Emergency - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 05-14-2002, 02:22 PM   #1
328gen1
Send a message via AIM to 328gen1
Emergency
im driving home from the mall and i my windows are rolled down cuz in houston it is finally nice out. My friend then asks to roll them back up because her hair was bothering her. I roll em up and look back to see that my passenger rear window is only half-way up! Is there any way i can manually roll it up? I have a big celebration dinner tonite (last day of highschool) and can't roll into valet with a bootleg window. I have a service appt for tom. morning but needed a quick fix. 40 g's and my window doesn't work...ill be damned
-B-
328gen1 is offline   Reply With Quote
Old 05-14-2002, 02:24 PM   #2
B
OG Moderator Extraordinaire
B's Avatar
My Ride: 325iX-M3-525iT-M5
Send a message via AIM to B
I'm not sure about the window... but I'm B... not you! :tongue:
B is offline   Reply With Quote
Old 05-14-2002, 02:31 PM   #3
teamdfl
Slow in, slower out
My Ride: 325it
In the old days
In the old days before OBDII, SMG, and M is for Marketing, BMW put small plastic plugs in the doors to allow access to the window motor gearbox. You could pop off the plug and use an allen wrench provided in the tool kit to crank up the window manually.
Just one more step in the Camryization of BMW.
Ed
Mod the driver. Participate in your local BMWCCA autocross or driving school. Have you joined BMWCCA yet?
teamdfl is offline   Reply With Quote
Old 05-14-2002, 02:31 PM   #4
jpetch
need $$$
My Ride: 2004 M3 SMG
its probably the window regulator inside the door. its probably broken. i had the same problem on my passenger door, the window would not roll up all the way. there isnt a way to close it unless you take it to the dealer and have them replace the regulator. it sucks, but there isnt a thing you can do.
jpetch is offline   Reply With Quote
Old 05-14-2002, 02:38 PM   #5
XeetBMW330ci
www.xeetstreetband.com
Location: Holland, MI - Osage Beach, MO - Rancho Palos Verdes, CA
My Ride: 2002 BMW 330Ci
Send a message via AIM to XeetBMW330ci
Roll down all your windows to the height of the broken one.
XeetBMW330ci is offline   Reply With Quote
Old 05-14-2002, 02:39 PM   #6
BlueMalibu
My Ride: 2000 323i sp stick
Send a message via AIM to BlueMalibu
Try This
This owrked for me when my regulator went.
With ignition on open door.
Stand outside by door and put one hand palm on each side of the glass. While someone else operates the up button press your palmes together with the glass sandwiched between them and lift. Should work.
'00 323i, Sport, Stick, CD, HK, FDRS, DYI CAI
DYI Resonator removal
Lightweight battery
BlueMalibu is offline   Reply With Quote
Old 05-14-2002, 02:40 PM   #7
XeetBMW330ci
BlueMalibu, where in MI are you?
Old 05-14-2002, 02:52 PM   #8
JetBlackE46
Modded
My Ride: E36/E46 M3 E46 323
try using your key from outside the car...if you're lucky it's just the button thats broken and not the regulator.
JetBlackE46 is offline   Reply With Quote
