Go Back   E46Fanatics > Tuning & Tech > Suspension & Braking
Old 09-03-2008, 02:15 PM   #1
erbeman
My Ride: 99 323I
Can I get your non-biased advise?
I've got a 99 323i sedan and I just hit 100,000 miles. My cheap rims are bent and my suspension is about worn out, so I'm replacing it all. I have decided on Velocity Motoring V710's staggered with 19x8.5 in the front and 19x9.5 in the back with BF-Goodrich G-Force 235/35/19 on the front and 245/30/19 in the rear.
Here is where I need advise; I don't track my car, I simply drive fast on the road. So, I've done some research and it looks like Bilstein PSS suspension kit is very popular as is the H&R coil over kit. I like that I can adjust the hight so coil over is where I want to go. There is only a few hundred dollars seperating the two kits and they come with the same stuff. What else in the suspension should I replace when getting the coilovers installed?
Thanks in advance for your replies.
www.RussErbePhotography.com
http://www.sportsshooter.com/erbeman
D700, D300, Nikkor 35-70 F/2.8, Nikkor 50mm F/1.8, Nikkor 70-200 AF-S VR F/2.8, Nikkor AF-S 1.7 teleconverter II,(2) Profoto D1 500 Air,SB-900, SB-600, (2)MB-D10, MacBook Pro
erbeman is offline   Reply With Quote
Old 09-03-2008, 02:19 PM   #2
simsima325
'a certain moderator'
simsima325's Avatar
My Ride: Honda Civic
Def. replace the rear shock mounts. I went with M3 Vert RSM's and Z3 Reinforcement plates when I put the PSS in, and have had no issues. All OEM.
Also consider taking a look at your Control Arms and Bushings up front, if you haven't done that lately. Since you are doing all that work, its probably a good time to get them swapped out if they are worn/bent.
Old 09-03-2008, 02:20 PM   #3
BartenderPlease
My Ride: 328i Sport
Send a message via AIM to BartenderPlease
replace all the suspension bushings. can't give you a full list, but somebody will probably chime in
Gottalovethexi: thx for the old p-chopped sig
| BBS CH | FK coils | RE Bushings/Mounts | K&N Intake | ZHP box/no resonators |
| 330i brakes | FX-R + Orion V4 | Full Exterior LED kit | JL Audio in trunk |
BartenderPlease is offline   Reply With Quote
Old 09-03-2008, 02:30 PM   #4
Snik
Snik's Avatar
My Ride: IR M3 Vert.
RSM, and cupkit. do a few rear end bushings, RTAB, RCAB and crap like that. have the front checked and inspected too.
Stuff for sale!!!!!
Do you ride a sportbike?
Snik is online now   Reply With Quote
Old 09-03-2008, 05:07 PM   #5
shady3one3
Banned
shady3one3's Avatar
My Ride: gets replaced soon.
Send a message via AIM to shady3one3
Stay away from the cupkit, and check all your bushings As B said, definitely get new shock mounts.
shady3one3 is offline   Reply With Quote
Old 09-03-2008, 05:49 PM   #6
simsima325
simsima325's Avatar
no cupkit, he already stated he wants height adjustability.
o, and don't forget a nice alignment afterwards
Old 09-03-2008, 07:59 PM   #7
Snik
Snik's Avatar
Why must u guys dog the cupkit so bad. Damn.
Stuff for sale!!!!!
Old 09-03-2008, 09:47 PM   #8
simsima325
simsima325's Avatar
because you can't read posts
Old 09-04-2008, 12:18 AM   #9
Snik
Snik's Avatar
Besides that smarty
Stuff for sale!!!!!
Old 09-04-2008, 07:32 AM   #10
shady3one3
Banned
shady3one3's Avatar
The cupkit sucks. Having dyno'd the cupkit shocks, I can tell you they are probably the very last thing I'd choose.
Old 09-04-2008, 08:25 AM   #11
erbeman
My Ride: 99 323I
What are RTAB and RCAB? Thanks
Old 09-04-2008, 08:31 AM   #12
blksedan
My Ride: HATES thieves
sorry to thread jack...do u have a side view of your car with that spoiler and back view?
blksedan is offline   Reply With Quote
Old 09-04-2008, 09:55 AM   #13
erbeman
My Ride: 99 323I
Click on the link to my website in my signature and go to my cars album. There you will find several pics of my car from different views.
Old 09-04-2008, 11:12 AM   #14
n2Bimmer
My Ride: Loves Corners
you will be okay with 245/35/19, if you want 255's get 30. i have 245/35/19 on my sedan.
Old 09-04-2008, 03:27 PM   #15
Chris-TK
My Ride: Mazda
Either one of those coilovers are good. I might go with the H&R because it goes lower. Definitely get some Rogue RSMs because they're mounted from the underside and are much better quality than other brands. Might also want to think about getting some new Meyle HD control arms and bushings while you're at it.
K.
Chris-TK is offline   Reply With Quote
Old 09-04-2008, 03:46 PM   #16
Snik
Snik's Avatar
RTAB- rear trailin arm bushing
RCAB - rear control arm bushing
Stuff for sale!!!!!
Old 09-04-2008, 04:33 PM   #17
erbeman
My Ride: 99 323I
Great, hey thanks everyone for your advise. I'll be sure and do some before and after shots and post them up when I get everything.
Old 09-04-2008, 05:52 PM   #18
Snik
Snik's Avatar
Hmm, well I already have em, and I've been thinking about changing the shocks, do you think some Koni yellows will do the trick, and still ride well and match the springs?
Stuff for sale!!!!!
Old 09-04-2008, 07:14 PM   #19
bigjae1976
bigjae1976's Avatar
My Ride: A car
I really consider how often you'd change the height. I got the PSSs for the adjustability and the only time the height adjustment has been touched is when the car was corner balanced. The PSSs at the highest setting will be about 3/4 lower front and rear than the sport suspension. If you want slammed, I think the Koni's would be better from what I've read.
The drop wasn't the most important thing to me. I bought the Bilsteins knowing that other brands can go a little lower. But I love the PSSs so far. I'm glad I didn't go with the PSS9s.
Hope that helps.
bigjae1976 is online now   Reply With Quote
Old 09-07-2008, 12:17 PM   #20
ModBargains
ModBargains's Avatar
My Ride: E30 325e & E46 ZHP
Have you considered the ST coilovers? They are a little more affordable than the PSS and they are just as good. Plus we offer free shipping to the lower 48 states. But, if you choose to go with the Bilstiens, we have you covered too. Let me know if you would like a quote.
ELLIOTT GOODMAN
Elliott@ModBargains.com | (714) 582-3330 ext. 8009
Hours: Monday - Friday 8:00am-7:00pm | Saturday 8:00am-5:00pm (PST)
Authorized Dealer of: Forgestar Wheels l KW Coilovers l D-Force Wheels l BMW E46 Parts l BMW Angel Eyes |BMW Accessories
ModBargains is offline   Reply With Quote
