake
Hours
Check out our Blog for updates!
ModBargains is offline   Reply With Quote
