Old 09-05-2008, 05:29 PM   #1
Alex323Ci
My Ride: M3 & 323Ci (sold)
Does FI need different spark plugs?
I was wondering on a FI system does it need different temp range spark plugs? With the extra air/fuel I would think the cylinder would be hotter. I haven't seen it posted, so I guess not. But if so, is there a preferred plug for FI engines?
Old 09-05-2008, 07:44 PM   #2
SPDu4ea
My Ride: .
It'll depend on the particular setup, but yes new plugs are probably going to be a good idea. Might be a heat range or two colder, might be gapped smaller. Check with the manufacturer of the kit you're looking at (many will come with plugs already)
SPDu4ea is offline   Reply With Quote
Old 09-06-2008, 12:30 PM   #3
blueapplesoda
My Ride: e30 Turbo
Send a message via AIM to blueapplesoda
for any fi setup i would run colder plugs....even on a race na motor we use colder plugs. it helps resist detonation when boosted, and yes, chamber temps are obviously warmer fi than na.
blueapplesoda is offline   Reply With Quote
Old 09-06-2008, 12:33 PM   #4
blueapplesoda
My Ride: e30 Turbo
ive had good luck with NGK Iridium spark plugs....i used to use the cheapest copper cored ngks and bosch supers cause they were cheap, but they kept being blown out at boost pressures higher than 8psi (and they were gapped pretty close), the Iridiums tend to hold their spark under higher intake turbulences. they say for every 75-100hp over stock you take one step colder on the plugs.
Old 09-08-2008, 02:59 PM   #5
Alex323Ci
Thanks for the info guys. I'll check with the maker of the kit and see if they suggest a certain plug and temp.
