Go Back   E46Fanatics > Tuning & Tech > Forced Induction Forum Sponsored by Active Autowerke
Old 09-13-2008, 01:30 PM   #1
yellowssm
My Ride: 2005 M3
To the HPF guys, what brand racing fuel are you using?
I know the normal that most people use is VP racing 110 leaded and Sunocco "the standard" which is there 110 leaded.
The cheapest place in town I found sells Rockett Brand racing fuel and it is 111 leaded and it is almost $1 cheaper a gallon than VP.
Here is a link to the Rockett Brand racing fuels:
http://www.rockettbrand.com/productspecs/specs.html
Will this be ok to use?
Here are the stats of all three brands:
VP 110 leaded
Color: Purple
• MON: 107
• RON 113
• R+M/2 = 110
• Specific Gravity: .720-.735 @ 60° F
Rockett 111 leaded
Color: Red
• MON: 106
• RON 116
• R+M/2 = 111
• Specific Gravity: .726 @ 60° F
Sunocco "the standard" 110 leaded
Color: Purple
• MON: 105
• RON 115
• R+M/2 = 110
• Specific Gravity: .728 @ 60° F
yellowssm is offline   Reply With Quote
Old 09-13-2008, 01:46 PM   #2
OCswedishM3
My Ride: E63 AMG
VP 110 leaded
Color: Purple
• MON: 107
• RON 113
• R+M/2 = 110
Rockett 111 leaded
Color: Red
• MON: 106
• RON 116
• R+M/2 = 111
Color: Purple
• MON: 105
• RON 115
• R+M/2 = 110
Vp is overrated. The best brand is Sunoco, and it is cheaper. Never heard of rockett before. Why dont you run Sunoco GT+. It is unleaded and will provide just as much protection as 110 leaded(and more power). And wont destroy your o2 sensors.
OCswedishM3 is offline   Reply With Quote
Old 09-13-2008, 02:00 PM   #3
gasser
My Ride: 2003 M3
The race gas setup for the HPF cars requires minimum 110oct. GT+ is only 104oct and won't provide as much protection as 110. It will give you some more power b/c it is oxygenated, but that is usually due to it leaning you out some. More octane (leaded gas) will keep the detonation issues down, allowing more timing, but does kill the O2 sensors. I ran 5-10 gallons of leaded through my Audi S4 all the time and just made sure to dilute it with unleaded after I was done having fun. I probably ran 100+gallons of leaded through it and NO issues with my sensors. I data-logged every 1/4 mile run and tuning session and the sensors would react slower for a few days, then they would be ok again. I know it would eventually kill them, but it is the price to pay for being able to turn up the boost and keep the timing high. Just my 2cents....
gasser is offline   Reply With Quote
Old 09-13-2008, 02:09 PM   #4
yellowssm
My Ride: 2005 M3
I havent found any places here in vegas that sells sunocco.
I see you are in vegas, Have you seen 110 leaded around? Preferbly on the west side of town.
Old 09-13-2008, 03:35 PM   #5
OCswedishM3
My Ride: E63 AMG
PM me and i'll give you the number to my wholesale account. You can only order 55gallon drums though , so you would have to store it in your garage or in your backyard. If i were you i would order the Sunoco 112 leaded.
Old 09-13-2008, 04:10 PM   #6
pastE36prsntE46
My Ride: HPF STG 3; 95 FI M3
What is the approximate price per gallon?
pastE36prsntE46 is offline   Reply With Quote
Old 09-13-2008, 04:17 PM   #7
yellowssm
My Ride: 2005 M3
I found VP 110 for a little over $8 a gallon and Rockett Brand 111 for $7.25 a gallon. The only problem is I have to drive 40 minutes to get the VP and the Rockett Brand is 5 minutes away.
Old 09-13-2008, 04:19 PM   #8
funkboy316
My Ride: 2003 M3 vert
i use the sunoco 112 leaded.
2003 TiAg HPF stage 2.5 SMG M3 vert
funkboy316 is offline   Reply With Quote
Old 09-13-2008, 05:36 PM   #9
gasser
My Ride: 2003 M3
Hey Ray, it's me Brian from down the street, this is just a different screen name than I use on the other forum. Where did you find the Rockett fuel so close? Just use that stuff, cheaper and closer. I know of plenty of people that have used it and works just fine. Also, just FYI, Sunoco and Turbo Blue are the same gas, just different names. I am wondering if Rockett is the same gas as someone else?????
Old 09-14-2008, 05:34 PM   #10
yellowssm
My Ride: 2005 M3
Its sold at rebel oil on sahara and the 15, right by cheetas
I talked to Chris at hpf and he said make sure its 110 motor octane. He suggested vp and sunocco only.
Old 09-14-2008, 09:26 PM   #11
rmz
My Ride: 04 M3 SMG
Torco 110 Leaded (from the pump, at a local station ) @ $6.75/gal
HPF Stg II
rmz is offline   Reply With Quote
Old 09-14-2008, 09:45 PM   #12
tankm3
My Ride: 03 M3
Rockett 111 here.
tankm3 is offline   Reply With Quote
Old 09-15-2008, 11:00 AM   #13
yellowssm
My Ride: 2005 M3
Originally Posted by tankm3 View Post
Rockett 111 here.
Perfect, finally someone that uses it. Im on my way to the pump.
