Old 09-05-2008, 02:47 PM   #1
330izzle
My Ride: 2001 330i
SES Codes
i need help on trying to fix the two codes that are showing up, first is code P1447 which is saying Diagnostic Module Tank Leakage (DM-TL) Pump Too High During Switching (BMW). then the second one is P0369 Camshaft Position Sensor B Circuit Intermittent (Bank 1)... can someone please help me bcuz i'm a total noob and don't wanna take it into a dealership.
330izzle is offline   Reply With Quote
Old 09-06-2008, 12:25 PM   #2
kentrob11
My Ride: 2001 BMW 330ci
I need the answer to this as well...
2001 330ci
kentrob11 is offline   Reply With Quote
Old 09-06-2008, 07:10 PM   #3
330izzle
My Ride: 2001 330i
cmon people...please help us!!
Old 09-10-2008, 02:16 PM   #4
330izzle
My Ride: 2001 330i
help!
Old 09-10-2008, 05:20 PM   #5
locodice
My Ride: zhp
DM-TL Module
i did have P1449 ..1447-1449 its the same error pump too high or low..anyways ..the first thing you should check is the gas cap (maybe is not sit well or the cap is defected or old) try that its $15 at dealer..clear the code and hopefully will not come back if its comes back under 50 miles than u gotta get that DM_TL module replaced ..i guess i paid $350-360.. but no more errors..
locodice is offline   Reply With Quote
Old 09-11-2008, 01:49 PM   #6
330izzle
My Ride: 2001 330i
thanks for the help! one code down and one more to go!!
Old 09-16-2008, 12:08 AM   #7
TheMadDutchman
My Ride: '04 330i ZHP
Check the exhaust camshaft sensor connector for oil. If you find oil in the connector portion of the sensor you should replace it along with the o-ring. Don't get an aftermarket piece, dealer only. After the sensor is replaced, clean the electrical connector with some electrical contact cleaner.
Good luck!
Here is a pic of the location of the exhaust camshaft position sensor.
TheMadDutchman is offline   Reply With Quote
Old 09-16-2008, 12:30 AM   #8
immigrant
My Ride: 2001 BMW 330CI
Send a message via MSN to immigrant
check the elbow part of the intake hose
immigrant is offline   Reply With Quote
Old 09-25-2008, 01:32 PM   #9
330izzle
My Ride: 2001 330i
thanks guys!! ill try both and see what happens...
