Sponsored by BimmerWorld
Old 08-28-2008, 03:15 AM   #1
hurls
My Ride: 2000 323iT
Bilstein Sports with stock sport suspension
I've got a 2000 323iT with the factory sports suspension. 75k miles.
Had to replace a leaky rear shock during the winter and my independent mechanic recommended (and installed) Bilstein Sports on the rear.
I'm thinking that it's time to replace the front shocks now, and as I've (belatedly) been doing some research, I'm trying to figure out if the sports are the best match for this suspension.
Read jpr's thread on Bilsteins (http://forum.e46fanatics.com/showthread.php?t=517995) and I guess what i'm trying to figure out is if the MY2000 sport springs are short enough to warrant the sport shocks (with their reduced body length), or if I would have been better off with the HDs.
If they were too short, what would I be noticing now? Bottoming out? The Bilsteins are definitely harsher than the stock (and worn) Sachs were, but I can't say that I feel like I'm hitting the bump stops a lot more than I had been before.
Bilsteins for the rear are only $75 a pop, so if I'd really be better off with the HDs, it wouldn't hurt to replace these almost new shocks back there while I'm at it (not counting the labor -- though I'm about to do my first ever shock change on my Miata, so i guess I'll soon know if I'm up to a DIY)
My preference, if it makes sense, would be to just put the matching Bilstein sport struts up front, but if I'm making a bad choice for these springs I won't.
(Of course if I replace the rears, wouldn't have to stick to the Bilsteins and could consider the Koni FSDs too....).
I searched, and did see some folks saying they were running the sports with stock sport springs, but also some posts that made me wonder if the HDs would be a better match. Any thoughts?
Thanks!
hurls is offline   Reply With Quote
Old 09-04-2008, 06:35 PM   #2
hurls
My Ride: 2000 323iT
I promise just one time... bump....anyone have an opinion?
Old 09-04-2008, 06:38 PM   #3
keith_m3-4
My Ride: 02 325iT
My suggestion is to match your rear shocks.
02 Steel Gray VF ZSP 325iT
keith_m3-4 is offline   Reply With Quote
Old 09-06-2008, 02:08 AM   #4
hurls
My Ride: 2000 323iT
Thanks Keith... that's my plan unless I hear something compelling otherwise... just had a bit of fear I shouldn't be using the sports after reading a few older posts!
Old 09-06-2008, 01:22 PM   #5
jtblkice
My Ride: 2003 BMW 325I
ive been asking the same thing. I have sport suspension and wondering which to get. I was told to get the sports. they have a special in the group buy section on bimmerforums.com cheapest ive see anywhere by like 100 bucks for a full set
Create your own banner at mybannermaker.com!
jtblkice is offline   Reply With Quote
Old 09-07-2008, 07:00 PM   #6
hurls
My Ride: 2000 323iT
Thanks for the pointer JTBLKICE... I'll check that out.. I only need the front struts, the rear shocks only have about 2k miles on them. I just want to match all around (and replace the old front struts)
bilstein, sport package suspension
