Thread Tools Search this Thread Rating: Thread Rating: 496 votes, 5.00 average. Display Modes
Old 02-22-2013, 05:53 PM   #521
E46Snowball
My Ride: 330i
Thumbs Up
Originally Posted by Kmoy2002 View Post
My DIY Power Steering Vent Tube
http://forum.e46fanatics.com/showthread.php?t=965436
If you're tired of keeping your power steering reservoir clean all the time a solution is to change the gasket along the cap however that isn't the definitive answer. If you will examine, your PS reservoir has a vent hole which spews out power steering fluid vapor which in turn coats your reservoir with this black greasy grit. The solution, a quick vent tube that directs the vapors elsewhere.
Parts
BMW Vacuum Hose P/N11727545323
1/8" to 1/8" male to male fitting
Directions
- Clean your messy reservoir
- Attach one end of the fitting to the hose
- Attach other end with attached cable to vent hole (You may need to trim the fitting to get it to fit since it is not exactly a 1/8" dia.)
- Route vacuum hose to your place of choice. I chose to vent the vapors to the pavement. The meter long vacuum hose is more than ample enough to reach.
Looks pretty original if you ask me and you will no longer have a dirty reservoir to clean anymore
Wow cool idea!
2003 330i
Imola Red
Zhp Package
6 speed
E46Snowball is offline   Reply With Quote
Old 02-22-2013, 07:00 PM   #522
325CiMaN
My Ride: 01 BMW 325ci 3.0L
Originally Posted by mujjuman View Post
That's true...
No back pressure equals higher end power and loss of low end torque aka feels like a turd. Just the right amount equals low end torque and mid to high power band and to much equals loss in everything. Going by my personal experience racing and building race cars and by my instructors at school
325CiMaN is offline   Reply With Quote
Old 03-11-2013, 09:03 PM   #523
trj
My Ride: 325Ci
DIY fishing rod holder for the trunk
Cost:
Around $7
DIY link:
http://forum.e46fanatics.com/showthread.php?t=975707
Old 03-11-2013, 09:24 PM   #524
KrasivataSabine
My Ride: 323Ci
I'm assuming what you are talking about torque and power as a function of pipe diameter, yes? The old myth that says:
Wider pipe = less back pressure = more power/less torque
Narrower pipe = more back pressure = less power/more bottom end torque
This is an myth that only has a stay in motoring because it makes sense intuitively. The fact is that narrower pipes, when designed properly, increase the exhaust velocity (venturi principle). Greater exhaust velocity leads to lower pressure in the headers, and ultimately scavenges exhaust gasses from the combustion chambers more efficiently. It is not back pressure that increases bottom end torque, it is the scavenging effect.
It follows that a wider diameter pipe does not reduce torque due to less back pressure, but rather because it reduces the exhaust velocity, and thus the scavenging effect within the combustion chamber/exhaust port. The benefit is that, because of the lower exhaust velocity, wider pipes allow the same mass flow rate with less kinetic energy in the expelled fluid, which means more top end power.
http://www.motoiq.com/magazine_artic...rk-part-1.aspx
Someone correct me if I'm wrong, but please provide supporting info.
#BattleBimmer #323RS
KrasivataSabine is offline   Reply With Quote
Old 04-02-2013, 11:05 PM   #525
iRide113
My Ride: 2004 M3
Originally Posted by paraklas View Post
MOD NAME: Alarm Shock Sensor install
MOD COST: $10.00
MOD BENEFIT: Increase the functionality of OEM Alarm
MOD DESCRIPTION (PICS OR FAIL)
MOD LINK (other sites/threads that contain a comprehensive DIY or provide more info)
DIY Link
Digging up an old grave, but do you know exactly what sensor that is and where can I get it? I'm on page 14 going through right now.
iRide113 is offline   Reply With Quote
Old 04-03-2013, 12:31 AM   #526
iRide113
My Ride: 2004 M3
Additional 12V Power Sockets and USB Charging
So this really isn't a new idea, but I can't remember where the idea came from, but here is my first DIY. I searched to see if I could find anything similar on here, but couldn't find something exactly like it. So if there is another like this, feel free to let me know, and I'll ask a mod to remove the thread!
Mod Name: Glove box charging!
Mod Cost: Depends on the outlet you choose
Mod Benefit: More outlets and USB charging
Finished Product:
Part List:
Add-a-Circuit (Direct Wire Fuse kit)
Inline Fuse Holder (Radio Shack) holds 5x20mm fuses
6.3A 5x20mm fuse
sheet metal screw
20 Gauge wire
18-22 Gauge butt connectors
3M Double Sided Tape
Outlet (the one I used)
Instructions:
Step 1:
Remove the glove compartment.
Step 2:
Prep the adapter. Cut the wires, find which one is positive (use a multimeter) and wire in the in-line fuse to the positive wire.
Step 3:
We need to find a fuse that only gets switched on with the ignition. I chose Fuse #26 which is the Garage Door Opener. Place the 'add a circuit' in the fuse slot, and then add the original 5A Garage Door Opener fuse along with another 5A fuse to the two open slots on it.
Step 4:
Drill a small hole in the right bracket by the fuse box to make a ground. Make sure your drill bit isn't cheap, because the metal is pretty strong. Attach a ground cable using a eyelet.
Step 5:
Run the wire from the fuse box up, behind the whole fuse module and then do the same with the ground - make it as neat as possible.
Step 6:
Attach the wires from the fuse and ground to the postive/negative leads coming from the outlet module using the butt connectors.
Step 7:
Attach the outlet module to the metal top using the 3M tape, put the glove box back on, and viola! You now have extra outlets in your glove box!
Old 04-08-2013, 07:20 AM   #527
kroh
My Ride: 2001ish 325i
Send a message via ICQ to kroh Send a message via AIM to kroh
Originally Posted by iRide113 View Post
Part List:
6.3A 5x20mm fuse
I don't understand. Aren't you fusing the same wire twice?
  • Dinan
    • Intake
    • Exhaust
    • Stage II flash
    • Strut brace
  • Bavarian Autosport ignition
  • Z3 short shift kit
  • Turner Motorsport
    • Subframe reinforcement
    • Front & rear swaybars
    • Rear CA bushing limiters
  • ZHP/Bilstein suspension
  • MTech II kit/OEM facelift
  • Ski hatch Solo-Baric sub
kroh is offline   Reply With Quote
Old 04-08-2013, 09:31 AM   #528
aahmed2016
My Ride: 2003 330i ZSP/CP/PP
No, I believe one fuse is for the original fuse (the place that the add-a-circuit took) and then the second one is the one for the wire.
Originally Posted by MercForHire View Post
Spends $2000 on car DVD + stereo -> Running 25000 mile oil changes and 87 gas with blown shocks
aahmed2016 is offline   Reply With Quote
Old 04-08-2013, 04:07 PM   #529
iRide113
My Ride: 2004 M3
Partially correct. The fuse is also acting as a voltage regulator and preventing an over voltage on the USB circuit board. The source was a direct tap to a switched fuse on the board also so there is no other fuse present.
Just better to be safe than sorry!
Old 05-17-2013, 01:20 AM   #530
ccaudio1
My Ride: 330i
you can use any aftermarket alarm 3 wire shock sensor
Ride: 2001 330i
Radio: Clarion NX500
Amps: Diamond Audio
Speakers: DLS Audio
Subwoofers: (2) 12" MB Quarts
MODS: Coming Soon
ccaudio1 is offline   Reply With Quote
Old 05-17-2013, 03:40 AM   #531
braaang
My Ride: E46 M3
completely correct. its all about exhaust velocity, and not backpressure. still surprises me how many ppl profess otherwise.
braaang is offline   Reply With Quote
Old 06-02-2013, 06:48 PM   #532
enjoipotter
My Ride: 2000 323i
Free mods / cheap mods under $10 DIY
Can we all agree to stop asking if your car supports the golf tee mod? Just ****ing walk up to your exhaust and look inside it. I think roughly 70% of this thread is people asking the same damn question.
Ride Smooth
enjoipotter is offline   Reply With Quote
Old 06-02-2013, 07:22 PM   #533
mkodama
mkodama's Avatar
Yeah, lazy people are usually annoying.
Old 06-03-2013, 01:20 AM   #534
iRide113
My Ride: 2004 M3
You dig up an old thread and get mad about something that hasn't been asked for months? Lol.
Old 03-24-2014, 09:39 AM   #535
Non-Affiliated
My Ride: 01 330i
So I'm brand new to the world of e46. Can't wait to try some of these mods on my 330i.
Definitely subscribed.
Non-Affiliated is offline   Reply With Quote
Old 03-24-2014, 09:39 AM   #536
Non-Affiliated
My Ride: 01 330i
Old 05-14-2014, 05:16 AM   #537
hloke1
My Ride: 99 323i
Send a message via ICQ to hloke1
Bumper Mods
Considering I had the ugly non sport front bumper with the large black number plate holder & long fog lights, I cut the bottom of the black plastic number plate thing to look like the number plate delete strip ($25AUD?) & added yellow headlight tint to the fog lights (seen on many e30's and such).
hloke1 is offline   Reply With Quote
Old 06-10-2014, 09:27 PM   #538
Non-Affiliated
My Ride: 01 330i
Can't wait till I have the time to try some of these mods out.
Especially the golf tee and yellow reflector bowls.
Old 06-10-2014, 09:27 PM   #539
Non-Affiliated
My Ride: 01 330i
Old 06-13-2014, 12:32 PM   #540
ramitchell
My Ride: 330CiC M-Sport
Wow! Great bunch of mods! Maybe this should be 'stickied'. BTW - what size golf tee should I use, HeeHee?
You are only paranoid until you are correct....then you are a visionary
ramitchell is offline   Reply With Quote
